Closed Thread
Old 09-21-2012, 07:18 PM   #1251
79letour
Member#: 302570
2013 XV
DGM!
does Subaru even sell 0w30? I can't help but wonder what is going on now!
79letour is offline
Old 09-21-2012, 07:36 PM   #1252
alphaproject
Member#: 147588
Well....some years of cars are just big mistakes....this could be the big, BAD year of Subaru when people look back...who knows? The swicth to the 2.0 may have bene a major downfall.
Only time will tell.
alphaproject is offline
Old 09-21-2012, 07:46 PM   #1253
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
googled the S0A868V9300 and all Russian websites for some reason...got one page translated and looks lile 0W20 oil.
http://translate.google.com/translat...ed=0CEIQ7gEwBQ
subypete is offline
Old 09-21-2012, 08:14 PM   #1254
79letour
Member#: 302570
2013 XV
DGM!
yeah thats all I could find too. But with the way the techs were talking, I'm fairly certain they have some kind of 0w30. idk... they"re great folks over there, this has to be some snafu.
79letour is offline
Old 09-21-2012, 08:20 PM   #1255
79letour
Member#: 302570
2013 XV
DGM!
yep.
79letour is offline
Old 09-21-2012, 08:28 PM   #1256
79letour
Member#: 302570
2013 XV
DGM!
well i just got word from the dealer, it apparently was a clerical error, and 0w20 WAS used.
79letour is offline
Old 09-21-2012, 08:44 PM   #1257
pgh88
Member#: 316756
I just had my oil changed after 3k of hard running with no consumption at all. I plan on leaving this oil in for around the next 5-7k. Mobil 1 0w-20 advanced fuel economy(green top)
pgh88 is offline
Old 09-21-2012, 10:33 PM   #1258
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Just had my oil changed. No issues at all. I have discovered some rattles though and found them now i need to find a way to fix them. (might take me 15 min and the use of some free supplies hanging around my apartment.
auskip07 is offline
Old 09-22-2012, 12:27 PM   #1259
79letour
Member#: 302570
2013 XV
DGM!
Checked my dipstick cold this morning. Scribed a line where its sitting now, about half inch over. So what I'm gonna do is measure the diastance between the factory marks, and when my oil has dropped by THAT much, I'll let them know it's lost 1.1 quarts.
79letour is offline
Old 09-22-2012, 02:30 PM   #1260
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
What ever happened to overfilling the engine being bad?
jr0bb5 is offline
Old 09-22-2012, 03:20 PM   #1261
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Is it worse than running out of oil? Nope
auskip07 is offline
Old 09-22-2012, 11:35 PM   #1262
subiTWO
Member#: 273054
2012 Impreza CVT HB
Overfilling the oil can lead to the oil foaming, which can lead to low oil pressure and destroyed main bearings, and more.
subiTWO is offline
Old 09-23-2012, 09:57 AM   #1263
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
dealer generally fill my '12 with 5 qts (0.3 qt below factory recommendation) when I have oil changed. due to oil consumption problem, they're now doing the oil consumption test and is now overfilling to the tune of 5.5 qts.
dorkbert is offline
Old 09-23-2012, 11:02 AM   #1264
nels0300
Member#: 331332
2014 Camry SE V6
With the stories of dealers overfilling, underfilling, filling with who knows what viscosity, and charging $80 for an oil change, it sounds like people should just change their own oil.
This is one of the easiest cars in the world to change oil on. It's cheaper, you can fill it with exactly 5.3 quarts of 0W20, and you'll know what represents "full" on the dipstick with certainty. Buy your crush washers and oil filter from the dealer, your oil from wherever 0W20 is on sale, keep your receipts, and enjoy your piece of mind.
nels0300 is offline
Old 09-23-2012, 11:34 AM   #1265
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Or buy a Fumoto valve so that you don't need a wrench while you're under the car (and don't need to worry about eventually stripping the threads on your aluminum oil pan), get the version of the valve that has a nipple (F-108N) so that you can control the flow with a tube (which also makes it easier to grab an oil sample for a Used Oil Analysis, if you're so inclined), and buy the Subaru oil filters on eBay in a multipack for $7 each.
But I agree with the peace of mind and control that doing your own oil changes provides.
sgoldste01 is offline
Old 09-23-2012, 11:49 AM   #1266
nels0300
Member#: 331332
2014 Camry SE V6
Fumoto valves look interesting, I'm sure they work great, but I could see them being blamed for something were I ever to have a warranty claim related to oil. You shouldn't have a problem stripping the oil pan if you use crush gaskets and only tighten till you can feel them "crush".
My dealer here charges about $7 for the oil filter, so I just pick it up from them and grab a free pop, some chips, and a granola bar while I'm there.
nels0300 is offline
Old 09-23-2012, 12:02 PM   #1267
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I mainly like the flow control that a Fumoto provides. But I agree that following a standard oil change process is easy enough.
Old 09-23-2012, 01:25 PM   #1268
djbono
Member#: 208098
Originally Posted by auskip07 View Post
Full mark when cold. check it when you havent driven the car in 3-4 hours. Mine does that too and then its exactly at the full mark when i do it when cold.
Thanks to your pedantism, I let it cool for 20 full hours. Outside temp. at time of reading: 13C (or 55F)
Same thing, as you can see.
djbono is offline
Old 09-23-2012, 03:17 PM   #1269
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
There are two sides of the dip stick. Side that faces the back of car and side that faces front of car. The side that faces the back is the side i read from. The other side tends to give higher readings.
Did my own oil change at 3000 miles. The front of the car was on rhino ramps. I waited until the oil pan was no longer dripping anymore oil before filling it exactly 5.3 qts. Drove the car for about 2 miles after oil/filter change and then check again after it cooled down overnight at the same garage level spot, dipstick side facing back of car shows level at exactly full dot.
subypete is offline
Old 09-23-2012, 04:37 PM   #1270
79letour
Member#: 302570
2013 XV
DGM!
Never had an oil problem till mine was waaay over-filled.
79letour is offline
Old 09-23-2012, 10:26 PM   #1271
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Didn't you remove the oil not too long after it was filled?
ST Eye is offline
Old 09-23-2012, 11:25 PM   #1272
Swagon_Wagon
Member#: 294424
1999 RSti
white as ****.
These cars, at least a 97 lgt, will run at least 3 qaurts low, maybe more. Just thought I would add that in here.
Had a buddy that had a cam seal slide out of the head and was supper low on oil. Light didn't come on till there was no oil to make pressure. Which I swear would be around quart
Swagon_Wagon is offline
Old 09-23-2012, 11:31 PM   #1273
ST Eye
Member#: 73068
I don't think it is fair to say that all Subarus consume oil. My '05 STi consumed ~1 qt every 2000 miles. My '08 STI doesn't consume any, and neither does my '12 Impreza.
ST Eye is offline
Old 09-24-2012, 06:41 AM   #1274
79letour
Member#: 302570
2013 XV
DGM!
That's what TWO dealers have told me...
79letour is offline
Old 09-24-2012, 07:52 AM   #1275
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, but as a member of this forum, you know better than to believe them.
I'm surprised that Mastro would tell you this.
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
