Closed Thread
Old 08-08-2013, 12:35 PM   #3951
79letour
Member#: 302570
2013 XV
DGM!
What kind of bike?
My pretty well modded ZRX1200 never has had this, not have any of my previous bikes. But I do libe in a flat state.
I could see your engines consuming oil if in the mountains on twisty roads.
But I think rings/bores are to blame for many oil burners.
My new XV doesn't get the carbon buildup on the ass end like my Impreza did.
So far no oil loss noted.
79letour is offline
Old 08-08-2013, 12:37 PM   #3952
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Originally Posted by Unknown77 View Post
I know I thought I was one of the lucky ones with no oil issues.They had already replaced the oil pressure sensor at around 18k miles and it was okay for awhile but when it started I just kept on going back to the dealer whenever the light turned on so it was recorded.
yikes. do keep up posted. i'm at 13k and thought i was one of the lucky ones...i still hope i am, but your experience gives me some cause for concern that oil consumption could start after 20k...
nubsub is offline
Old 08-08-2013, 12:38 PM   #3953
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by 79letour View Post
I havent heard anything good about a shortblock replacement on here yet.
Mine is, so far so good! I do have a rough idle on cold start ups though, not sure if that's related. Subaru service guys said its normal, but they didn't get a chance to keep my car over night to check. It's quite the rough cold start at times though.
gregorz4 is offline
Old 08-08-2013, 12:41 PM   #3954
Dubie2012
Member#: 353050
I am starting to think my situation is "dealership mechanic" issue rather than a warranty issue. I think they really screwed something up while installing this new engine.
Dubie2012 is offline
Old 08-08-2013, 12:52 PM   #3955
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I'm wondering if it might be something simple that's not catastrophic. Does anyone remember reading someplace of a person whose oil consumption was caused by something minor like a bad EGR or PCV valve?
sgoldste01 is offline
Old 08-08-2013, 12:59 PM   #3956
79letour
Member#: 302570
2013 XV
DGM!
Thats kinda the point I was trying to make.
How many fb engines has the service dept removed and swapped before?
Being that they screw up much simpler things, the last thing I'd want is a dealer installed engine.
79letour is offline
Old 08-08-2013, 01:01 PM   #3957
79letour
Member#: 302570
2013 XV
DGM!
Glad youre happy. But both brand new Subaru's I've bought had very smooth idles, even in the winter in the morning. Did your new engine quit consuming oil.after break-in?
79letour is offline
Old 08-08-2013, 01:48 PM   #3958
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
What kind of bike?
Vstar 1100, the only place I have ever seen it lose oil was in Montana, at home I never have issues, again lots of high rpms in low gears climbing and descending mountains. Car is the same from what I can tell.
I went to Colorado over Christmas, but didn't remotely close to the same type of driving I did on this trip, which is why I used a lot more oil imho. I might try to source a new pcv valve though
flyboy1100 is offline
Old 08-08-2013, 01:48 PM   #3959
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Yea after the first oil light/top up I can report I have had zero noticeable oil consumption. How's your new ride treating you?
gregorz4 is offline
Old 08-08-2013, 01:53 PM   #3960
79letour
Member#: 302570
2013 XV
DGM!
Lots better so far, Greg! Thanks!
79letour is offline
Old 08-08-2013, 01:56 PM   #3961
79letour
Member#: 302570
2013 XV
DGM!
My best friends dad rides a V-Star. He had to replace his engine at 10k because of oil problems. Apparently one of the cylinders didn't get proper lubrication.
But I don't recall him losing any oil or smoking.
Its a pretty comfortable bike, I just cant get used to shaft-drive.
79letour is offline
Old 08-08-2013, 01:58 PM   #3962
79letour
Member#: 302570
2013 XV
DGM!
Please post any findings with the pcv if/when you replace, it, please!
79letour is offline
Old 08-08-2013, 02:41 PM   #3963
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
The resources are there for the mechanic to successfully replace a short block. Beside the factory service manual they have a tech line that they can call for questions or anything that is out of the ordinary. If a mechanic is bad and doesn't install the shortblock right, they will have to fix it correctly. Not hard to show them the engine doesn't run right.
With regards to not wanting a shortblock replaced, yeah you're right I would rather NOT have to go through that, however if you NEED to do it, you do it. If given the option to fix your car or continue to have a engine that consumes oil, I would go for the former. That should be obvious.
ST Eye is offline
Old 08-08-2013, 02:47 PM   #3964
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I am up to almost 30k on it, most go for over 100k w/o issues.
Like I said the only place I have had oil issues is in the mountains where it pukes a lot out the breather, and I really think the fb20 with it's high compression creates a lot of crankcase pressure when engine braking
Old 08-08-2013, 02:48 PM   #3965
79letour
Member#: 302570
2013 XV
DGM!
@ST- right,
But I disagree about the dealing having to fix it correctly. They are supposed to- but if something goes awry, which seems very likely, most dealers are notorious for the "thats normal" line.
Im sure they told Greg that idling rough is ok. Because they spent all that time fixing it and it would be a huge pita for them to sort out. And if you call SOA and complain, the dealer can just deny you service.
Thats right- SOA's official company policy is thqt any dealer can refuse any customer at any time for any reason they see fit. All they HAVE TO DO- IS SELL YOU THE CAR.
79letour is offline
Old 08-08-2013, 02:51 PM   #3966
79letour
Member#: 302570
2013 XV
DGM!
True.
Yours sounds like a very normal and well-functioning Subaru.
But with my last car I hardly ever engine-braked and it still chugged the crude. The XV I actually do use the engine to brake with, and not a drop so far...
Knock on wood!
79letour is offline
Old 08-08-2013, 02:53 PM   #3967
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
True.
Knock on wood!
I use it all the time, rarely even touch my brakes above 25-30
Old 08-08-2013, 03:11 PM   #3968
ST Eye
Member#: 73068
@ST- right,
They cannot deny a faulty repair, I'm sorry but they can't.
ST Eye is offline
Old 08-08-2013, 03:19 PM   #3969
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Old 08-08-2013, 03:27 PM   #3970
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Here's a good description of what the PCV valve does, and why:
http://www.agcoauto.com/content/news/p2_articleid/197
Old 08-08-2013, 03:52 PM   #3971
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
The service manual says to not remove it unless broken, the next page is how to test it once removed....how am I supposed to test it w/o removing it? Lol
Part isn't horribly expensive, I might just go buy one tomorrow
Old 08-08-2013, 04:01 PM   #3972
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
How much are they?
Old 08-08-2013, 04:08 PM   #3973
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by sgoldste01 View Post
How much are they?
16.95 msrp. They thread in, and it looks like dealer only for now, but my dealer always has things 15% off
Then again, I think it is probably functioning correctly, 1500+ miles of working the engine decently hard, but still can't hurt to have a spare
Old 08-08-2013, 04:38 PM   #3974
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
They thread in...
Yes, but don't forget to use the appropriate Locktite product that is the functional equivalent of the almost-impossible-to-find thread sealant that the service manual specifies.
A quick Google search will reveal the appropriate stuff to buy. In fact, if you search on this forum, you'll find it.
Old 08-08-2013, 05:09 PM   #3975
79letour
Member#: 302570
2013 XV
DGM!
They're on ebay.
79letour is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
