Closed Thread
Old 01-04-2014, 06:00 PM   #4501
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by jr0bb5 View Post
It was an actual recall. I got it for my Impreza also.
Where do you find out about past and recent tsbs/recalls for our imprezas?
gregorz4 is offline
Old 01-04-2014, 06:54 PM   #4502
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Unless you live on the east coast, no update
flyboy1100 is offline
Old 01-04-2014, 08:08 PM   #4503
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
That was an East Coast only recall? What's the reasoning behind that? I was under the impression it was a recall for all 2012 Imprezas built before a certain date.
jr0bb5 is offline
Old 01-05-2014, 11:06 AM   #4504
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
The only recall that affected all was the brake master cylinder iirc.
The ecu one they are talking about has something to do with coolant temp or light.
Old 01-05-2014, 04:09 PM   #4505
Angelus911
Member#: 89967
2012 Impreza Sport
The ecu TSB was for PZEV cars and the coolant light, correct?
Angelus911 is offline
Old 01-06-2014, 01:44 PM   #4506
jr0bb5
Member#: 315353
5MT OBP/DGM
I'm pretty sure the ecu thing was more than just a TSB. I received and actual recall notice for the ecu reprogramming. You may be right, however, about it only being for certain PZEV Imprezas. If you didn't receive a notice, then it's not applicable to your car.
jr0bb5 is offline
Old 01-06-2014, 01:57 PM   #4507
Angelus911
Member#: 89967
2012 Impreza Sport
You are right, it was a recall:
Recall Service Program
Engine Control Module Reprogramming | WQC39
Service Program WQC-39
Vehicles Registered in the States of
CA, CT, MA, MD, ME, NJ, NY, OR, PA, RI, VT, WA
Old 01-06-2014, 02:43 PM   #4508
RememberMeJoeB
Member#: 332926
2012 Imp
My first 3 oil changes i had no burned oil, my last 3 oil changes have been after 2500 miles the oil light comes on. The dealer ship said they have done valve adjustments on some legacy's but no imprezas. They did give me a free oil change ($90 value) and have me come iin for "oil consumption test" which is no more than checking the dip stick.
SOA says buring 1qt of oil every 1000 miles is "completely normal" at 10$ per quart. how then would i be able to go the recommended 7000 miles between oil changes? This car would burn off all the oil by the time i got to 5k mi?
RememberMeJoeB is offline
Old 01-06-2014, 03:05 PM   #4509
jr0bb5
Member#: 315353
5MT OBP/DGM
Do you know about how much you are burning? Unfortunately, If you're not over 1 quart per 1200 miles, they're just going to tell you that its normal and send you on your merry way.
If you're not burning much oil, but your low oil light keeps coming on, I think there may be a TSB fix for that.
jr0bb5 is offline
Old 01-06-2014, 06:53 PM   #4510
RememberMeJoeB
Member#: 332926
2012 Imp
I have only driven 400 mi so far. I asked them to collect the oil that came out last time and they 'forgot' to. My dip stick was almost dry when the light was on, I added a quart and it turned off for a week or two till i made it in for the change. Should I just run her dry, ignore the light, blow the motor and warranty a new one? HA!
Old 01-06-2014, 08:40 PM   #4511
jr0bb5
Member#: 315353
5MT OBP/DGM
Lol. I have a feeling you'd be SOL if you ignored your oil light and grenaded your engine. Just saying...
If I were you, I'd call up SOA and let them know what's going on and tell them that your very dissatisfied with the amount of oil that your engine is consuming. They'll open a case and work with you and your dealership to hopefully resolve your problem. If they find that your engine isn't consuming enough oil to warrant repairs, then, well that really sucks and you either deal with owning a car with a POS oil burning engine or you get rid if it and buy something else I guess.
jr0bb5 is offline
Old 01-07-2014, 08:40 AM   #4512
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Let me know how that works out but im pretty sure negligence on your part (it would be pretty obvious if they checked and your light worked) voids the warranty
auskip07 is offline
Old 01-07-2014, 10:26 AM   #4513
RememberMeJoeB
Member#: 332926
2012 Imp
I wouldn't hurt my car on purpose. Every time I go in to the dealer they have comped the oil change so I'll ride that til they stop. The manual says to stop driving when the oil light comes on. Once I call roadside assistance enough times maybe subaru will get tired of sending out trucks and just adjust my valves/rings. Luckily I purchased the 100k extended bumper to bumper warranty.
Old 01-07-2014, 12:22 PM   #4514
jr0bb5
Member#: 315353
5MT OBP/DGM
Thats actually not a bad idea at all! I wish I would have thought of that. Probably would have saved me some time and headaches trying to push my dealership into taking action with my car. Hope everything works out for you. Keep us updated.
jr0bb5 is offline
Old 01-07-2014, 12:54 PM   #4515
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
No it doesn't. It says to park in a safe and level location, check the oil level and correct it if necessary.
Oil level light = amber
Oil pressure light = red
Commander Keen is online now
Old 01-07-2014, 12:55 PM   #4516
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Kills me because im color blind and cant tell the difference between Amber and Red
auskip07 is offline
Old 01-07-2014, 12:59 PM   #4517
Commander Keen
Member#: 319157
For the red light:
"Stop the engine at the first safe opportunity and check the engine oil level. If the engine oil is at the proper level but the light remains illuminated, contact your nearest SUBARU dealer immediately."
Old 01-07-2014, 01:01 PM   #4518
Commander Keen
Member#: 319157
In case you're serious, the amber light has a wavy line below it.
Old 01-07-2014, 01:16 PM   #4519
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
yep color blind I have not seen the red light so ill keep that in mind
auskip07 is offline
Old 01-08-2014, 10:40 AM   #4520
79letour
Member#: 302570
2013 XV
DGM!
Seems like its definitely more cases than "just a few unique individuals".
I need to get to the dealer soon. But its an hour or so drive. At least I've only lost 1.5 qt this time around.
Thing that really irritated me was when I had to borrow some mobil10w20 from my friend whose Toyota Tundra will go 10,000 miles on 0w20 with no appreciable oil loss.
79letour is offline
Old 01-08-2014, 12:41 PM   #4521
Commander Keen
Member#: 319157
As often as you've checked the dipstick on your Impreza, I'm surprised you let that light sneak up on you in the XV.
Old 01-08-2014, 12:46 PM   #4522
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
79letour everytime you repeat yourself you remind me of ted striker from airplane.
aeoporta is offline
Old 01-08-2014, 01:18 PM   #4523
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
In my opinion, 79 has good reason to be disheartened. I don't blame him one bit.
But then again, I lived through a lot of stress and misery with my 2010 VW Golf TDI's issues (and issues with the VW dealership, and issues with VWoA), so maybe it's easier for me to empathize than it is for you.
sgoldste01 is offline
Old 01-08-2014, 02:11 PM   #4524
Angelus911
Member#: 89967
2012 Impreza Sport
+1. I would voice my discontent on here as well if I was having the same luck as him. It's apparent that Subaru hasn't solved this issue yet, regardless of how small a percentage of people it affects
Old 01-08-2014, 02:23 PM   #4525
Commander Keen
Member#: 319157
What luck? His car is burning a quart every 5K. I'm not sure exactly what he plans to do at the dealership. His consumption rate would need to quadruple before they'll give him any consideration.
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
