Closed Thread
Old 07-06-2013, 12:21 PM   #3801
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Originally Posted by 79letour View Post
Its all good. I agree with what you're saying.
But there arent any special additives in the factory oil. Its Idemitsu 0w20.
With some residual assembly lube.
I think I broke the last one in too conservatively.
I'm still not "going hard". I'm just varying rpms and load and not giving two ****s about mpg's for the first 1000-1200.
Your probably doing exactly what you should do. Not to easy, not to hard. Let me know how you like amsoil. I've never used it, and have been curious. I've always used Royal Purple. I'm a creature of habit, its not that I think RP is better than the next one.
G2Spfld is offline
Old 07-06-2013, 12:30 PM   #3802
79letour
Member#: 302570
2013 XV
DGM!
I've used amsoil before.
Their 75w90 Severe Gear is awesome stuff for your Sube's tranny and rear end. Ask Zeeper!
UOA's done on Amsoil samples as well as EXTENSIVE testing/use/abise by many government agencies with vehicles has led me to become a real believer in Amsoil products.
RP is probably really good stuff too, but it sure isnt as popular on the Subaru message boards. I definitely think Amsoils gear oils have a better reputation.
But for motor oil- all 0w20's perform well in tests and all seem to be really good oils.
I get free oil AND changes for life so after 3000 miles, it will lilely run factory Idemitsu.
But I am also a creature of habit, and having heard great things about Pennzoils new 0w20 I couldnt help but buy a couple jugs when they were available and on sale at wallyworld for like $24....
79letour is offline
Old 07-06-2013, 12:32 PM   #3803
79letour
Member#: 302570
2013 XV
DGM!
The reason I'm going Amsoil (oe) is I want to make sure and have the BEST in there for its first change.
I think we all can agree that early engine life is the most crucial part.
79letour is offline
Old 07-06-2013, 12:47 PM   #3804
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Thanks- I wanted to change gear and tranny oil out- but didn't know what to use or if it was recommended. I read someone say not to use anything but factory stuff with cvt. I sold my JD mower ( don't have time to mow anymore) to a guy that runs a heavy equip co that sells Nissan equipment. Nissan gave them all 2wd trucks for service rigs. He changed all fluids to synthetic immed and gets 35. + or - mpg in the truck. He said mainly due to syn oils in drive train.
G2Spfld is offline
Old 07-06-2013, 12:54 PM   #3805
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
There must be a reason Subaru specify ONLY use 0w20 full Synthetic from the first oil change.
A buddies BMW motorbikes ( 2 ) have a similar requirment with BMW stressing using anything else risked voiding warranty. Can only think these engines bores with their slippery coating and tight tolerances don't need "running in" in the same way they used to ?
John451 is offline
Old 07-06-2013, 01:43 PM   #3806
Angelus911
Member#: 89967
2012 Impreza Sport
One word: MPG
Angelus911 is offline
Old 07-06-2013, 02:36 PM   #3807
CLL_OBP
Member#: 310435
'12 Sp Limited
M1 EP 0W20 105,090 miles
The FB engine. A pretty significant change from the old EJ engine. Especially with the cylinder head. Tight tolerances need the oil to be thin. I saw a video on YouTube from a Subaru service department talking about why these engines need 0w20 synthetic oil. I use 5w20 synthetic
CLL_OBP is offline
Old 07-06-2013, 07:13 PM   #3808
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by Angelus911 View Post
One word: MPG
Technically that's 3
flyboy1100 is offline
Old 07-06-2013, 07:33 PM   #3809
79letour
Member#: 302570
2013 XV
DGM!
Ive heard rumors on the web that xv's have been found to come filled with 5w20.
79letour is offline
Old 07-06-2013, 08:30 PM   #3810
nels0300
Member#: 331332
2014 Camry SE V6
I use whatever oil is on sale.
Napa 0W20 for $3.49 a quart currently. Made by Valvoline. Next time? Who knows, whatever is on sale.
nels0300 is offline
Old 07-06-2013, 10:31 PM   #3811
John451
Member#: 321966
While MPGs the obvious long term answer it's not the answer to my question with regards to run in.
My last 2 new cars that run Full synthetic were recommend by factory to use Semi for the first 12,000 miles before switching to Full. The Impreza is different in Requiring "Full" by Subaru from day one, so presume the engine is either pre run in by the factory or built so running in is unnessary for the bore although still required other mechanicals.
John451 is offline
Old 07-06-2013, 10:46 PM   #3812
G2Spfld
Member#: 354284
2013 Imp Sport CVT
This was my concern, albeit I was unaware full synthetic came from factory. I also feel if that's the case then my thoughts for minor oil burn goes out the window. That is assuming tho, that Subaru engineers didn't jump into the new gov mpg guidelines blindfolded. I find it hard to believe they havnt thought things out properly, so to me that only leaves the fact that attention to proper break in is of less significance than previously thought. That is based tho, off of them having full synthetic from the factory.
G2Spfld is offline
Old 07-06-2013, 11:55 PM   #3813
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I think you are better off running factory fill until closer to 7500 miles. From what I saw on my car it was still breaking in through 14000 miles and that was on 3 total changes. If I were to do it again I would run factory fill much longer than the 1200 I ran it
Old 07-07-2013, 12:16 AM   #3814
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I already screwed up then. I changed it to RP at just under 3,000. I'm just a little over 7 now and just did 2nd RP change. I'm not using oil, and it runs great for what it is. So hopefully I'll be ok.
G2Spfld is offline
Old 07-07-2013, 12:22 AM   #3815
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm at just shy of 23k and my oil is also pretty good, I don't notice any real drop in level until later in the interval.
Old 07-07-2013, 08:36 AM   #3816
Zeeper
Member#: 299286
2017 Legacy Limited
I changed my oil twice so far, starting with a change to Amsoil OE at about 1200 miles, then Signature series at 7,000 miles. the car has about 12,000 miles on it now with no visible oil consumption.
The oil changes will neither increase nor decrease your chance of having an engine that consumes oil IMHO.
As far as break in: I didn't do a hard break in, nor did I baby it.
I did not really rev it up until well after the engine had broken in, and seldom do that now (hence my theory that there may be a correlation between those that rev the engine high and increased oil consumption)
Zeeper is offline
Old 07-07-2013, 01:04 PM   #3817
79letour
Member#: 302570
2013 XV
DGM!
While i agree with you- no amount of rpm's helped my consumption test along.
79letour is offline
Old 07-07-2013, 01:45 PM   #3818
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
It did for some
gregorz4 is offline
Old 07-07-2013, 04:27 PM   #3819
79letour
Member#: 302570
2013 XV
DGM!
Fixing to go wash and DETAIL a car that I LOVE!!
Feels great to not hate my car. Life is already much less stressful.
Once I started having to do plumbing, roofing, etc a LOT, I decided a new car was in order.
I like the towing ability, but alas, on the 4th some dickholes stole my trailer. God damn thievery...
79letour is offline
Old 07-07-2013, 06:44 PM   #3820
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Sorry bout that bro- I can't count the ladders, drills, etc I've had stolen at job sites. I loaned a new 18+2 challenger flatbed to a buddy who left it at his sign shop chained to his gooseneck between it and his building. They cut fence, busted chain and drug the gooseneck over and took my trailer. Cops said its a big issue, and most around here go to Oklahoma since they don't register trailers there. Go figure
G2Spfld is offline
Old 07-07-2013, 07:14 PM   #3821
79letour
Member#: 302570
2013 XV
DGM!
Chancesof recovering my 6x12 homebuilt utility are pretty low...
I am in the middle of moving and actually was worried some asswipe would get it.
Oh well...
I'll do a 5x10 this time, so it'll be a little easier to pull with the XV.
79letour is offline
Old 07-07-2013, 07:51 PM   #3822
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Oh well...
I should have bought an XV.
G2Spfld is offline
Old 07-07-2013, 09:00 PM   #3823
79letour
Member#: 302570
2013 XV
DGM!
I would have originally if I'd been given the choice.
I actually scoffed at the idea of the xv when I first heard and read about it. I thought they had simply "lifted" the Impreza.
I like it well enough that, well, I bought it even though its a Subaru!
79letour is offline
Old 07-08-2013, 10:56 AM   #3824
Dubie2012
Member#: 353050
Originally Posted by Dubie2012 View Post
Update: I've had my oil light come on 3 times since the last oil change, which was performed at the dealership. Which tallys up to 3 qts in 4,000 miles. I've been talking to the service manager and he told me they're going to have a specialist come out to look at the car. They are going to want to keep it for 3 days and they'll provide me with a loaner. The manager wouldn't provide me with much details, however he mentioned something of a possible engine swap.
Just an update: They had a master tech look at my engine. He decided it needed to be replaced. It took them a month before they told me I could come pick up my car. When I picked it up I drove it 500 ft down the street and it started misfiring. The check engine and traction control light came on and the cruise light started blinking at me. I took it back to the dealer and they gave me another loaner. Everybody who I talk to about this asks me why they just don't give me a new car. Anybody have any experience with a full car replacement?
Dubie2012 is offline
Old 07-08-2013, 11:05 AM   #3825
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
How old is the car? How does the Lemon Law work in your state?
The misfiring might be a minor thing, like not connecting a sensor or two when the new engine was installed (although I would expect the service department to give the car a thorough test drive before having you come pick it up).
sgoldste01 is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
