Old 06-01-2012, 09:06 AM   #26
Nuul
Member#: 313456
2003 WRX Wagon
Thanks for posting this, good info for those of us about to start a hybrid project.
Nuul is offline   Reply With Quote
Old 06-01-2012, 01:55 PM   #27
KpT KiM
Member#: 242422
Originally Posted by Jirv311 View Post
So if stock STi compression is 8.2:1 and I use 8.5:1 pistons with 02 WRX heads undecked, stock STi head gaskets, what CR am I looking at? I've heard with stock STi pistons (at 8.2:1) it's around 8.96:1-ish so would 9.26:1 sound about right?
Probably around there. The big problem with a 257 block and 205 heads is not the higher CR IMO, but the weird knock issues you run into as the 205 combustion chambers are not designed for the 257 pistons. Homemade WRX brought up the point that custom pistons designed for the 205 combustion chambers should work, but I don't know of anyone that's tried it yet.
KpT KiM is offline   Reply With Quote
Old 06-01-2012, 07:19 PM   #28
Jirv311
Member#: 273528
2002 Impreza WRX
I think the knock issues probably come more from the sharp edges of the combustion chambers and are more prominent due to their position within the cylinder on a hybrid. I'll be rounding mine out.
Jirv311 is offline   Reply With Quote
Old 06-01-2012, 07:47 PM   #29
J_Baker
Member#: 309434
06/9 WRBSTI/SRR2.5i
shop slut/5sp beater
I'd seriously consider cnc work on the heads. Any unevenness will create hot spots, and minor differences between cylinders is problematic as well. Another thing to keep in mind is the quench surface dimensions and difference between 92mm and 99.5 mm piston quench area.
J_Baker is offline   Reply With Quote
Old 06-01-2012, 07:49 PM   #30
wrxkid2003
Member#: 228945
2003 WRX
Let me know how that works i bet if you take your 257 head gasket and lay on the heads and scribe a line you could carefully smooth out the sharp edges of the mismatch and be ok.
I work in a CNC shop so when i get to doing my build i am going to mill out the sides of the head where the gasket lines up to and make it close to the 257 heads. if i get crazy i will make up a plexi glass head chamber tester to see what the CC's are.
And I would say you would be safe with running 8.5:1 pistons or 9.0:1 if you are going to smooth out and remove some material on the heads. i read that a 257 block with 205 heads is more like 8.8:1 so with 8.5:1 pistons you would be like 9.1:1 which would be good. remember factory subarus run very low cr for being turbo and as others have said they run 9.5:1 and love it probalby give more low end power.
wrxkid2003 is offline   Reply With Quote
Old 06-01-2012, 08:39 PM   #31
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
My last hybrid motor was a basic 257 SB with my shops custom Wiseco pistons and the CR was 8.5:1 with WRX heads. I did have cams which lower your effective CR and the combustion chambers, valve faces, and exhaust ports where ceramic coated. On 91 California octane I had no knock issues, made great power, and the car was the smoothest revving Subaru engine I personally have ever driven.
That same engine is in my STi currently just waiting for my turbo so I can get the car running. The only difference this time around is the heads aren't ceramic coated this time. Will I be more prone to knock now? Probably just not sure by how much, I'll report back for a comparative data point.
Those who have been around have been running hybrids for some time know that there are more than one way to skin a cat and while the combustion chamber mod is good and does work there are also other effective ways to get a great running hybrid.
Old 06-02-2012, 02:11 AM   #32
Jirv311
Member#: 273528
2002 Impreza WRX
Low end is definitely something I'm hoping for on this one. It's a bit pathetic how weak the 2.0 is by itself right now.
I'll throw some pictures up once I clean up the heads and we'll see how it works.
Old 06-12-2012, 05:10 PM   #33
swagwag92
Member#: 260858
0102 01 OBS
02wagon #bigturbo#cam'd
i had a pnp'd sti heads with 272s springs valves and retainers in my car but recently removed them so i could daily the car now so im putting 02 wrx heads on a fully built ej257 bottom end, timing setup is from an 02 wrx, heads are stock. ill be firing the car up for the first time on friday after school lets hope all goes well haha
swagwag92 is offline   Reply With Quote
Old 06-12-2012, 05:41 PM   #34
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Why couldn't you DD the car with the 272s in it?
Old 06-12-2012, 06:20 PM   #35
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
^Bad tune maybe?... 272's are perfectly streetable.
TDagen is offline   Reply With Quote
Old 06-12-2012, 07:16 PM   #36
swagwag92
Member#: 260858
0102 01 OBS
not that the tune was bad but the car wasnt the best on gas...especially in boost which you cant help but hit lol, i actually have the heads forsale now if you huys know anyone thats interested. i really need some cash as well
Old 06-12-2012, 11:05 PM   #37
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
that's not the cam's fault, that's you. lol your right foot determines how much gas the engine is going to suck up.
FuJi K is online now   Reply With Quote
Old 06-13-2012, 10:16 AM   #38
Samurai Jack
Member#: 21145
2002 Enemy of Aku
subscribe
Samurai Jack is offline   Reply With Quote
Old 06-13-2012, 10:56 AM   #39
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Originally Posted by ronzogonzo View Post
2L heads use 2L plugs
-Phil
...And if your ej205 heads are cut to match the ej255 combustion chambers...you still use spark plugs from the ej205.
Just in case anyone wanted to know.
Squidz is offline   Reply With Quote
Old 07-07-2012, 07:25 PM   #40
Jirv311
Member#: 273528
2002 Impreza WRX
Quick question about my build. I'm moving to the 06 STi oil pan and pickup and wondering if I have to use the STi windage tray or can I still use my 02 WRX one?
Old 07-08-2012, 10:56 AM   #41
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I actually went with the Killer B windage tray, it's a really nice piece for a reasonable cost. I'd go that route personally.
I just finished putting about 3k on my new hybrid build, and it's been fantastic. Doesn't burn a drop of oil, it's quiet, and makes good power. I'm running:
09 EJ255 LGT block, 99.75mm Mahle 4032 pistons, ACL bearings, Eagle rods, STi nitrided crank, CnC'd 205 heads done by ASF machine, stock STi HGs, and a VF34. It's a fun DD!
03SubyWRX is offline   Reply With Quote
Old 07-08-2012, 12:31 PM   #42
lohr700
Member#: 300583
2002 WRX Hybrid
That build does seem fun!! Very close to what I'm currently building (except a 05 STi block and a precision 5858)
What power do you put down? Are you in the power band or top end? Either way... watch out for those pestering po-po!!
lohr700 is offline   Reply With Quote
Old 07-09-2012, 07:20 PM   #43
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You could use your '02 WRX one, but the '02 WRX windage tray is very restrictive. Oil doesn't return to the pan quickly.
The KillerB version is only ~$70 and will let oil flow back the pan quickly, which is the way it was deliberately designed.
Old 07-16-2012, 07:35 AM   #44
triniscoob
Member#: 143225
2004 JDM Sti
Ok, i realised that there are 2 different Front 02 sensors, theres one for the JDM 207 and then theres a different one for the US ej257.
AFter having rebuilt my ej207 using a the 257 bottom end, with my jdm heads, im now wondering which 02 sensor to USe.
Do i go with the 2.0jdm sensor (22641AA042) or do i use the 2.5US sensor (22641AA211), i have been having idling issues and was wondering if this could be the ONE of the causes.
Any thoughts?
triniscoob is offline   Reply With Quote
Old 07-16-2012, 08:01 AM   #45
kellygnsd
Member#: 32669
LINK G4 hybrid STi
It all depends what ecu and wire harness you have. The engine/head combo matters not.
Old 07-16-2012, 08:18 AM   #46
triniscoob
Member#: 143225
2004 JDM Sti
still running my stock 2004 jdm ECU, i had a ej207 in there and simply swapped out the bottom end for an ej257 with forged pistons.
Old 07-16-2012, 09:39 AM   #47
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You need the jdm sensor. If that's the one you have maybe your idle problems are tune related
Old 11-24-2012, 10:22 PM   #48
. o 69 o .
Member#: 124938
i was looking for a ej257 short block and found a complete longblock for a good price. it has single avcs. so is it possible to still use these heads and maybe change out the cams for non avcs 2.5L cams? or would it be best to just part the heads complete, cnc the 2L heads and get somethign like a Crower 272 for a 2L
. o 69 o . is offline   Reply With Quote
Old 11-24-2012, 11:32 PM   #49
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Run as is without AVCS
Old 11-25-2012, 11:43 AM   #50
. o 69 o .
Member#: 124938
i was told that wouldnt work..hmmm
WTB 2.5l Shortblock or 2.0 Longblock 97gtguy Private 'Wanted' Classifieds 54 02-15-2010 12:27 PM
2.0L to 2.5L Shortblock Build/ Turbo Options? csmithwrx'05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-08-2008 10:50 AM
wtb 2.5 shortblock & 2.2 heads kylemcspecial RMIC Private Classifieds 0 06-20-2006 01:59 PM
jdm sti v8 2.0l or usdm 2.5l shortblock? WSSBOARD18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 03-06-2005 03:48 PM
STI 2,0L vs STI 2,5L shortblock - need help calvin434 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-30-2005 10:02 AM
