Old 05-22-2012, 09:47 PM   #1
Rob.Prairie
Member#: 290881
Default Cannot figure out this misfire
Well, Ive tried everything I can think of, lets see if anyone has any ideas. I have a 04 sti. Since I have owned it I have had a cel. I scanned it with my work scanner, and it came up with a misfire cylinder 1. Since I bought it used, I did the timing belt, water pump, thermostat, and plugs and coils, thinking that would have fixed my problem. The cam sprocket was missing a tooth which I thought that would be my misfire problem, but that did not work. I then had my friend use the snap on scanner to try and narrow it down. It says 1,2,4 misfire, but, he cannot complete the test to narrow it down because the computer keeps kicking out the scanner. So now im completely lost on what it could be. Computer? Anyone have any idea? If I can figure it out I am going to bring it to efi.
Rob.Prairie is offline   Reply With Quote
Old 05-23-2012, 12:31 PM   #2
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
WRXSD is offline   Reply With Quote
May have figured out my misfire at idle issue. MyWRXlove Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 03-03-2013 07:31 PM
Can't figure out this misfire.. zandander Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-11-2011 12:07 PM
Cannot figure out this whirring noise, grrr...... Black_Sun Transmission (AT/MT) & Driveline 0 12-14-2010 02:08 PM
cannot figure out this exh rattle for the life of me! dLo R6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-29-2009 06:24 PM
need help asap! cannot figure out where hose goes (under tmic) ansonb505 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2007 08:22 PM
