Closed Thread
Old 11-03-2012, 06:40 AM   #1826
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by flyboy1100 View Post
checked my oil today, 1400 miles on the change with Amsoil Signature 0w-20, no consumption.
What oil change interval are you planning to use with the Amsoil Signature? Signature is expensive stuff, which I could only justify if it's good for longer than other oils.
Right now I'm using Amsoil OE, with a 5k mile oil change interval. I just changed it last weekend, so it won't be due for another change until sometime this winter, at around 12k miles on the odometer. I plan to submit a sample to Blackstone Labs for a used oil analysis at that time.
If you're going to do an extended oil change interval with the Signature, are you planning to submit a sample for analysis? This is the only way we could know if Amsoil's claims for Signature can be believed for our boxer engines.
sgoldste01 is offline
Old 11-03-2012, 09:51 AM   #1827
79letour
Member#: 302570
2013 XV
DGM!
I really don't think the 'boxer' layout of the engine is to blame, I've had plenty of old VW's that didn't have oil consumption problems. And my granny's old GL wagon went 400,000+++ miles in its life one one engjne. I don't recall oil consumption in that car. It was sort of the inspiration for my impreza purchase.
79letour is offline
Old 11-03-2012, 10:01 AM   #1828
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I didn't like xl, which is pretty darn close to oe on paper. I ordered my Blackstone kit and plan to test my fumoto valve out at 6000 miles and see how it is doing. I would like to run 12-15k intervals with a filter change at 7.5k. If it doesn't look like I can get what I want it I will decide, I guess after the vw I'm used to a $50+ oil change in my garage
But so far the signature seems to be holding up better than the xl. I know it is cooler now, but the last few thousand the xl was in the car was cooler too.
flyboy1100 is offline
Old 11-03-2012, 11:42 AM   #1829
djbono
Member#: 208098
5MT here
djbono is offline
Old 11-03-2012, 01:48 PM   #1830
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
That's awesome! What was your consumption like before you switched to Amsoil Signature?
jr0bb5 is offline
Old 11-03-2012, 02:10 PM   #1831
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Not severe like others (you too iirc), on a pace of about 1.4qts/7500. Every 1200 miles was about 7oz. But I haven't seen any change at all with the signature. I tried changing driving habits but it made no effect.
Old 11-05-2012, 09:25 AM   #1832
79letour
Member#: 302570
2013 XV
DGM!
Well- so much for optimism. At 780 miles, I'm 1/18-3/16" down on the dipstick. Bummer.
I noticed that my local parts store got some Signature Amsoil 0w20 in, so I guess I'll switch back next change.
79letour is offline
Old 11-05-2012, 09:48 AM   #1833
jr0bb5
Member#: 315353
5MT OBP/DGM
That's with the 5W30??
jr0bb5 is offline
Old 11-05-2012, 10:15 AM   #1834
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Most 5W30 are thinner than 0w30. I don't think I would try a 5w
Old 11-05-2012, 10:17 AM   #1835
79letour
Member#: 302570
2013 XV
DGM!
Yup.
79letour is offline
Old 11-05-2012, 10:25 AM   #1836
79letour
Member#: 302570
2013 XV
DGM!
Well, I tried the band-aid. It didn't work. Not gonna mess with it anymore.
79letour is offline
Old 11-05-2012, 11:31 AM   #1837
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Are you still above the full dot? You are only down about 4oz if you are. What I have seen on my car is the 5.3qts full mark is about 3/16" over the dot, from there down to about 1/8" under the full dot is between 6-7oz
Old 11-05-2012, 11:52 AM   #1838
jr0bb5
Member#: 315353
5MT OBP/DGM
Really?! I thought it was the exact opposite... Man, this oil weight thing is friggin confusing. Once I think I have it all figured out, someone posts something about oil that completely throws my understanding of it out the door.
jr0bb5 is offline
Old 11-05-2012, 11:58 AM   #1839
MaxCarnage
Member#: 334249
http://www.bobistheoilguy.com/motor-oil-101/
Go there and read up.
MaxCarnage is offline
Old 11-05-2012, 12:00 PM   #1840
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
They shear less than 5w30 too. Some 0w30 are almost 40wt oils they are so thick, especially German castrol
Old 11-05-2012, 12:42 PM   #1841
79letour
Member#: 302570
2013 XV
DGM!
No- its about 3/16" below the full line. It was filled to JUST over the full mark. Maybe a sixteenth or so.
I'm done experimenting. It burns oem 0w20 and it burns synthetic 5w30. It burns oil. Bummer. I got my hopes up this time.
79letour is offline
Old 11-05-2012, 12:44 PM   #1842
jr0bb5
Member#: 315353
5MT OBP/DGM
Originally Posted by MaxCarnage
Funny thing is that I have read that... a few times even. Guess I didnt retain it all.
jr0bb5 is offline
Old 11-05-2012, 01:31 PM   #1843
79letour
Member#: 302570
2013 XV
DGM!
I think the oil itself has been ruled out as the culprit of the consumption.
79letour is offline
Old 11-05-2012, 01:56 PM   #1844
jr0bb5
Member#: 315353
5MT OBP/DGM
If that's true, then all those subie techs that said it was because of the 0W20 were either lieing or don't know what the hell they're talking about. That also means that there truely is a flaw with some of our engines / engine component(s). We'll probably really never know for certain.
jr0bb5 is offline
Old 11-05-2012, 02:20 PM   #1845
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
For S&G keep it in there and see how long it takes for the light to turn on. (factoring the correct fill of the engine) you might see it will exceed your last burn rate. No one said it would cure it totally but it should have slowed it down
Continuing with the 0w-20 makes little sense to me since you know that it will just burn more with it.
as far as a "flaw" in the design. thats usually determined when engines are spinning a certain bearing, breaking a rod, or blowing HG if you list burning oil as a flaw..... buddy you aint got no idea.
as ive said before the type of build. Loose vs tight determine the oil consumption. when you are measuring thousandths there is a lot of wiggle room.
Keep us informed 79 and make sure you keep 2 quarts of oil in the back.
auskip07 is offline
Old 11-05-2012, 02:26 PM   #1846
79letour
Member#: 302570
2013 XV
DGM!
Time will tell.
It aint the oil! But most of us knew that. I was just being optimistic. Its already dropped and hasn't even been nearly 1000 miles.
Meanwhile- my seat most definitely broken inside in some way. Its making noises again. Not so much a squeak as a pop. Its constantly annoying as anytime you shift in the seat at all it just feels like a broken spring.
If I were wealthy, I'd send it back to japan with a nice note attatched.
79letour is offline
Old 11-05-2012, 03:10 PM   #1847
jr0bb5
Member#: 315353
5MT OBP/DGM
Well I wasn't thinking as much as a design flaw as I was thinking perhaps there was a bad batch of rings or some other engine component(s). Or maybe just some of the engines were built on the "looser" side of the tolerance scale.
Time will tell.
I forget, did you try a 0W30? If so, did you have the same results?
jr0bb5 is offline
Old 11-05-2012, 03:59 PM   #1848
djbono
Member#: 208098
sitting at the stealership atm for my consumption test (first visit - 2000km).
Can't wait for them to tell me that "all is ok" (given the dipstick reading is not too bad). ... and for me to show them a picture of where the dipstick was reading when they gave it to me after started the test (a good 3/4inch above full...)
djbono is offline
Old 11-05-2012, 04:42 PM   #1849
djbono
Member#: 208098
Well; no surprises
they took it for 50mins (they told me beforehand it should only take 20mins..);
Svc guy came back with a dirty piece a paper - told me they've "only" had to put in 500ml of il...
Then I asked - Ok but for the test, did you take into account the level it was at when you gave it back to me last time ?
He looked at me liek a deer in headlights... I proceeded to tell him how much oil there was in last time - much more than the full mark - andshown him on the picture...
he told me No, it wasnt' taken into account because they NEVER overfill them... hmm...
wtf.
So I passed for a liar more than anything. Told me to come back in 1600km (wtf... last time they told me it was three visits, one every 2000km...)
Boy am I less and less impressed...
djbono is offline
Old 11-05-2012, 05:18 PM   #1850
79letour
Member#: 302570
2013 XV
DGM!
A dealer would NEVER over-fill. Lmao
My receipt for the last oil change says 0w30. Was told its a misprint. Idk.
Not gonna bother with 0w30, just gonna try the amsoil and continue to ponder how to best get out of the quagmire.
79letour is offline
Closed Thread
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? JDMSTA Electrical & Lighting 59 07-21-2013 08:04 AM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 Oceanguy Impreza Forum 80 11-18-2012 12:56 PM
My Oil Light is Flickering and I have No Leak??? kakarotoni Newbies & FAQs 39 08-16-2012 10:36 AM
('11-'14) 2012 Impreza High beams = Low beams lighting Jmzda Impreza Forum 28 06-01-2012 12:14 PM
