Old 07-30-2014, 02:31 PM   #5101
Oaf02Z
Member#: 263219
2010 Mugen GE8 Fit
2012 Flared STI (SOLD)
thanks man! put them on! that would look sick!
Oaf02Z is offline   Reply With Quote
Old 07-30-2014, 02:41 PM   #5102
fear_noEVO
Member#: 193654
'09 FXT Limited
'07 LGT Spec B
I did a test fit and they look nasty! I'll be putting pics up if I do
fear_noEVO is offline   Reply With Quote
Old 07-30-2014, 05:42 PM   #5103
Sexyrexy1990
Member#: 395644
2004 Impreza WRX
Obsidian Black Pearl
Originally Posted by Wirtz View Post
You're gonna need a roll all around for sure and camber. Don't think you searched hard at all my old posts of my 17x9 +30 setup along with grippymonkey's old posts too encompassed this setup. You're not gonna want a fat ass tire like 235 or 245 unless you're looking at tucking tire and having a functional stance because my oem 225/45 were meaty on the rear. Fronts were no issue at -1.5 but rear needed roll and around -3 unless you start pulling.
Hope that helps and keep this stuff to the wheel and tire sticky please
Thanks. My bad on the post. New to the whole online forum deal. And I never search on my Computer. (probably my problem I know) I'll take a look through and see what all you mentioned. I'll be back posting pics though. New te37v going on here in a week or two
Sexyrexy1990 is offline   Reply With Quote
Old 07-31-2014, 01:14 AM   #5104
.clipse
Member#: 212265
2013 Legacy
do legacy's count
.clipse is offline   Reply With Quote
Old 07-31-2014, 02:40 AM   #5105
Oaf02Z
Member#: 263219
2010 Mugen GE8 Fit
That's sexy
Old 07-31-2014, 09:00 AM   #5106
Digitalwave
Member#: 321857
Sick!
Digitalwave is offline   Reply With Quote
Old 07-31-2014, 10:39 AM   #5107
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
Originally Posted by .clipse View Post
do legacy's count
Anymore pics? Looks great!
BLkdubRX is offline   Reply With Quote
Old 07-31-2014, 10:59 AM   #5108
.clipse
Member#: 212265
2013 Legacy
thanks guys
will post some up when i take more
Old 08-01-2014, 02:04 PM   #5109
veryslow-_-
Member#: 352788
2002 Impreza WRX
went back to stock wheels with 25mm spacer
[IMG][/IMG]
[IMG][/IMG]
veryslow-_- is offline   Reply With Quote
Old 08-01-2014, 02:34 PM   #5110
RJSMITH
Member#: 347474
2002 wrx,01 L coupe
mbp,sr
not really stock wheels but i am a sucker for sti bbs wheels on bugeyes looks clean wish u had a lil more tire for a functional fitment
RJSMITH is offline   Reply With Quote
Old 08-01-2014, 02:34 PM   #5111
avidworks
Member#: 144415
That looks so good.
avidworks is offline   Reply With Quote
Old 08-01-2014, 06:58 PM   #5112
Wirtz
Member#: 286408
WFC #952
Function:error!
That looks amazing slammed on it's nuts
Wirtz is offline   Reply With Quote
Old 08-01-2014, 08:31 PM   #5113
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
bugeye105 is offline   Reply With Quote
Old 08-01-2014, 11:36 PM   #5114
ryce84
Member#: 210466
2005 STI
Default the S-word, the F-word, the other S-word, post pics or stick it up your A-wor...
Can I play?
ryce84 is offline   Reply With Quote
Old 08-02-2014, 08:00 AM   #5115
celosteelo
Member#: 80062
06 STi
^tasty!
celosteelo is offline   Reply With Quote
Old 08-02-2014, 02:24 PM   #5116
CarverSnell
Member#: 256218
2004 Impreza WRX
FP Black, 380whp
Not nearly as nice as half of the stuff in here but whatever. lol
CarverSnell is offline   Reply With Quote
Old 08-02-2014, 03:52 PM   #5117
Digitalwave
Member#: 321857
Old 08-02-2014, 08:18 PM   #5118
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Need some wider wheels to get it down perfectly, but getting there
Smurftastic is offline   Reply With Quote
Old 08-02-2014, 08:53 PM   #5119
avidworks
Member#: 144415
This setup is turning out to be a pain in the ass. First I didn't have enough camber and it rubbed everywhere, now the rears have too much and the fronts still rub bad around turns, even after a decent pull front and rear.
Going to order rear camber plates so I can dial that in (I only have bolts now and it's such a pain trying to adjust) and hopefully turning up the damping will help the rubbing in the front (still 8k/6k springs). They're 18x9.5 +38 with 245/40/18 and 12mm spacers (I have ARP studs and my lugs won't tighten without the spacers).
Old 08-02-2014, 09:02 PM   #5120
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
Open ended lugs my friend.
Old 08-02-2014, 09:06 PM   #5121
avidworks
Member#: 144415
They are. The problem is, the locking lug socket that comes with Project Kics lug nuts is way too short and gets stopped by the wheel stud. I either have to run spacers (which I don't mind) or drill through an inch of steel.
Old 08-03-2014, 01:08 AM   #5122
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
recent shot i took
under0athh51189 is offline   Reply With Quote
Old 08-03-2014, 05:24 AM   #5123
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
Fat Black Pig Sac is offline   Reply With Quote
Old 08-03-2014, 12:07 PM   #5124
Nguyener
Member#: 267667
2007 STi
2012 S4
You're probably rubbing on the inner fender like crazy in the front with those tires. Only thing that'll help is either tubbing or smaller tires. I know my rubbing didn't stop in the front until I switched to 215/35
Nguyener is offline   Reply With Quote
Old 08-03-2014, 12:14 PM   #5125
avidworks
Member#: 144415
I'll have to double check that. There were wear marks on the inside but I assumed they were old, etc since I've barely driven the car with the new ones on... It sounded more like it was hitting the outside fender but that's entirely a possibility. It's mostly around uneven pavement with the wheels turned or when turning at decent speed, i.e. on-ramps. I've already cut the upper part of the fender liner, tucked the harness up and flattened some of the seams, but maybe I need to take a torch and a big hammer to the inner tub...
The tires are definitely an issue, especially since they're an inch taller than stock and I didn't raise the car at all. I might cave and do a 225/40 or something. Blah.
The "My Lunch Could Beat Up Your Lunch" Thread markman Off-Topic 766 07-14-2016 01:44 PM
Pare it down or beef it up? AVANTI R5 Non-Subaru News & Rumors 2 05-03-2012 02:01 PM
B6D Wrap It Up and Photo Thread I25 Off-Topic 1051 07-06-2010 02:50 PM
Is it bump your own thread day... allanak Off-Topic 12 02-11-2009 05:29 PM
Post pics of Rota Attacks on your WRX Here! wrx.jeus Brakes, Steering & Suspension 1 09-04-2002 02:20 PM
