Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 07-23-2014, 02:24 PM   #5076
Wirtz
Member#: 286408
WFC #952
Function:error!
Originally Posted by Zach Bitzer View Post
Guys with the 05's. What tire/wheel size are you running in the front? Seems like most of you are just getting away with a roll and no pull. I'm running 225/40/18 on my s4, and my fronts needed quite a bit of work with +25. 18x9.5. I keep going back and fourth on doing an 05. Just curious what you guys are getting away with. Air or static.
I recommend 35 series after seeing a 9.5 setup on 245/35 steer easier with the ability to go lower than a 235/40.
Mine aren't pulled for say to where they flare but I definitely have them rolled out a bit and flat. I'm at 10 +16 on a 245/35 at -4 degrees in front. I barely touch a fender on one side and that one rubs on hard bumps. Other side is good and doesn't even fit a finger
Wirtz is offline   Reply With Quote
Old 07-23-2014, 10:06 PM   #5077
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
My fronts are rolled almost flat with about -1.5 camber. I'm running a 225/40 tire with +22 9.5" wheel.
Supa LA is offline   Reply With Quote
Old 07-24-2014, 12:12 AM   #5078
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
Must not be tuckin then. Like I said all depends on how low you wanna go
under0athh51189 is offline   Reply With Quote
Old 07-24-2014, 03:07 AM   #5079
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
The tires are slightly tucked, but it can go lower (I think) my coils are basically maxed unless I wanna hit the boot. I need to harass Wirtz some more to see how he remedied the situation since we have the same brand. Unless anyone else wants to chime in?
Old 07-24-2014, 03:28 AM   #5080
under0athh51189
Member#: 193959
2001 Lexus IS300
Shorter springs up front. That's how fixed mine. And to tuck hard you will need alot more camber than -1.5 I tuck to rim lip and im at -5.5f -6.8r with a decent pull all around and im running a 215/40 on a 18 x9.5 +13. I could get away with less camber but don't wanna rub paint it rim lip with how low I am.
Old 07-24-2014, 07:11 AM   #5081
Wirtz
Member#: 286408
WFC #952
Function:error!
Robb nailed it. I have shorter front springs on my coils
Old 07-24-2014, 05:47 PM   #5082
taiekchi
Member#: 130038
2004 Impreza WRX
taiekchi is offline   Reply With Quote
Old 07-24-2014, 06:42 PM   #5083
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Obsidian Black Pearl
Quick question and I've been looking but this offset is not too common I guess? 17x9et30 on a 04 sedan. 235 or 245/40 is the tire I'm between. I'm going to be putting coilovers in it, but rolling rears I'm pretty sure... Anything else?
Sent from my SM-N900V using NASIOC mobile app
Sexyrexy1990 is offline   Reply With Quote
Old 07-24-2014, 07:01 PM   #5084
IllwaukeeNA2.5
Member#: 330830
2010 Impreza2.5i 5dr
Roll your fronts as well. Better to have them done than to damage them and then get them rolled (my experience) and then this happens
IllwaukeeNA2.5 is offline   Reply With Quote
Old 07-24-2014, 07:02 PM   #5085
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
So just rolling should do me for this setup
Old 07-24-2014, 07:03 PM   #5086
Supa LA
Member#: 344540
2015 Mustang 5.0
Guard Metallic
Ya I'm not trying to touch lip to fender. However, I do want to tuck more tire. I'm fully prepared to dial in a Lil more negative camber up front, just not another 5 lol. My fronts aren't even pulled much.
Shorter springs will have to be the route I take tho. I'm not satisfied with the height in front. Thanks for the info.
Old 07-25-2014, 12:46 AM   #5087
under0athh51189
Member#: 193959
2001 Lexus IS300
Np man. Enjoy
Old 07-25-2014, 08:06 PM   #5088
theboucher
Member#: 281906
2004 WRX
theboucher is offline   Reply With Quote
Old 07-28-2014, 10:58 AM   #5089
GarrettKing
Member#: 234802
95 Imreza L
Glacier White
GarrettKing is offline   Reply With Quote
Old 07-28-2014, 12:31 PM   #5090
Wirtz
Member#: 286408
WFC #952
Function:error!
You're gonna need a roll all around for sure and camber. Don't think you searched hard at all my old posts of my 17x9 +30 setup along with grippymonkey's old posts too encompassed this setup. You're not gonna want a fat ass tire like 235 or 245 unless you're looking at tucking tire and having a functional stance because my oem 225/45 were meaty on the rear. Fronts were no issue at -1.5 but rear needed roll and around -3 unless you start pulling.
Hope that helps and keep this stuff to the wheel and tire sticky please
Old 07-28-2014, 05:10 PM   #5091
Wirtz
Member#: 286408
WFC #952
Function:error!
On topic
Old 07-28-2014, 05:14 PM   #5092
IllwaukeeNA2.5
Member#: 330830
Originally Posted by Wirtz View Post
On topic
Oh look, it's the StanceNation famous Instagram guy
Old 07-28-2014, 05:26 PM   #5093
Sato_unit
Member#: 230417
I think this thread is only at the top cause of your Wirtz. LOL
Sato_unit is offline   Reply With Quote
Old 07-28-2014, 05:30 PM   #5094
Wirtz
Member#: 286408
WFC #952
Function:error!
Yeah.....okay. Don't give a crap lol
Old 07-29-2014, 01:23 AM   #5095
Sato_unit
Member#: 230417
lol all i ever see is your car !!!
Old 07-29-2014, 08:42 AM   #5096
Wirtz
Member#: 286408
WFC #952
Function:error!
Why don't you post yours then :P
Old 07-30-2014, 12:36 AM   #5097
Ferg
Gung-ho Iguana
Member#: 14145
'02 WRX
'10 4Runner
Ferg is offline   Reply With Quote
Old 07-30-2014, 02:27 PM   #5098
Sato_unit
Member#: 230417
Originally Posted by Ferg View Post
WINNER WINNER CHICKEN DINNER!!!!!!!!!!!
Old 07-30-2014, 02:38 PM   #5099
Oaf02Z
Member#: 263219
2012 STI sedan
Plasma Blue Pearl
ill post one. cant go lower until i cut more fender. (wheels are up for trade)
Oaf02Z is offline   Reply With Quote
Old 07-30-2014, 02:50 PM   #5100
fear_noEVO
Member#: 193654
'09 FXT Limited
'07 LGT Spec B
Aaron your car looks so badass! I'm debating putting the rpf1s on the Saab.
fear_noEVO is online now   Reply With Quote
The "My Lunch Could Beat Up Your Lunch" Thread markman Off-Topic 669 01-30-2015 02:48 PM
Pare it down or beef it up? AVANTI R5 Non-Subaru News & Rumors 2 05-03-2012 03:01 PM
B6D Wrap It Up and Photo Thread I25 Off-Topic 1051 07-06-2010 03:50 PM
Is it bump your own thread day... allanak Off-Topic 12 02-11-2009 06:29 PM
Post pics of Rota Attacks on your WRX Here! wrx.jeus Brakes, Steering & Suspension 1 09-04-2002 03:20 PM
