Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 05-27-2012, 03:04 AM   #1
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Default ALL Hybrid 2.5L Shortblock & 2.0L Cylinder Head INFO Thread *POST HERE*
I'll start helping you guys out by compiling the mounds of threads into one easy to read thread with all the info you need for your Hybrid builds.
Threads are getting cluttered up with mis-information and whatnot.
If you have a informative post please PM me and I'll add as we build it up.
I hate searching as much as you guys do but starting a new thread every time, just mucks it all up.
-Phil
Flat 4 Motorsport is offline   Reply With Quote
Old 05-27-2012, 03:04 AM   #2
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Old 05-27-2012, 11:44 AM   #3
bryan1242
Member#: 321352
im on a 2.5 block with 2.0 heads i cnt find a straight answer as to what thickness head gasket to get and where to get block is stock and so are heads i have fp18g turbo and pink sti injectors
bryan1242 is offline   Reply With Quote
Old 05-27-2012, 12:55 PM   #4
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
did you deck the heads and block?
did you machine and chamber match the cylinder heads?
Use better grammar dude. Very hard to understand what you're asking.
ronzogonzo is offline   Reply With Quote
Old 05-27-2012, 05:05 PM   #5
TechMJ
Member#: 145804
2002 Bugeye Beast,
Murdered Out,2.5,6spd,20G
Impreza WRX STi
Use OEM STI Head Gaskets and get your heads combustion cambers matched to the block by ASF Machine.
Equilibrium Tuning's Head service is good but I went with ASF Machine and the job/service was EXCELLENT!!!
TechMJ is offline   Reply With Quote
Old 05-27-2012, 05:56 PM   #6
MainFrame
Member#: 218739
2002 WRX hybrid
Really the only hybrid specific questions most people will have pertains to combustion chamber work, head gasket thickness, compression ratio (you could throw piston dish in here), and crank case/head breather routing.
MainFrame is offline   Reply With Quote
Old 05-28-2012, 01:43 AM   #7
KpT KiM
Member#: 242422
Outfront Motorsports cut my chambers to STI specs and car runs well so far. No knock problems.
Not sure if this type of "Where can I get my heads worked on for a hybrid?" info should go into this thread though.
KpT KiM is offline   Reply With Quote
Old 05-28-2012, 02:04 AM   #8
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
^^ this is good, this is exactly what this thread is meant for.
Please post up results, reviews and info pertaining to any hybrid setups.
It makes it so much easier for people who are searching to just go to one thread for all their questions.
-Phil
Old 05-28-2012, 10:31 AM   #9
daddyphatsax304
Member#: 248075
02' WRX Wagon
This is good stuff. Very broad topic and hard to search for answers sometimes...
Thanks Phil!
daddyphatsax304 is offline   Reply With Quote
Old 05-29-2012, 03:00 PM   #10
wrxkid2003
Member#: 228945
2003 WRX
Should become a skicky
wrxkid2003 is offline   Reply With Quote
Old 05-29-2012, 05:36 PM   #11
subarufan555
Member#: 255117
2004 ANY Subi
ANY
Im just finishing building a Hybrid 2.5 block with WRX heads. What spark plugs do you recommend?
I be running E85
Thanks
subarufan555 is offline   Reply With Quote
Old 05-29-2012, 07:05 PM   #12
ronzogonzo
Member#: 136671
WRX HTA GT3076R
2L heads use 2L plugs
-Phil
Old 05-29-2012, 08:56 PM   #13
texasedirp
Member#: 304669
Thumbs up
AGREED. Definitely should be a sticky. this is day one of my research for my hybrid build, and just so happens a thread with compiled info pops up on the first page. Thanks for starting this. Gonna save people like me hours and hours of searching.
texasedirp is offline   Reply With Quote
Old 05-29-2012, 09:13 PM   #14
ronzogonzo
Member#: 136671
WRX HTA GT3076R
Sure thing guys, if anyone has info they want to include post up or PM me and I'll put it in the first post.
-Phil
Old 05-29-2012, 09:39 PM   #15
wrxkid2003
Member#: 228945
2003 WRX
Thumbs up
Same here first day on research and surprised not to find a sticky in the 2.0 or motor build sections about hybrid builds.
I would also like to add save this forum from alot of repeat threads.
Old 05-29-2012, 10:23 PM   #16
Jirv311
Member#: 273528
2002 Impreza WRX
It might also be nice if people could post their "recipes" for their hybrid builds. Like what compression pistons, head gasket and thickness, machined heads or not, etc.
Jirv311 is offline   Reply With Quote
Old 05-29-2012, 10:31 PM   #17
KpT KiM
Member#: 242422
OEM Shortblock
CP Pistons 9:1 CR
Stock STI head gaskets
Combustion Chambers cut to STI specs by Outfront Motorsports
Car is running great. Higher CR is definitely nice for autocross even with pump gas.
Old 05-30-2012, 11:09 AM   #18
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Originally Posted by KpT KiM View Post
OEM Shortblock
CP Pistons 9:1 CR
Are you sure you maintained a 9:1 CR even after having the cc's worked?
Zackbo is offline   Reply With Quote
Old 05-30-2012, 01:41 PM   #19
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
^^^ this. I had a guy bring me his car to tune because nobody else could get it to make decent power for his setup. I started the tune and right off the bat I knew something was different. I asked for his build specs and ends up he had over 10.5 to 1 compression. The guy thought because he bought a cosworth shortblock with flat top 9.5 to 1 pistons that his compression ratio would be 9.5 to 1. Wrong! He didn't take into account gasket thickness or head cc size before he bolted the heads to the block.
fastblueufo is online now   Reply With Quote
Old 05-30-2012, 05:20 PM   #20
ripman
Member#: 305707
1999 WRX
WRC Blue
My question would be: what view are the pro engine builders taking with regard to lobe centres on a 2.5 with 2l non AVCS heads. Kelfords seem to be the cam of choice here in AUS, but from what I can find on their site all there 2.5 cams are built for AVCS. Do you go a 272 that matches the 2l heads rather than the 264 for example? If you know what I'm saying.
ripman is offline   Reply With Quote
Old 05-30-2012, 07:50 PM   #21
KpT KiM
Member#: 242422
Good question. I'm betting so as my 205 heads are now like 257 heads without AVCS. I used OEM 2.5 L headgaskets and the CP pistons are designed for the 257, so I believe everything that could cause higher compression is taken care of. I didn't mill the heads or anything.
Old 05-31-2012, 04:58 AM   #22
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I ran the Cosworth non-AVCS 2.0L cams in my 2.5L hybrid in the past and also in the new engine going in my STi right now. The last engine screamed and made good power considering Cali 91 octane and only 21 psi. This time I will make more.
Old 05-31-2012, 07:45 PM   #23
Jirv311
Member#: 273528
2002 Impreza WRX
So if stock STi compression is 8.2:1 and I use 8.5:1 pistons with 02 WRX heads undecked, stock STi head gaskets, what CR am I looking at? I've heard with stock STi pistons (at 8.2:1) it's around 8.96:1-ish so would 9.26:1 sound about right?
Old 05-31-2012, 10:18 PM   #24
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Nice thread Im hoping we get some great info in here. Ill post up some info in my old hybrid, and my new hybrid build soon.
rexworx is offline   Reply With Quote
Old 06-01-2012, 10:06 AM   #25
Nuul
Member#: 313456
2003 WRX Wagon
Thanks for posting this, good info for those of us about to start a hybrid project.
Nuul is offline   Reply With Quote
WTB 2.5l Shortblock or 2.0 Longblock 97gtguy Private 'Wanted' Classifieds 54 02-15-2010 01:27 PM
2.0L to 2.5L Shortblock Build/ Turbo Options? csmithwrx'05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-08-2008 11:50 AM
wtb 2.5 shortblock & 2.2 heads kylemcspecial RMIC Private Classifieds 0 06-20-2006 02:59 PM
jdm sti v8 2.0l or usdm 2.5l shortblock? WSSBOARD18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 03-06-2005 04:48 PM
STI 2,0L vs STI 2,5L shortblock - need help calvin434 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-30-2005 11:02 AM
