Old 05-28-2012, 01:15 AM   #1
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Need help finding what line goes to the metal nipple coming off the front of the turbo on my ej20g I looked everywhere but cannot find what hose to connect to it. It is the one that pushes air out of it. anyone have an idea?
http://s1243.photobucket.com/albums/...nt=image-2.jpg
Thanks
Bfooool is offline   Reply With Quote
Old 05-28-2012, 08:34 AM   #2
luka
Member#: 194742
1993 Impreza WRX JDM
top nipple on your coolant reservoir.
luka is offline   Reply With Quote
Old 05-28-2012, 11:54 AM   #3
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
No on the turbo
Old 05-28-2012, 05:06 PM   #4
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Sounds like its the hose that goes to your boost controller. If you were to hook it up directly to your wastegate actuator it would boost whatever spring pressure is.
super_usdm is offline   Reply With Quote
Old 05-28-2012, 06:19 PM   #5
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
I don't have a boost controller though?
Old 05-29-2012, 10:39 AM   #6
Aphex28
Member#: 11506
2015 WRX
boost control solenoid located on the passenger strut tower if it was ever put on.
Aphex28 is offline   Reply With Quote
Old 05-29-2012, 01:34 PM   #7
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Old 05-29-2012, 02:18 PM   #8
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
I take it you're not driving the car yet?
Yes that hose needs to go to either:
Wastegate actuator on turbo
Boost controller- manual or electronic
External wastegate
Old 05-29-2012, 02:44 PM   #9
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
I have driven the car very little about ten miles I can't seem to find the hose to connect to it I've looked everywhere is it possible I have it hooked up somewhere else?
Old 05-29-2012, 02:57 PM   #10
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
The hose may be missing. Find a flexible rubber hose that fits the nipple and hook it up to one of the 3 I mentioned above. Most likely the stock electronic boost control solenoid. Search it to see what it looks like and where it is.
Old 05-29-2012, 03:32 PM   #11
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
It goes to the boost control solenoid located on the right side strut tower. It is the hose marked "to compressor housing outlet" in the picture.
rob is offline   Reply With Quote
Old 05-29-2012, 03:46 PM   #12
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Ok I'll try to do that thanks I'll let you know if I need more help
Old 05-29-2012, 03:56 PM   #13
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Ok I have that hose hooked up here
http://s1243.photobucket.com/albums/...nt=image-3.jpg
What do I hook up to this after I take it off and put it on the turbo? The charcoal canister?
Old 05-29-2012, 04:04 PM   #14
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
That picture is useless without an arrow or something.
Paste the pic to paint and circle the hose connection. You should probably take a better pic too, the angle of the camera makes me think you are not even close to the boost solenoid.
Old 05-29-2012, 04:27 PM   #15
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
I can't paint a circle on my phone but I took a better pic pointing at it here it is
http://s1243.photobucket.com/albums/...nt=image-4.jpg
I now have this hooked up to the charcoal canister hope it's right
Old 05-29-2012, 04:28 PM   #16
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Old 05-29-2012, 05:23 PM   #17
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
It looks like you have that hose hooked up to your coolant reservoir. If so, do not turn the car on!
Old 05-29-2012, 05:25 PM   #18
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
The first thing you need to do is find this guy....
Old 05-29-2012, 05:33 PM   #19
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Wow I'm so dumb I need to figure this out
Old 05-29-2012, 08:01 PM   #20
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Bump anyone know If this is right?
Old 05-29-2012, 11:22 PM   #21
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
It's hooked up to the metal hose under it? There are two of them one small and one that is bigger?
Old 05-29-2012, 11:30 PM   #22
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
I sucked on the hose coming off it and it tastes like fuel hah I think it's right but would be at ease with some feedback
Old 05-29-2012, 11:46 PM   #23
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Only air should flow through that line. Did you find the boost solenoid yet?
Old 05-30-2012, 12:00 AM   #24
Bfooool
Member#: 226567
1993 1994 wrx
PPG Super White
Ya I got that all squared away but I was confused on the charcoal canister but that hooks up to the two metal lines under the coolant resivoir right? there lines that the fuel vapors go through into the canister?
Old 05-30-2012, 10:42 AM   #25
Aphex28
Member#: 11506
2015 WRX
Your posts are un-intelligible. You're making it seem like you hooked up the compressor nipple of the turbo to the charcoal cannister.
The charcoal canister is pretty much unrelated to the boost control system.
It's part of the evap system and should be on the vaccum/evap line of the fuel lines.
What are you trying to say?
Water Hose Tank to Turbo hose size burtonboarder230 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-18-2010 04:45 PM
sri hose to turbo hose connector jdgrimm General Community 2 05-17-2006 02:59 PM
02 WRX:need a stock IC to turbo hose and BOV hose Wazoo Racing New England Impreza Club Forum -- NESIC 3 03-14-2005 11:03 PM
restricted turbo hose subarud Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-16-2001 08:59 PM
turbo hoses subarud Newbies & FAQs 2 11-15-2001 11:33 PM
