Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Closed Thread
Old 12-01-2013, 04:57 PM   #4351
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by flyboy1100 View Post
i noticed last weekend and today again that my rear window in the hatch is leaking i checked the main hatch seal and that isn't it so it must be the window. Going to the dealer on wednesday for alignment, I will have to see if i can get that fixed under warranty too before it is up, currently at 34,050 miles
Where do you notice the water from the leak?
sgoldste01 is offline
Old 12-01-2013, 05:20 PM   #4352
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
on the plastic trim, it comes out from the window side
flyboy1100 is offline
Old 12-01-2013, 07:45 PM   #4353
Chris793
Member#: 336926
2013 Impreza Sport
Ice Silver
Maybe a stupid question, but what are the the potential problems associated with a car that consumes oil, in 1qt per 2000-3000 interval? I would guess excessive carbon buildup and clogged cat, but are there more serious issues?
I ask assuming the owner is going to hold onto the car until at least 100,000 miles.
Chris793 is offline
Old 12-01-2013, 07:47 PM   #4354
scooby24
Member#: 56414
2004 Forester XT 5MT
Do these fb engines have ringland issues? Rings, pcv, ringlands or valve stems are the only reasons I can imagine would cause consumption issues.
scooby24 is offline
Old 12-02-2013, 12:57 AM   #4355
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
There is a tsb for the oil control rings. They have been updated. 2013's and up should have the new rings.
As yet I have heard of no problems with ring lands or valve stems, the fb seems pretty well built.
FunkMasta is offline
Old 12-02-2013, 12:38 PM   #4356
BURNiN8R
Member#: 374797
2012 Impreza Premium
Dark Grey
Do you have a web-site or PDF we can reference about the TSB for the oil control rings? I am going to my dealer today to discuss with them about oil consumption.
BURNiN8R is offline
Old 12-02-2013, 12:40 PM   #4357
scooby24
Member#: 56414
I read the TSB and it doesn't indicate that they identified a design flaw...if they are replacing the oil control rings (and assuming pistons) on vehicles with excessive consumption, are they replacing them with a new design/material that wears better?
scooby24 is offline
Old 12-02-2013, 01:35 PM   #4358
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I was able to duplicate this with a garden hose and I took pics. They better completely remove the glass and reattach it, sealing it with silicone will not be acceptable as the glass and glue are structural.
Old 12-03-2013, 09:30 AM   #4359
Oceanguy
Member#: 310466
2012 Impreza
Camellia Red Pearl 5spd
Parts list for New Oil Control Rings:
12033AC360 Ring Set Pist
44616AA200 Gasket Exhaus
14035AA580 GSKT Int Mani (2)
14852AA040 Gasket Air Su
14738AA150 GSKT EGR Pipe
806912190 O Ring 12.1x2 (3)
806924120 O Ring 23.8x2 (1)
806915100 O Ring
806916080 O Ring 16.1x2
10966AA040 GSKT Spark Pl (4)
103270AA240 GSKT Rocker C
13272AA170 GSKT Rocket C
806915170 O Ring 15.4x1 (4)
11044AA780 Gasket Cylind
10944AA070 Gasket Cylind
12109AA120 Bolt Connecti (8)
21236AA050 GSKT Thermo
806939060 O Ring 39.0x2
806750080 Oil Seal 50x62
16608KA000 Fuel Injector (4)
16698AA110 O-Ring (4)
44616AA200 Gasket Exhaust
44011AC030 Gasket (2)
15208AA15A Elem CP-Oil FL
803916010 Gasket
SOA635065 Three Bond 128
SOA635041 Super Coolant (8)
SOA635045 Synthetic 0W-2 (8)
Done at 20,900
SOLD! at 22,000
Oceanguy is offline
Old 12-03-2013, 09:38 AM   #4360
scooby24
Member#: 56414
Hmm...I had to have my rings replaced in my '10 GMC Terrain due to a known oil consumption issue and they replaced pistons too, indicating that pistons wear with the rings. Wonder if subaru's really fixing the problem with just rings...and is the ring design different?
scooby24 is offline
Old 12-03-2013, 11:14 AM   #4361
Angelus911
Member#: 89967
2012 Impreza Sport
I thought I remember seeing that the rings with the TSB fix are larger/bigger
Angelus911 is offline
Old 12-03-2013, 11:18 AM   #4362
kinger37
Member#: 324423
2012 Impreza Sport
ISM
In order to get your car fixed for this TSB, do you have to do an oil consumption test even though your car was in the range of affected years?
kinger37 is offline
Old 12-03-2013, 11:32 AM   #4363
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
Great info, Oceanguy. Strange that they would replace the fuel injectors.
Commander Keen is online now
Old 12-03-2013, 11:50 AM   #4364
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i believe so, it has to exceed the 1qt/1200 miles too
Old 12-03-2013, 12:11 PM   #4365
kinger37
Member#: 324423
2012 Impreza Sport
ISM
My car consumes a half quart per 5k, which I don't have a problem with. My car has 15k on it and after reading all of these stories I'm worried about having issues later down the road when my warranty is up.
kinger37 is offline
Old 12-03-2013, 12:11 PM   #4366
Oceanguy
Member#: 310466
2012 Impreza
I wanted to speak with the tech regarding his findings and get a better explanation of the repair but he wasn't in when I picked it up. I did drive straight to a mechanic that I trust implicitly as I had spoken to him considerably during the process. He was not very confident that this service would "fix" the problem but more mask it longer as he felt there is more going on than the rings. I can only imagine that the combustion chamber seeing the oil fouls up the injectors pretty quickly. Those that consider the down the road chain of events I feel are correct in considering O2 sensors, Cat Converter (but they last a good long while to begin with due to the reason they are on there in the first place), et al. I sold the car and this just helped the decision - we ended up with an extra car due to a death in the family so it really wasn't needed (more like the car payment wasn't needed). All in all, I can't say I was displeased with the dealer that ended up servicing or what SOA finally did - the early goings and denial were the difficult portion claiming it was normal - after initially saying it wasn't normal. Please understand these were their words, not mine. Then the conversation changed to become "acceptable". Every time my wife drove to the dealer for their 1000 mile dip stick check (usually around that time was when the oil light would come on), I instructor her to say, "You still think this is acceptable"? Her good nature would not bring her to say it though...
Good luck to those with consumption issues and congratulations to those that either accept it or don't have it! Like VW says - drive more, worry less
Oceanguy is offline
Old 12-03-2013, 12:17 PM   #4367
Angelus911
Member#: 89967
2012 Impreza Sport
So does this TSB only apply under the standard 36k warranty? What happens if you have excessive oil consumption at say 60k?
Old 12-03-2013, 12:20 PM   #4368
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I believe our power trains have a 60k/5 year warranty. It's the rest of the car that is covered by the 36k/3 year bumper-to-bumper warranty.
Old 12-03-2013, 01:20 PM   #4369
Commander Keen
Member#: 319157
[deleted]
Old 12-03-2013, 02:11 PM   #4370
Angelus911
Member#: 89967
2012 Impreza Sport
You are right, my bad. If it is a TSB though, would they cover it out of warranty, say at 90k? Probably not, then?
Old 12-03-2013, 02:18 PM   #4371
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
There are no guarantees, but there's a good chance that Subaru would cover it outside of warranty. If there's a TSB, then that means there's a pattern failure/problem that is common to many cars sold, and Subaru doesn't want to sour a bunch of customers against the brand.
Old 12-03-2013, 04:18 PM   #4372
dromond56
Member#: 344172
2013 Impreza 2.0i
Originally Posted by jr0bb5 View Post
Ugh... That sucks man. Sorry to hear about your oil burning debacle. If your car is anything like mine was, it'll start consuming more and more oil the more miles you put on it. Also, you may find that it burns oil faster during the warmer months and/or with harder-than-normal driving. Wish you the best of luck and hope that Subaru steps up and takes care of you.
On a side note, I would personally not purchase another Impreza for my wife if mine was an oil burner... Just my .02
I called up customer service at 1-800-SUBARU-3. The representative first parroted the "less then 1 quart burned per 1,200 miles in within the manufacturers spec" line. I explained that while that is true, it is very disappointing to the customer who has to perform added maintenance and worry if their engine will last as long as it should. I also explained that it is a great car other than this problem, and that we are considering an additional Subaru (Forester) but that having a new car consume this amount of oil is extremely discouraging. She offered a $500 service voucher to defray the cost and hassle of adding oil, which I thought was the right thing to do. It's not that this problem makes the car junk, just that you have to frequently check and add oil.
My theory is that engine braking with the manual transmission greatly accelerates the oil consumption. I'm going to monitor the oil level more carefully and see if that is true. Since the power train warranty goes for 60k I have a decent sized window to see if the problem gets worse. It's frustrating and I really hope that if we buy a Forester it doesn't consume oil like this; but at this point it's still not enough make another car more desirable or to make me consider selling it. If the problem gets worse and leads to other problems that would be a different story.
dromond56 is offline
Old 12-03-2013, 04:22 PM   #4373
scooby24
Member#: 56414
Not that I would ever advise lying, but if you've got pretty bad oil consumption that doesn't QUITE hit that 1qt per 1000 miles, it ain't hard to push it over the edge... a la mityvac.
scooby24 is offline
Old 12-04-2013, 01:57 PM   #4374
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
Hey Oceanguy, glad everything worked out for you. I wish I was in the same situation as you and I didn't need my Impreza anymore. I would get rid of it in a heartbeat if I could.
I know I probably sound like a depressing broken record, but I'm still burning an unacceptable amount of oil after my short block replacement. Its hard to have a positive outlook on the longevity of this engine and everything else affected by excessive oil consumption. I would much, much prefer to unload this car before the miles really start to add up. Hoping I'll have the chance to do so in the near future.
jr0bb5 is offline
Old 12-04-2013, 10:46 PM   #4375
Oceanguy
Member#: 310466
2012 Impreza
I can only suggest a lemon law attorney. What is considered acceptable to a manufacturer, does not have to be acceptable to the consumer. If you have all of the factory service records and documentation of the oil consumption issue, you will be better off.
Best of luck!
Oceanguy is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
