Old 10-02-2013, 05:49 PM   #3976
Wirtz
Member#: 286408
WFC #952
Function:error!
Originally Posted by subie_riegs View Post
LOL all you have to do is post wheel specs for people to notice you're interested in xxr nowadays
Reasons not to go with xxr besides them being under a grand?
And they're not high quality cast wheels aka easy to bend on the wrong hole. My outer lip has two small bends on my varrstoens which are even better quality by most people's standards.
And yes tuck your harnesses people znoblebb mentioned but it pretty much cost me my motor, well at least the heads. TGV motor got fried, throttle position sensor, and an injector all lost power and fried my exhaust valves to ****
Wirtz is offline   Reply With Quote
Old 10-02-2013, 08:01 PM   #3977
05subysti
Member#: 268190
2005 STi
Originally Posted by flat4LGT View Post
How have you guys gone about tucking the wiring harness? Just zip tie it out of the way or something else?
I used some heavy duty zip ties, recommend also uses c or p style clamps mounted to the car instead which looks more professional.
Will redo mine when I do a wire tuck.
05subysti is offline   Reply With Quote
Old 10-02-2013, 09:05 PM   #3978
flatbooost
Member#: 310076
2004 STi
BC BR extreme low, swifts
RPF1 18x10 +38
flatbooost is offline   Reply With Quote
Old 10-02-2013, 09:30 PM   #3979
j2nicee
Member#: 354827
2006 STI
BBC
[quote=flatbooost;40700826]BC BR extreme low, swifts
RPF1 18x10 +38
Just put the same setup on, is your ride pretty stiff?
j2nicee is offline   Reply With Quote
Old 10-02-2013, 09:34 PM   #3980
deezu1
Member#: 369925
not my car, but its in my area, and its pretty sick..
deezu1 is offline   Reply With Quote
Old 10-02-2013, 10:08 PM   #3981
flatbooost
Member#: 310076
2004 STi
[quote=j2nicee;40700958]
RPF1 18x10 +38
My spring rates are 10k/8k. dampners set to about 24F 18R.. its not terrible by any means but def stiff. However it rides wayy better than the normal BRs on full stiff..
Old 10-03-2013, 09:56 PM   #3982
j2nicee
Member#: 354827
2006 STI
BBC
I hear you, mine are at 12k and its bumpy, might raise it up a lil bit.
Old 10-04-2013, 03:13 AM   #3983
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
RPF1 18x10 +38
Love it! Very clean.
2.5L Monster is offline   Reply With Quote
Old 10-04-2013, 06:21 AM   #3984
joSTIzel
Member#: 157787
04 WRX STi 411/420
Indeed
joSTIzel is offline   Reply With Quote
Old 10-04-2013, 09:17 AM   #3985
Silver Sedan
Member#: 259220
2005 RWD STi
Still love this set of photos. Diggin' through the archives.
Silver Sedan is offline   Reply With Quote
Old 10-04-2013, 09:46 AM   #3986
amiglierina
Member#: 321466
2008 subaru impreza
Your NASIOC Administrator
First static set up more to come next summer.. i'm currently on 18x9 +35 do you think if i manage to find some smaller tire than my 225/40 i can manage to drop more my car and be more aggressive.
amiglierina is offline   Reply With Quote
Old 10-04-2013, 10:55 AM   #3987
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Originally Posted by amiglierina View Post
First static set up more to come next summer... i'm currently on 18x9 +35 do you think if i manage to find some smaller tire than my 225/40 i can manage to drop more my car and be more aggressive.
Put some 215/40 or 205/40 on there and you'll definitely be able go lower.
Slow Scoobie is offline   Reply With Quote
Old 10-04-2013, 11:00 AM   #3988
i50caL
Member#: 94899
91 GTR, 75 S30Z,
97 STI, EVO X?
Originally Posted by azn2nr View Post
Sell me these...
i50caL is offline   Reply With Quote
Old 10-04-2013, 11:41 AM   #3989
[JT]
Member#: 218435
2001 18g'd Rs Coupe
2 doors less whores
What are you guys doing for an exhaust? I'm planning on dropping my gf wagon alot this spring, but the 3 inch piping (swapped) is already pretty low to the ground. Granted i still need short exhaust hangers but still, I feel like that's not going to be enough.
[JT] is offline   Reply With Quote
Old 10-04-2013, 12:06 PM   #3990
Sato_unit
Member#: 230417
No exhaust modifications
Sato_unit is offline   Reply With Quote
Old 10-04-2013, 12:20 PM   #3991
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
^that
No modifications, it just scrapes on occasion when I go over speed bumps. I'm never going fast enough over bumps to cause any damage.
flat4LGT is offline   Reply With Quote
Old 10-04-2013, 09:37 PM   #3992
[JT]
Member#: 218435
2001 18g'd Rs Coupe
2 doors less whores
Ok then. Hopefully the hangers will do the trick.
Old 10-05-2013, 04:47 PM   #3993
Joes scooby
Member#: 320839
2006 wrs sti
obsidian black pearl
This is my 06 sti on ssr ms3 18x10 +29 tucking 245/35 tires. Enjoy!
[IMG][/IMG]
Joes scooby is offline   Reply With Quote
Old 10-05-2013, 07:07 PM   #3994
mattyl526
Member#: 198404
WFC #391
S2000
That looks great. I'm contemplating on a meaty setup for next year as well
mattyl526 is offline   Reply With Quote
Old 10-06-2013, 05:25 PM   #3995
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
My front wheels both had some toe out so I adjusted the tie rods till both wheels looked pretty straight. Problem is prior to the adjustments I had minimal rubbing however now I have lots of rubbing what gives?
edit Turns out somehow changing my toe lowered my car a bit more and now my axle hits the frame. Anyone know what a safe distance from axle to frame is? I know it can vary depending on how stiff your suspension is but just as a rule of thumb. Trying to avoid notching
Old 10-06-2013, 05:52 PM   #3996
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
ocdpvw is offline   Reply With Quote
Old 10-07-2013, 01:40 AM   #3997
Silver Sedan
Member#: 259220
2005 RWD STi
Old 10-07-2013, 10:57 AM   #3998
Jacobs11
Member#: 268948
04 WRX
PSM Sold :(
RPF1 18x10 +38
My new wallpaper thanks for that!
Jacobs11 is offline   Reply With Quote
Old 10-10-2013, 03:02 PM   #3999
WreaKLoosE
Member#: 165300
2006 WRX
Steel Gray Met.
Originally Posted by Wirtz View Post
Can I play? I'm back but my Varrstoens are two tone black (satin and gloss). Same 245/35. Missing my wheel bolts and center cap. Powdercoater left them at his house lol. Rear needs a tweak before I match this.
How did you get the (studs) out??? they dont push out from the back and they are kind of glued in.. I have the same wheels on my RX8 im going to have powder coated the same way..
19x9.5+12 and +22
I will be doing the same for my linea Corse for my soob booby...
WreaKLoosE is offline   Reply With Quote
Old 10-13-2013, 09:11 AM   #4000
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Why not notch? I literally just let mine rub the frame until it rubbed a nice notch in it
under0athh51189 is offline   Reply With Quote
The "My Lunch Could Beat Up Your Lunch" Thread markman Off-Topic 766 07-14-2016 01:44 PM
Pare it down or beef it up? AVANTI R5 Non-Subaru News & Rumors 2 05-03-2012 02:01 PM
B6D Wrap It Up and Photo Thread I25 Off-Topic 1051 07-06-2010 02:50 PM
Is it bump your own thread day... allanak Off-Topic 12 02-11-2009 05:29 PM
Post pics of Rota Attacks on your WRX Here! wrx.jeus Brakes, Steering & Suspension 1 09-04-2002 02:20 PM
