Notices
Old 05-24-2012, 09:23 PM   #1
Franko
Member#: 193628
2010 STI
SSM
Default Anyone have a 60 gal upright compressor? How did you mount it?
Just got one for my garage. It says to bolt it to the concrete floor but I don't want to do that. Could I just leave it on the skid it came with? I read about people doing that.
Franko is offline   Reply With Quote
Old 05-25-2012, 12:10 AM   #2
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
That'll probably work. If not, build some outriggers for extra stability.
sizemic1 is offline   Reply With Quote
Old 05-25-2012, 12:10 AM   #3
sizemic1
Member#: 270669
2011 WRX Sedan
Old 05-25-2012, 12:21 AM   #4
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
I never bolted mine down nor did I leave it bolted to the pallet. Never had an issue. They aren't that tipsy. I put my 80gal vertical on wheels! That thing is twice as heavy as my old 60gal unit.
ChicksDigWagons is offline   Reply With Quote
Old 05-25-2012, 01:53 AM   #5
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
Add a couple kickers from the pallet to the wall studs if you are worried about it. but it will be just fine on the pallet or on the floor
cmk82600 is offline   Reply With Quote
Old 05-25-2012, 02:11 AM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
on the two that I have installed it specifically says to not leave it on the pallet... So I would skip that...
I would at the very least support it to the wall with a chain or something...
Zefy is offline   Reply With Quote
Old 05-25-2012, 02:53 AM   #7
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
At the shop, it's on concrete blocks and strapped to some very solid bolts in the steel building's structural members... And not going anywhere anytime soon. Put it out of the way and far from where you're working if you can afford the hose routing, or the noise gets annoying after a while. Ours is in an attached (basically closet) outbuilding... Soundproofed...
J_Baker is offline   Reply With Quote
Old 05-25-2012, 07:42 AM   #8
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Leave it bolted to the pallet.
rudymcskoody is online now   Reply With Quote
Old 05-25-2012, 09:10 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We have one at the shop that we left on the pallet and tucked into the compressor closet.
I have one at home that I put on a few old mousepads and then strapped to the wall as it's tucked into a corner.
Old 05-25-2012, 11:10 AM   #10
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Why don't you want to bolt it to the floor?
Mine is done like that and it keeps it quiet and in place. 1 masonary bit on a regular drill and the cleated studs and maybe 1/2 hour of time.
Old 05-25-2012, 01:15 PM   #11
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
a couple hooks in a wall and a ratchet strap or tie down will keep it from falling over.
Bacon117 is offline   Reply With Quote
Old 05-26-2012, 06:10 AM   #12
mikeythejew
Member#: 141672
I left mine on the shipping pallet and anchored it in the floor with a few Tapcons.
So If I ever remove the compressor, only a few small holes can be sealed easily.
I located the compressor in my basement and plumbed the airlines with copper into the garage. I added a water separator and have coiled line to help cool the pressurized air.
Putting it the basement was great. I don't hear the damn thing run and it's not that audible in the house.
mikeythejew is offline   Reply With Quote
HELP! Has anyone tried to replicate these? If so how did you do it? wrx2oo2 Interior & Exterior Modification 15 08-09-2008 05:50 PM
Anyone in NJ have an STI yet? If so, where did you buy it? Evil STI STi Forum Archive 16 06-12-2003 11:18 AM
To those with MRT boot tank- how did you mount it? tifosi77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-03-2002 01:17 AM
How did you mount your HID / Catz Zeta Ballast ? DEVO-2nd GEN Interior & Exterior Modification 9 04-20-2001 12:52 AM
