Old 05-28-2012, 12:17 PM   #1
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Red
Default Jdm Ej20G thrust 3 toasted,Tiger japan beware
Well this is just a heads up,thanks to Tiger Japanese Auto Parts Ltd my Jdm EJ20G thrust bearing is toast
Bought the motor it was not what I ask for they lied told them to take it back ,they never did so after 2 week I went ahead and use the block ,I should have known something was wrong when I got it tune at only 2000 miles,the clutch was hard on take off and then soft on slowing down like if there was air in the clutch cylinder (so I taught) well it was the thrust bearing# 3 gone bad back and forth play of .200 that's why they did not take the motor back it was bad motor to begin with,its not a daily and i only put 4000 miles on this jdm block.
I will be selling the block ,rings and more that I will not be used ,here are some pics of the thrust #3 .
DONT buy from Tiger Japanese you have been warned.
trinistyles is offline   Reply With Quote
Old 05-28-2012, 12:37 PM   #2
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Red
And yah the crank is shot
Old 05-28-2012, 12:56 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
Another board I am on claims that these engines come from tsunami cars. Osaka, Tiger, Jdmenginedepot.
That is why they are 5-1000 cheaper than all the other vendors
eg33GC is offline   Reply With Quote
Old 05-29-2012, 01:39 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Why not rebuild it properly? Good used cranks are widely available in the US.
Marnix is offline   Reply With Quote
Old 05-29-2012, 04:49 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yeah, just grab a 1.8 or 2.2 used crank and some new bearings and your done. No machine work needed.
Old 05-29-2012, 08:40 PM   #6
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Red
2 of the cylinders has lines for piston skirt and all 4 bores are on the high limit,so the block will have to be bored out and honed,alone with new pistons,rings,Acl main bearing,Acl connecting rod bearing=$$$$$
So I well just rebuilt the Ej205 Usdm block which will cost much less to rebuild that I had up for sale,thanks for your input guys.
Old 05-30-2012, 08:35 AM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
There is no difference in rebuid cost for a center thrust crank block or a later rear thrust crank block....
Old 05-30-2012, 10:35 PM   #8
trinistyles
Member#: 71627
180 Wrx/Fozzy/OBS
DGM/DGM/Red
Marnix I do know that the main bearing for thrust 3 and 5 cost the same,I am rebuilding the Usdm only cause I dont have to have the regrind the crankshaft nor do I have to get pistons and bore + hone the cylinders.
Old 05-31-2012, 04:20 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Ok
EJ20G HUGE TMIC Custom made to fit on your JDM EJ20g apoopoo999 Engine/Power/Exhaust 0 01-08-2008 01:19 PM
FS: NYC: JDM Legacy BE sedan spring Daytona Japan andivic Legacy Specific Parts 1 04-06-2007 08:45 PM
were to get ej20g parts and don't say japan scobaru Subaru Conversions 7 02-06-2004 09:23 AM
JDM parts for Sale straight from Japan holmskillt Private 'For Sale' Classifieds 42 09-29-2003 08:11 AM
Spotted (Warning: Big 3 content - haters beware!) Elwood Mid West Subaru Owners Club Forum -- MWSOC 5 09-01-2003 11:01 PM
