Welcome to the North American Subaru Impreza Owners Club Saturday November 22, 2014
Old 07-09-2013, 05:11 PM   #3851
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by jr0bb5 View Post
Thanks man.
Honestly, I don't even care if they have it for a month or longer as long as they fix the problem and put everything back together right. I'm fine with racking up miles on a loaner and keeping them off my car ;-)
If they keep the car for anywhere near a month, you should contact SOA and ask them to reimburse you for one month of your loan payment.
I got VWoA to refund one month of my loan payment when they had my TDI for 2.5 weeks.
sgoldste01 is offline   Reply With Quote
Old 07-09-2013, 05:15 PM   #3852
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
why? What expense are you out that you wouldnt have normally incurred?
auskip07 is offline   Reply With Quote
Old 07-09-2013, 05:55 PM   #3853
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
None. But when you buy a car, you expect to drive the car you're paying for. At least I do.
Old 07-09-2013, 06:45 PM   #3854
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
Update:
I just got word from the dealership that they are going to replace the short block, heads, valves, etc. Basicly everything but the long block. They also said that there was no ETA yet for the parts to come in so who knows how long they'll have it for.
So did they find out what is wrong and causing oil consumption?
subypete is online now   Reply With Quote
Old 07-09-2013, 07:24 PM   #3855
79letour
Member#: 302570
2013 XV
DGM!
Very good advice!
79letour is offline   Reply With Quote
Old 07-09-2013, 07:40 PM   #3856
79letour
Member#: 302570
2013 XV
DGM!
I assume, from following his story along, that oil was/is getting past the rings.
Subaru knows whats going on by now, they replaced engines last year. If their engineers cant figure out a production, design, or assembly issue by now they all deserve to be fired and replaced with Dodge employees.
I think the bores are either improperly machined/honed, or the rings may be somehow botched occasionally when being manufactured or assembled on the production floor at Fuji.
I know with this XV, I've been WAAAY more careful and attentive when driving and breaking it in. Lots of variation in RPM's and keeping the tach mostly under 4000. Not babying it at all. Just giving it ample time to warm up and then varying rpms, engine braking after half throttle pulls to 4000. Havent touched the cruise control. Not going to for at least the first 11-1200 miles. Its at about 400 miles now and no oil loss to note.
If it does end up burning some oil, well, I won't be too upset. A quart in 7500 miles is fine, not three. Wish me luck!
And good luck to you, Jrobb- I'm happy for you man! Hopefully you have fun with the loaner and get your car back all fixed and ready for many many miles.
Old 07-09-2013, 08:19 PM   #3857
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
This is how I broke mine in, except also 2 pulls to redline in 2nd gear when it had 60 total miles on it, overall really no problems
Old 07-09-2013, 08:28 PM   #3858
79letour
Member#: 302570
2013 XV
DGM!
I think 4400-4600 is as high as I've went so far.
Don't they break in aviation engines in a similar way?
Old 07-09-2013, 08:53 PM   #3859
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I picked mine up in KC, and drove it from 3 miles to home kinda rough. Maybe it saw an attempt to redline, just never got there. It was too restricted and tight to get much past 5000. Now it revs much more freely. ;-)
G2Spfld is offline   Reply With Quote
Old 07-09-2013, 10:30 PM   #3860
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Pistons are 75% power for 2 hours straight.
Turbines are just get in and fly, roughly 90+% rpm
Old 07-09-2013, 11:53 PM   #3861
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
I still sorta like the theory about during the break in period the rings weren't seated properly. I didn't rev my engine hard the entire break in period, but with only 100-200 miles on it I let 2 friends drive it a bit, and they both put it up to 4.5-5.5k RPMs once. I joke with them they might have saved my from an oil burner.
Either way, something about the rings...
Xafen is online now   Reply With Quote
Old 07-10-2013, 12:09 AM   #3862
79letour
Member#: 302570
2013 XV
DGM!
Thats what I had thought.
Thats sort of the rationale of this break in procedure. With aspects of Motorcycle break-in applied as well.
Old 07-10-2013, 12:15 AM   #3863
79letour
Member#: 302570
2013 XV
DGM!
I got it with 8 miles on it, anx even on the test drive, I applied the varying engine load/rpm's technique.
My last car, in retrospect, was probably broken in too gently. Or maybe it didnt matter and was born a burner.
With this car, I've been methodical from the start.
My girlfriend said to me that she cant wait till its got 1000++ miles on it so we can dribe along at one speed in one gear for more than a couple minutes.
Old 07-11-2013, 07:09 PM   #3864
Chris793
Member#: 336926
2013 Impreza Sport
Ice Silver
Just did an oil change on my car. 14,500 on the car, 7000 on the fill, amsoil XL and it burned 0.5qt. On my last change the car drained roughly 5qts out, this time only 4.5qts came out.
Having said that, 0.5qts in 7000 miles reluctantly falls into my "acceptable" category. Definitely ran the car harder this OCI, and the temps here in GA are in the 90's everyday.
Put amsoil OE in this time, so we will see if it just didn't like the XL for some reason.
Chris793 is offline   Reply With Quote
Old 07-11-2013, 07:25 PM   #3865
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I see zero problem with .5qt in 7000 miles! It has to use some otherwise not everything gets lubricated
Old 07-12-2013, 09:52 PM   #3866
Sidewindor
Member#: 166609
2013 Outback
How was your tdi in the snow? I am considering moving on from this mess.
Sidewindor is offline   Reply With Quote
Old 07-13-2013, 12:46 AM   #3867
79letour
Member#: 302570
2013 XV
DGM!
I would think going from awd to fwd would be a big disadvantage in snow.
What about an SUV that's compact but has awd or even 4wd?
Old 07-13-2013, 02:24 AM   #3868
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
they're crap without good snow tires. same can be said for almost any car of course, but your suby will get you around pretty well
FunkMasta is offline   Reply With Quote
Old 07-13-2013, 02:52 AM   #3869
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Any car, AWD or not, is gonna suck in the snow without a proper set of seasonal tires. I thought my Subie was horrible in the snow last year with the stock 17's and garbage Yoko tires.
This winter I'm going with a dedicated set of 15" rims with winter tires.
jr0bb5 is offline   Reply With Quote
Old 07-21-2013, 10:35 PM   #3870
79letour
Member#: 302570
2013 XV
DGM!
After all my warning, someone I know went to my first dealer Bill Bryan.
Lmao- shes paying 500 a month for 84 months for a Premium hatch with the only option the moonroof. Thats $42,000 for a subaru impreza! Good folks over there! L
Even after putting 28,000mi on my trade in and losing money on buying another new car and all, I only owe about a grand or so more on the xv than I did on the impreza.
Anyone who knows me and still would buy a car from bill bryan deserves what they get!
Old 07-21-2013, 10:39 PM   #3871
MattD87
Member#: 126930
2012 Impreza Sport
It's the dealer's fault that your friends are incapable of making sound financial decisions?
MattD87 is offline   Reply With Quote
Old 07-21-2013, 10:43 PM   #3872
79letour
Member#: 302570
2013 XV
DGM!
Not at all. Stupid people make stupid choices. She simply stated "I just wanted a car and mastro wasnt open.
Anyone that would pay 500/month for an impreza is gonna get raped on any car deal anywhere.
Old 07-21-2013, 10:50 PM   #3873
79letour
Member#: 302570
2013 XV
DGM!
I lol'ed when she told me that the battery was dead when they went to test drive it. And it had several miles already on it. not like 100 but not the six to eight my cars have when I buy them.
It feels so good to have a car thats never been on Mr Bryans lot!
Man, this XV is awesome!!!!
Old 07-21-2013, 11:00 PM   #3874
MattD87
Member#: 126930
2012 Impreza Sport
Sounds like my local Subaru dealer. I'll drive 45 minutes out of the way just to avoid them.
Old 07-21-2013, 11:29 PM   #3875
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Especially for 7 years. Those numbers don't make sense unless zero down and high interest rate
The only way I can come up with those numbers is a car sold at 25k out the door @ 17% interest. Seriously does your friend have bad credit and no common sense?
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 09:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 06:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 01:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 11:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 01:14 PM
