Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Private Classifieds
Old 05-26-2012, 12:42 PM   #1
rcp15
Member Sales Rating: (21)
Member#: 307539
2004 PSM
JDM Sti EJ207 Ver 8
Like the title says i need a ver 8 jdm avcs solenoid asap. Preferrably somebody from Houston. Let me know what you got. Thanks! 832-518-0324
rcp15 is offline   Reply With Quote
Old 05-26-2012, 12:53 PM   #2
B.R.E.D
Member Sales Rating: (2)
Member#: 289606
06 WRX
white
I'm running my JDM heads on USDM Soleniods and haven't had a issue.
B.R.E.D is offline   Reply With Quote
Old 05-26-2012, 12:55 PM   #3
rcp15
Member#: 307539
2004 PSM
JDM Sti EJ207 Ver 8
What version jdm?
Old 05-26-2012, 12:55 PM   #4
silvialost
Member Sales Rating: (6)
Member#: 91021
1997 impreza
red
bread what version jdm heads are you running?
silvialost is offline   Reply With Quote
Old 05-26-2012, 01:00 PM   #5
B.R.E.D
Member#: 289606
06 WRX
white
Version 8
Old 05-26-2012, 01:05 PM   #6
silvialost
Member#: 91021
1997 impreza
red
Usdm solenoids do not work with the jdm head. I have tried it.
there is a slight veriance at the end of the solenoid that lets oil pressure by and advances the cam.
Old 05-26-2012, 01:07 PM   #7
B.R.E.D
Member#: 289606
06 WRX
white
Thats all I've ever had in mine and I've never had an issue. The last time I ran them on a car they made 550whp at 18lbs, I doubt the cams were advanced or we would have had issues. Its been a while though so Ill see if I can dig up the datalogs and take a look.
Old 05-26-2012, 01:12 PM   #8
silvialost
Member#: 91021
1997 impreza
red
550 wheel on 18psi?
what dyno, what size injectors?
Old 05-26-2012, 01:14 PM   #9
B.R.E.D
Member#: 289606
06 WRX
white
Precision T4 PT67 Low Mount, 1600cc injectors
Old 05-26-2012, 01:17 PM   #10
silvialost
Member#: 91021
1997 impreza
red
what dyno?
Old 05-26-2012, 02:38 PM   #11
B.R.E.D
Member#: 289606
06 WRX
white
Dynojet. Just dug through my binder of invoices. They were jdm soleniods i got them from jdm parts.com
Old 05-26-2012, 07:59 PM   #12
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Are you just missing the solenoids or do you think they're not working properly?
Computersare8ad is offline   Reply With Quote
Old 05-27-2012, 10:22 AM   #13
rcp15
Member#: 307539
2004 PSM
JDM Sti EJ207 Ver 8
They're not working. Its running on open circuit. I found one from iaperformance.com brand new.
Old 05-29-2012, 08:57 AM   #14
silvialost
Member#: 91021
1997 impreza
red
his driver side solenoid has no continuity across the terminals. ecu sees this and trips code for open circuit. would do the same thing if it was just left disconnected.
Old 05-29-2012, 09:40 AM   #15
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
Yeah, as I told 'em I would swap the passenger side in before buying a new sensor. If the problem moves to the passenger side and the drivers side is fixed the issue is the sensor... if the p1308 stays then it is a wiring problem.
Easy peasy.
Old 05-29-2012, 01:36 PM   #16
silvialost
Member#: 91021
1997 impreza
red
i have already removed the drivers side solenoid and tested the continuity on it. It is bad. Tested passenger side as well and it is good. So we are already past that point.
Old 05-29-2012, 08:17 PM   #17
rcp15
Member#: 307539
2004 PSM
JDM Sti EJ207 Ver 8
Brad, i should get the solenoid on friday so i should be there saturday morning.
FS CA: JD STi Ver. 8 Seats, 02 WRX Seats, 02 MoMo Wheel, JDM Ver.8 STi Gauge Cluster ViperWRX Interior/Dressup/Audio & Security 144 04-14-2010 05:20 PM
jdm ver 8 and jdm ver 7 acheung Newbies & FAQs 3 01-03-2010 02:13 PM
F.S JDM VER 8 TOP MOUNT INTCOOLER,VER 8 RH HEAD(big ports)TURBOCHARGER.COM TD 05 16G shaz1980 Engine/Power/Exhaust 25 12-03-2009 12:16 PM
JDM Version 8 AVCS Cam Sensor wiring? Kotir Subaru Conversions 22 03-24-2005 04:10 PM
what is different about jdm ver.8 sti injectors? Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-25-2003 02:40 AM
