Old 05-23-2012, 07:32 PM   #1
htownboxer86
Member#: 261422
06 WRX TR
UGM
Default A/C chirping noise
So it's starting to get warm out and i decided to turn on my A/C after not using it for a long while. When i turned it on, i heard a chirping noise for about 3-4 seconds before it stopped. As i put my car into reverse to back out of my driveway, the chirping kicked back up until i came out of reverse and took off in 1st. I'm not hearing it when I'm driving except for a split second every once in a while during cruising. I'm not too experienced when it comes to belts and the A/C system, so i figured i'd ask to see if anyone has any idea what the cause of this is or has experienced this themselves?
htownboxer86 is offline   Reply With Quote
Old 05-23-2012, 09:36 PM   #2
htownboxer86
Member#: 261422
06 WRX TR
UGM
Update: I noticed one of my belts was slightly looser than the other, so i tightened it a quarter of a turn. I'm not really sure how tight "too tight" is, so i'm kinda iffy on going tighter. turned the car on and heard the chirp for a split second and let sit. Didn't hear it again, but won't know for sure till i head to work in the morning. Anyone have any other suggestions or prior experience with the issue?
Old 05-23-2012, 10:45 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
As far as the loose belts go, no more than 1/2" depression at the center point of the belt between the 2 pulleys.
As for the chirping noise, take an air gun and blow out all the dust around the A/C compressor housing. You'll get a bunch of red dust come flying out. That will stop the chirping noise
Samurai Jack is offline   Reply With Quote
Chirping noise...help! Boujie Transmission (AT/MT) & Driveline 7 06-09-2003 12:25 PM
installed up-pipe, now hearing a strange chirping noise? Rallye-fan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-07-2003 12:12 AM
WRX develops chirp noise? toobee1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 05-08-2002 01:50 AM
Fluttering chirp noise @70mph and up anyone? munkis Normally Aspirated Powertrain 2 01-31-2002 06:54 PM
Chirpping noise coming from right front tire? ImprezedRS Brakes, Steering & Suspension 1 08-21-2001 01:44 PM
