Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-20-2013, 11:01 AM   #351
02RexWI
Member#: 165141
Originally Posted by talonh2o View Post
Where are my parts
What'd you end up doing about your engine?
02RexWI is offline   Reply With Quote
Old 05-20-2013, 11:24 PM   #352
talonh2o
Member#: 183560
05 sti
Just going to get this motor running with the spare heads I have. Having the heads cleaned, and inspected. Gaskets and timing belt kit on the way. Hard to believe that plastic cam gears still seem like the best option. Other than the very pricey JUN gears. Looking at getting some company23 tools for some of the head stuff.
talonh2o is offline   Reply With Quote
Old 05-21-2013, 02:24 PM   #353
02RexWI
Member#: 165141
I've never had a problem with the plastic gears besides getting the bolts loose. It'd be much easier if they were metal so you didn't have to be so careful to not damage them.
I've got the valve spring compressor, if you wanted to borrow it that'd be OK as long as you didn't need it for a long amount of time (and if you actually returned it )
Old 05-22-2013, 10:19 AM   #354
thepunishur
Member#: 336799
04 WRX Stage 2
JBP
Default New Guy
New guy here. Just picked up an 04 JBP WRX, stage 2.
Anyone know of any tuners close to Green Bay? I went to one place, paid for a tune, was told I had slight knock and suggested I replace the plugs to one step colder and try again. Did that, went and paid for another tune (discounted rate), knock was still there. They boost leak tested after the 2nd attempt and found I had a major leak, and suggested I fix it and come back.
Needless to say, I'd like to try another tuner and see what they say.
thepunishur is offline   Reply With Quote
Old 05-22-2013, 12:50 PM   #355
thepunishur
Member#: 336799
04 WRX Stage 2
JBP
anyone in Green Bay want to show me how to boost leak test my car? I'll pay in beer.
Old 05-22-2013, 02:15 PM   #356
02RexWI
Member#: 165141
^I bet that was beyond redline.
Stay FAR away from those guys.
I can do any mechanical work you need, and Brad can do a great tune for you.
PM me if you need more info.
Old 05-22-2013, 02:24 PM   #357
thepunishur
Member#: 336799
04 WRX Stage 2
JBP
I just need someone to show me the proper way to boost leak test these cars. I cam from DSM's, which seem like a cakewalk in comparison. How do I get in touch with Brad and what does he charge?
Old 05-24-2013, 11:53 AM   #358
Toadz
Member#: 262903
2003 WRX
Who's a good tuner that is "close" to western Wisconsin? I'm in the Hudson/Twin Cities area but am willing to drive.
Toadz is offline   Reply With Quote
Old 05-24-2013, 01:38 PM   #359
02RexWI
Member#: 165141
I've heard good things about some shops in the twin cities. I've never dealt with them though.
Old 05-24-2013, 01:51 PM   #360
Toadz
Member#: 262903
2003 WRX
Thanks for the reply. What part of WI are you from? Looking to get to know more people that know these cars. I'm a GM guy so I'm used to over simplicity.
Old 05-25-2013, 12:02 PM   #361
Joshz400_03
Member#: 198844
2004 WRB STi
have you made a boost leak tester yet? I can swing by your place if you have one made and an air compressor.
Joshz400_03 is offline   Reply With Quote
Old 05-25-2013, 01:01 PM   #362
02RexWI
Member#: 165141
I live in Neenah. There are quite a few guys on here that live in a 50 mile radius. If you need to know anything let me know. I've owned a few STI's and WRX's, & I've done just about everything you can think of on them.
If you wanted to get a tune you could make a trip over this way. Me and a couple other people do road tunes.
Old 05-25-2013, 01:19 PM   #363
Toadz
Member#: 262903
2003 WRX
Right now I'm trying to figure out why I'm not getting power to the ECU in an '03 WRX. I've got a thread going in the Electrical section. I'm currently in the middle of swapping an engine and can't get the car that the engine is going into to start so that put a halt on things.
What tuner do you use? Would it be safe for me to make the 4 hour drive without a tune? The car will have a full exhaust from the up pipe back, aftermarket intercooler, injectors, and a boost controller.
Old 05-25-2013, 04:49 PM   #364
talonh2o
Member#: 183560
05 sti
Thanks for the offer. Might take you up on that. Any 245/40/17 tires around by chance? Thinking about putting in whiteline steering bushings while motor is out. Maybe an uppipe. Got the full gasket kit, would have been nice if they were labelled in some way
Old 05-25-2013, 08:17 PM   #365
02RexWI
Member#: 165141
Yeah, I never understood why they give you 3 rear main seals in those kits...
I do have some Kumho XS tires in that size, but they're bald. I was planning on bolting them for the ice this winter.
Toadz,
Your car would be safe to drive except for the injectors... what size are you putting in? If they're close you could probably get it here... otherwise you could get a tactrix cable, & I could send you a tune so you could get the car here.
Put up a link to the thread you started & I'll see if I can help.
Old 05-25-2013, 08:34 PM   #366
Toadz
Member#: 262903
2003 WRX
http://forums.nasioc.com/forums/show....php?t=2508738
I'm not sure of the injectors. They were already on the engine that I'm swapping in. It looks like a red aftermarket fuel rail with pink injectors.
How much are the cables and where can I get them?
Old 05-26-2013, 12:22 AM   #367
02RexWI
Member#: 165141
If you're looking to stay cheap you could get a used 1.3 cable from someone on here, otherwise a new 2.0 is $169: http://www.tactrix.com/index.php?opt...id=6&Itemid=53
I'll give the thread a look in a little while.
Old 06-01-2013, 01:53 PM   #368
talonh2o
Member#: 183560
05 sti
Anyone put in the whiteline steering bushings? Just thinking of possible things to do while the motor is out.
Old 06-01-2013, 02:10 PM   #369
Toadz
Member#: 262903
2003 WRX
Thanks for reminding me...while I'm doing an engine swap, what else should I be replacing/inspecting?
Old 06-02-2013, 11:39 AM   #370
Dankathym
Member#: 38555
2015 STI Launch Ed.
2013 OB BBP SAP 2.5i
I put the bushings in awhile ago, at the time I felt like they helped a good amount.
Dankathym is offline   Reply With Quote
Old 06-02-2013, 09:10 PM   #371
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
They're cheap and make a minor difference since they are pretty thin, unless your current bushings are really worn out
Pete Holt is offline   Reply With Quote
Old 06-03-2013, 09:29 AM   #372
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Hey guys, anybody know of any 08-09 3.0R Outbacks for sale?
Patrikman is offline   Reply With Quote
Old 06-03-2013, 04:35 PM   #373
Joshz400_03
Member#: 198844
2004 WRB STi
holy crap he's alive!
Old 06-04-2013, 04:24 AM   #374
Patrikman
Member#: 234499
2004 Outbrat XT
Haha, speak for yourself! I see you are working at Napa now and selling your car too.
I'd be more than willing to lowball you on those rotas, just sayin. What offset do you run?
Old 06-04-2013, 04:28 AM   #375
Patrikman
Member#: 234499
2004 Outbrat XT
New Website means New Thread - now with Carbotech on the way. KNS Brakes Suspension/Brakes/Handling 4 05-20-2010 01:09 AM
Official Northeast Wisconsin Thread!!! getaforknjob Mid West Subaru Owners Club Forum -- MWSOC 0 02-28-2008 06:42 PM
Official Modded/JDM 08-STi thread #2 *NOW with less nerd!..... STI_SLC Member's Car Gallery 40 11-30-2007 12:45 PM
SE Meet ...teh thread...now with less whoring...and bs... madspecvman Texas Impreza Club Forum -- TXIC 95 09-12-2007 07:59 PM
Crazy cop video - now with 100% less WTLW STiMUL8 Off-Topic 26 11-22-2005 11:02 AM
