South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-22-2012, 10:36 PM   #1
jrcoyotes21
Member#: 314958
2002 WRX sedan
Angry Someone backed into me!
So the other day, my sister backed into my driver side rear door. Now i'm trying to decide whether to take it into a shop or to buy a new door. Its creased along the bottom, you can kind of see it in the pics.
Do you think a shop would be able to fix it or would I be better off just buying a new door? Does anyone have any good body shops that they recommend?
jrcoyotes21 is offline   Reply With Quote
Old 05-22-2012, 10:42 PM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
New door time, not worth fixing
bobturismo is offline   Reply With Quote
Old 05-22-2012, 11:03 PM   #3
yman
Member#: 199051
04 sti
psm
you can find a WRB door for cheap
yman is offline   Reply With Quote
Old 05-22-2012, 11:08 PM   #4
05bluesti
Member#: 251804
05 WRB STi
I believe i saw wrb door on here not long ago for either 100 or 200
05bluesti is offline   Reply With Quote
Old 05-22-2012, 11:08 PM   #5
jrcoyotes21
Member#: 314958
2002 WRX sedan
Yeah, thats kinda what I was thinking.
Where should I start looking? I know of wrxusa but the doors are $400. I definatley feel like i can find them cheaper
Old 05-22-2012, 11:09 PM   #6
jrcoyotes21
Member#: 314958
2002 WRX sedan
Do you know where?
Also, how hard is it to put on a new door?
Old 05-22-2012, 11:33 PM   #7
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
i have a link give me a second
Edit +link:
http://forums.nasioc.com/forums/show....php?t=2344846
Might want to check with him. Good luck
03.dub.r.x is offline   Reply With Quote
Old 05-22-2012, 11:43 PM   #8
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
man it looks like the rear quarter panel was spared thankfully!!!
DerickRyoung is offline   Reply With Quote
Old 05-22-2012, 11:58 PM   #9
jrcoyotes21
Member#: 314958
2002 WRX sedan
I know! Thank god! I told her if there was a place to hit, that was it. That door had key marks or deep scratches on it already from the previous owner. (you can see the scratches in the pics, right in the middle of the door and under the handle)
And does anyone have experience with replacing a door? how hard is it?
Old 05-23-2012, 12:00 AM   #10
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
Originally Posted by jrcoyotes21
I know! Thank god! I told her if there was a place to hit, that was it. That door had key marks or deep scratches on it already (from the previous owner).
its super easy. with a helping hand i did mine(with my dads help) only important id point out to try and aline it correctly and accurately torquin the door bolts.
Old 05-23-2012, 12:18 AM   #11
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
quick note. i actually got an 02 door for my 03 so the wiring harness was different just a heads up not sure if other yrs differ as well
Old 05-23-2012, 12:20 AM   #12
subaru life
Member#: 305994
beware when buying a new door..02-03,04-05,06-07 are all different.. so if you got a 05 wrb door .. its wont workout..so ive been told by the dealer..(part numbers are different hence different style) i had wrb 03 doors but their gone.. ive recently picked up a shell 07 sti and it needed a door and ive tried replacing it with the 03 door i had..But it didnt line up at al... so just make sure your door is for a 02-03..
subaru life is offline   Reply With Quote
Old 05-23-2012, 12:43 AM   #13
jrcoyotes21
Member#: 314958
2002 WRX sedan
are you sure?? because all the doors listed here say 02-07..
http://wrxusa.com/Doors.html
Old 05-23-2012, 12:45 AM   #14
bobturismo
Member#: 42145
6-4 jockin da bish-
Wagons are different from sedans i believe, but 02-07 are the same
Old 05-23-2012, 12:45 AM   #15
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
and i swapped the harness itself and vuala it works locks window works =\ only speaker doesnt work
Old 05-23-2012, 12:55 AM   #16
jrcoyotes21
Member#: 314958
2002 WRX sedan
I'm almost positive that the wagon is different from the sedan but can someone verify that 02-07 sedan doors are all the same?
EDIT: And im talking about the fitment.. I understand that the harnesses are different
Old 05-23-2012, 01:08 AM   #17
bobturismo
Member#: 42145
6-4 jockin da bish-
They are all the same, I'm beyond positive.
The reason i mention the sedan/wagon difference is because i bet "Subaru life" tried putting one on the other and that's why his door didn't fit.
Also the salvage yard interchange number is the same.
Also the whole damn car is the same for 02-07, it would simply cost too much to change the tooling just to the change the main chassis/doors, you're talking millions of dollars.
Old 05-23-2012, 01:42 AM   #18
subaru life
Member#: 305994
Dealership parts has different part#'s for 02-07...so doors are different.... my friend works at chandler superstition subaru..
Old 05-23-2012, 01:47 AM   #19
jrcoyotes21
Member#: 314958
2002 WRX sedan
Yea the wiring harnesses are different as mentioned above, which could be the reason for the different part numbers?
Old 05-23-2012, 01:52 AM   #20
subaru life
Member#: 305994
Not sure.. my friend assures me different part#'s means different item no interchangeable... just like td04's are different also from 02-07..setup different.
Old 05-23-2012, 01:58 AM   #21
bobturismo
Member#: 42145
6-4 jockin da bish-
I'm sure teh part numbers are different, that's how they do it. Doesn't mean it won't fit.
Trust me the doors fit, there is no car in the last 100 years where the door doesn't fit if the chassis configuration is the same.
Was the door on your car from a wagon or was the 07 chassis a wagon?
EVERY junk yard in the nation goes by an interchange number, meaning parts taht "interchange". The 02-07 has the same interchange, that means they "interchange".
If any junk yard in the last 10 years had sold a door and it didn't fit, the interchange would not be the same.
Also called japcarrealgood / barry, whio has a door for sale, says they are all teh same, also rich who is the head mechanic at camelback subaru agrees.
<Also worked at a subaru dealership and has been building and working on subarus for the 10+ years
Old 05-23-2012, 02:02 AM   #22
subaru life
Member#: 305994
Ok well sorry ive wrong i guess my bad.. my doors were from a wrx02 putting it on a 07sti
Old 05-23-2012, 02:09 AM   #23
bobturismo
Member#: 42145
6-4 jockin da bish-
no worries
08 STI maybe?
02 wrx wagon?
You have to line up the door, it has larger holes tahn the bolts to you can move it around, if you let it settle and tighten the bolts it probably wont shut.
Also $250 for a silver door.
Old 05-23-2012, 02:13 AM   #24
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
bue car is offline   Reply With Quote
Old 05-23-2012, 04:14 AM   #25
05bluesti
Member#: 251804
05 WRB STi
You dont know his setup
I think someone backed into my wife's car, but she won't tell me what happened... rogue Off-Topic 13 08-25-2005 07:19 PM
Someone backed into me! FiKtIOn Texas Impreza Club Forum -- TXIC 3 02-28-2005 07:38 PM
someone backed into me! surfer5567 Interior & Exterior Modification 17 10-05-2004 07:38 PM
I think someone backed into my car in the grocery store parking lot Jersey-Girl Tri-State Area Forum 50 03-09-2004 10:03 AM
Someone backed into my car and broke my C-west rear spat! adamsrs Interior & Exterior Modification 9 03-17-2001 08:21 PM
