Old 05-25-2012, 11:44 AM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default 1/4 mile- WRX wagon [email protected] at 5400'
Event: quarter mile
Ambient Temp: 75
Elevation: 5400 feet (density altitude 7474')
Weather: sunny
Track and Conditions: ok
Tires: BFG DR's 225/45R17
Car: 2006 WRX Limited wagon
Tuner: me
Transmission: 05 6 Speed, Rallispec long gears
Target Boost: 30
Fuel: E85 (tested E72 on zietronix)
Engine/Power Modifications: Full race BW91-79 with supporting mods
Driveline Modifications: Full STi drivetrain, DSS rear axles
This is the first time the car has been out this year. Last year it went 11.05 pushing coolant pretty bad. I tore it down and decked the heads and installed L19's.
2nd pass of the day which ended up being my only full pass since I bent the 1-2 shift fork after that.
Quickest/fastest Subaru in NM
60' - 1.733
1/8- [email protected]
1/4- [email protected]
Left lane:
Video-
06rexwagon is offline   Reply With Quote
Old 05-25-2012, 11:45 AM   #2
stanghater
Member#: 69381
2005 Legacy GT Wagon
2002 hta green WRX
congrats dude
Fastest subie in NM
stanghater is offline   Reply With Quote
Old 05-25-2012, 12:06 PM   #3
freakfly23
Member#: 171302
2006 wrx tr
crystal grey metalic
Great run cam. Congrats on the time.
freakfly23 is offline   Reply With Quote
Old 05-25-2012, 12:25 PM   #4
whitesti400
Member#: 151005
05 STi
good stuff Cam!!
whitesti400 is offline   Reply With Quote
Old 05-25-2012, 12:27 PM   #5
CatfaceType-R
Member#: 81102
not bad for a wagon . what does your car weigh? mr hardshifter!
CatfaceType-R is offline   Reply With Quote
Old 05-25-2012, 12:38 PM   #6
edsonmassao
Member#: 291430
2006 WRX wagon
man, this is fast! congrats!
edsonmassao is offline   Reply With Quote
Old 05-25-2012, 12:39 PM   #7
06rexwagon
Member#: 114730
[email protected]
Weighed 3565 with me in it last time I weighed it. I probably took 50 lbs out of it since then, and I weigh 170. So I'm guessing somewhere just over 3300.
Old 05-25-2012, 12:44 PM   #8
06rexwagon
Member#: 114730
[email protected]
I tried running the car turned up on the 1st pass but it blew through the clutch as soon as I shifted to 2nd (1.64 60'). The car is turned down from it's normal tune but it will 60' in the low 1.6's consistently- I just need the clutch to hold it.
Old 05-25-2012, 01:03 PM   #9
Dizzuque
Member#: 98699
2007 SWP WRX
Congrats Cameron! Loving the wagon.
Dizzuque is offline   Reply With Quote
Old 05-25-2012, 01:09 PM   #10
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Congrats again Cameron
Old 05-25-2012, 02:48 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
Congratulations Cam
I know you have more in it
Nuke209 is offline   Reply With Quote
Old 05-25-2012, 04:46 PM   #12
bebesito21
Member#: 176128
5862 ...baby boosted
what ecu are you running? sounds like you need per gear boost control
edit: on second thought, per gear would not fix it....nevermind....
bebesito21 is offline   Reply With Quote
Old 05-25-2012, 05:53 PM   #13
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Congrats Cam! Can't wait to get my FR setup.. wagon power!
izergfx is offline   Reply With Quote
Old 05-25-2012, 06:03 PM   #14
06rexwagon
Member#: 114730
[email protected]
I run an aem ems.
Old 05-25-2012, 06:30 PM   #15
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
BAM! there it is.. great work
Kastley85891 is offline   Reply With Quote
Old 05-25-2012, 07:15 PM   #16
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
Doesn't this car have 700whp?
JMK508 is offline   Reply With Quote
Old 05-25-2012, 07:27 PM   #17
izergfx
Member#: 308012
C# & Java Devs***
PM me***
I think this is the most recent graph on nasioc:
Also, after DA calculations (turbo calc from dragtimes, not N/A calc), the run comes out to a 10.318 @ 135.524 MPH. After fixing the 1.7 60' and slipping clutch It should be capable of 9's at sealevel.
Old 05-25-2012, 08:08 PM   #18
Vincz
Member#: 257224
2010 STI
That graph is from when he was pushing coolant. He recently hit 740 on our dynojet
Vincz is offline   Reply With Quote
Old 05-25-2012, 08:38 PM   #19
Blue91lx
Member#: 321303
2003 Evolution
Apexi Silver
Are your traps low because of the altitude? 700whp should be trapping sub 140, no?
Blue91lx is offline   Reply With Quote
Old 05-25-2012, 08:41 PM   #20
06rexwagon
Member#: 114730
[email protected]
Well the transmission is out and apart. The shift fork is fine, but the ring won't move over to 1st gear. It was jammed part way into 1st but once I tapped it down it moved into 2nd just fine. It will go to 1st if I use a punch and hammer to tap it into gear. Any transmission gurus have any ideas? The syncro looks fine.
Old 05-25-2012, 08:43 PM   #21
06rexwagon
Member#: 114730
[email protected]
Our sae correction is crazy high. The car made around 630 uncorrected on a dynojet that a stock sti makes 250-260 corrected on. My corrected dyno was 744whp. I ran the car at low boost though and was roughly 50whp down from my dyno. It's a heavy car and I'm a bad driver.
Old 05-25-2012, 09:19 PM   #22
Blue91lx
Member#: 321303
2003 Evolution
Apexi Silver
Figured something was up. This car has a LOT left in it. Definitely excited to see what it can do.
Old 05-26-2012, 01:21 PM   #23
06rexwagon
Member#: 114730
[email protected]
Here's the clutch I just installed about 700 miles ago. It slipped bad with the car turned up.
And here is the 1-2 selector that won't move to 1st. 2nd is ok now. It was just stuck slightly toward 1st.
I'll need to press the gears off again to see what the problem is.
Old 05-26-2012, 01:54 PM   #24
Young_Sauce
Member#: 321364
That's crazy! wish mine was as fast.
Young_Sauce is offline   Reply With Quote
Old 05-26-2012, 02:03 PM   #25
GeneralTJI
Member#: 152680
Sorry for the issues, hope you get it worked out. Nice run....
I hear you on DA, my track is over 9k quite often
GeneralTJI is offline   Reply With Quote
FS/FT: Version 4 JDM WRX wagon with a ton of mods martystoked Private Vehicle 'For Sale' Classifieds 7 04-02-2010 12:29 AM
F/S NC 04 WRX Wagon 10,900 OBO 118k miles ajwrxwgn Private Vehicle 'For Sale' Classifieds 0 08-05-2008 09:43 PM
testing waters 4 sale WRX Wagon 03 beachbear Private Vehicle 'For Sale' Classifieds 4 01-24-2004 10:57 PM
1/4 mile- when to shift into 4th? Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-22-2002 08:16 PM
Nice WRX wagon in my parking lot at work... Layman Mid Atlantic Impreza Club -- MAIC 2 06-15-2001 11:26 AM
