Old 05-25-2012, 04:57 PM   #1
DannyD303
Member#: 271150
2004 Impreza WRX
Default scratches and imperfections
So my sister parked her next to me the other day and after a litle while later I noticed this....
[IMG][/IMG]
[IMG][/IMG]
Throwing this out there to anyone with ideas on a way to make this go away. Here are a few other paint issues I have going on. Any and all ideas welcome.
[IMG][/IMG]
[IMG][/IMG]
DannyD303 is offline   Reply With Quote
Old 05-25-2012, 05:00 PM   #2
XERO287
Member#: 253541
2011 WRX 5DR Premium
3000 grit wet sanding should do the trick. Followed by some polishing after.
XERO287 is offline   Reply With Quote
Old 05-25-2012, 07:34 PM   #3
subiesnacks55
Member#: 321319
2005 wrx sti
man thats a bummer.. Sorry! but yeah what he said ^^^^^^^^
subiesnacks55 is offline   Reply With Quote
Old 05-27-2012, 05:59 PM   #4
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
I noticed how bad the paint condition is before I even saw that individual scuff lol. Looks like someone washed the whole car with a dirty sponge without rising it out once and spreading the same dirt all around the car to make consistent swirls and scratches.....
As for the first paint defect, that looks like paint transfer and will be on the surface of the paint. I would clay bar first to clear that area of surface contaminants (but why not just clay bar the whole entire car while you're at it.) After wards, depending on what you have on hand. Paint thinner will take that off, rub lightly with a small amount and make sure to thoroughly wash the area with some soap right away afterwards to remove all chemical residue. If not, I would use a light polishing compound with a foam applicator pad or a microfiber towel. Note that once you polish that area, that spot will be a lot clearer than the rest of the car, still making that spot noticeably different from the rest of the car....
As for the second one, Im not entirely sure because it is kind of hard to see. It either looks like acidic etching from bird droppings or other chemical residues that have ate through the pores of the clear coat because (correct me if Im wrong, your naked eye should be able to tell better) it looks like there is some rippling on that defected area. I would do the same and try clay barring it first, then on with the polish to see if it has made anything better. If the paint is unleveled in that area ( like what I suspect with bird droppings or other chemical etching) then a heavier correction might be required to level out the clear coat...DEPENDING on how much paint has been lost already. It might not entirely be safe to do so to a point, depending on how much paint has been permeated. I would not recommend just jumping straight to wet-sanding if you do not know what you are doing, and because you have asked this question.
pho_shizzle is offline   Reply With Quote
Old 05-27-2012, 06:05 PM   #5
tibug
Member#: 273906
1831 Conestoga Wagon
My oxen all died.
You should kill her. Oh, you mean the paint. Um, idk.
tibug is offline   Reply With Quote
NLM - Used parts, open box, and scratch and dent No Limit Motorsport No Limit Motorsport 11 09-13-2012 01:59 PM
COBB Tuning Surgeline Overstock and Scratch and Dent Sale! Cobb Tuning NWIC Vendor Classifieds 11 06-08-2010 08:02 PM
Scratch and dent 04' STI HID's, with wiring and leveler switch. AKGC8 Exterior/Styling 1 06-17-2009 01:55 AM
Scratches and polish - Before and afters Kastley85891 North West Impreza Club Forum -- NWIC 3 12-17-2006 06:26 AM
Brembo and aluminum A arm scratch and dent sale galore IA Performance Suspension/Brakes/Handling 65 08-25-2004 12:27 AM
Message Board Statistics All times are GMT -4. The time now is 01:36 PM.
