Old 05-24-2012, 04:32 PM   #1
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
Default Rear Diff breather replace - easy or hard?
Done my homework and nothing definitive, so asking the crowd:
In an '02 WRX rear diff, how easy is it to inspect/remove/replace the diff breather on top of the case?
I suspect mine is clogged and its the cause of my slow leak out the pinion seal. Or the damn seal is shot - but let's try the cheap stuff first.
I am not afraid to drop the diff a few inches with all else connected, but don't have the tools space or time to pull the axles, DS and do a true diff removal. I've seen the writeup for the diff bushing replacements and could do both at the same time, I think.
I have the FSM but it only deals with diffs that are removed - think it said to hammer it in. Doubt I would have the space to swing a hammer under the diff carrier.
thanks!!
oaklandish_WRX is offline   Reply With Quote
Old 05-24-2012, 05:34 PM   #2
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Pinion seals leak because they are... pinion seals.
I doubt the breather is clogged unless you've been driving up to the doors in mud.
You can pop off the top cap on the breather and run a piece of wire etc down it if it bothers you that much. Getting the whole assemble out without breaking the tabs off will require the diff cover to be removed.
NitroTrike is offline   Reply With Quote
Old 05-24-2012, 06:34 PM   #3
oaklandish_WRX
Member#: 267339
MBP LongRoof
I was assuming it was clogging due to it, in all likelihood, running the factory fill in the diff for >91k miles and clogging from the inside out, so to speak.
Plus, being a former florida car it could have been subjected to deep water. Given the amount of hidden rust I've found....uggh.
I'll start saving my pennies. thanks for the response.
WRX Rear diff breather replacement? Easy? Hard? oaklandish_WRX Transmission (AT/MT) & Driveline 2 05-25-2012 08:02 AM
WTB : Rear diff stud ASAP - Seattle area DrnknZag NWIC Private Classifieds 0 05-24-2012 01:21 AM
Window replacement, Easy or hard? P.J. Interior & Exterior Modification 6 09-08-2009 08:31 PM
Clutch Replacement...easy or hard? jsterner Transmission (AT/MT) & Driveline 2 01-04-2007 11:41 AM
How easy or hard would it be to replace an 04(possibly sti) front end on my 02 wrx. booSTIes! Subaru Conversions 3 08-06-2004 06:02 AM
