Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 05-28-2012, 06:32 PM   #1
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
Default Need a sealant on headlight restoration?
Looking to do a headlight restore even though my headlights are fine. Just got a slight haze over it so I wanna make it clear as possible. When I buff the headlights should I worry about putting some sort of sealant on the lights since there is a lot of heat generated there? ( running 55w HID's) Some say to do it and some say don't
dumpstercrusher is offline   Reply With Quote
Old 05-28-2012, 06:45 PM   #2
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
polish them with an orbital and a fine wax... they will look good but once the wax wears off you will have to do it again and again and again...
_______
a long lasting solution:
wet sand the old stuff off the head light. use more rough grit and slowly work your way down to 3000 grit.
clean the headlight with a good cleaner that doesnt leave residue
take a foam brush and brush a light coat of CLEAR exterior polyurethane over the head light
let the lights dry for several hours. The streaks created from the foam brush will settle and your light will look brand new... Ive done this tons of times and all cars look new
All4bSpinnin is offline   Reply With Quote
Old 05-28-2012, 08:53 PM   #3
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Those headlight restoration kits don't have that Clear exterior polyurethane, right? I would have to buy that as a separate thing? Also Im guessing 1000 grit paper is thicker and rougher than 3000 grit?
Old 05-28-2012, 10:51 PM   #4
Jdub.csu
Member#: 283784
2013 EVO X GSR
I took the best solution and added to it basically what we do at the shop.
wet sand the old stuff off the head light. use 600 grit and slowly work your way to 1000 grit.
Best practice is to use an air powered disk because it speeds things up
clean the headlight with a good cleaner that doesn't leave residue (denatured alcohol)
Then spray with renulight and back under the sun. Will look brand new. We do this at the shop and get payed 100 to do it. Works great.
Jdub.csu is offline   Reply With Quote
Old 05-28-2012, 11:25 PM   #5
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
Gonna have to try this out, thanks!
Old 05-28-2012, 11:48 PM   #6
Jdub.csu
Member#: 283784
2013 EVO X GSR
Supposed to say bake under the sun. Basically that spray takes UV light to cure. So do it on a sunny and non windy day. The can of spray costs about 35 bucks a can and will do 3-4 sets of headlights
I've done so many jettas, neons, and mustangs with that stuff it works great. We offer a 3yr/ 36k warranty on it so yeah it works
Old 05-29-2012, 11:23 AM   #7
Jdub.csu
Member#: 283784
2013 EVO X GSR
Old 05-29-2012, 01:17 PM   #8
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
spoon feeding me directions and products, I like
Old 05-29-2012, 01:33 PM   #9
Jdub.csu
Member#: 283784
2013 EVO X GSR
Here is some before and after pictures just for ****s
BEFORE
AFTER
THIS IS WHAT THEY LOOK LIKE CLEANED SANDED to 1,000 grit before spray
Old 05-29-2012, 01:49 PM   #10
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
wow! looks brand new. that before picture was so oxidized and crap looking
Old 05-29-2012, 01:55 PM   #11
Jdub.csu
Member#: 283784
2013 EVO X GSR
Yeah I asked the lady how she could see at night, the picture makes it look nicer than it was, and she told me well I just don't drive at night.
Old 05-29-2012, 05:37 PM   #12
subaru505
Member#: 321645
03 03 rsti
black
ive just been buying the 8 dollar bottle at pep boys and do it after every wash and its working great
subaru505 is offline   Reply With Quote
Old 05-29-2012, 06:04 PM   #13
Jdub.csu
Member#: 283784
2013 EVO X GSR
Why spend 8 bucks multiple times a year when you can spend 50ish and do it once...
Old 05-29-2012, 06:36 PM   #14
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
well im sure if she did she be able to see a LOT better.
Old 05-29-2012, 08:57 PM   #15
Jdub.csu
Member#: 283784
2013 EVO X GSR
I know so plus in CO you would have to drive in the dark unless you go into hermit mode around 4:30pm during winter..
The problem with other solutions is that you will have to keep doing them over and over because they don't replace the UV prot coating.
Old 05-29-2012, 11:11 PM   #16
XERO287
Member#: 253541
2011 WRX 5DR Premium
OP, just get the 3M scratch repair kit, not the headlight restoration kit. That Along with some 2000-2500 grit wet sanding should do the trick. After that use Meguiar's headlight sealant.
XERO287 is offline   Reply With Quote
Old 05-30-2012, 01:47 AM   #17
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
How about what XERO287 said? Mine really isn't oxidized just needs a touch up to make them clear and I was looking into the 3m kit, but adding the meguiar's sealant seems to be a good idea
Old 05-30-2012, 08:50 AM   #18
SovereignSpoon9
Member#: 297519
I tried the 3M kit and it was ok not great. I will definitely be doing this next time I need to! Those before and after pics are almost unreal.
SovereignSpoon9 is offline   Reply With Quote
Old 05-30-2012, 09:30 AM   #19
Jdub.csu
Member#: 283784
2013 EVO X GSR
The 3M still doesn't seal it, that's the problem with all these kits.
Here is another before and after
BEFORE
AFTER
Old 05-30-2012, 10:10 AM   #20
XERO287
Member#: 253541
I know, the 3M Headlight restoration kit is way too abrasive. Only god knows why you would need to have a 600 grit disc rotating at greater than 5k rpm. I Buy the 3M scratch repair kit (Comes with 2 pads. One is for compounding the other is for polishing, it also comes with a 3000 grit square of sandpaper). I also buy a pack of assorted high grit sandpaper ranging from 1500-2500.
Step 1: Spray headlights and 2000 grit sandpaper with water
Step 2: Rub sandpaper on headlight (Due about 2-3 passes)
The headlight should like white after this
Step 3: Spray headlights and 2500 grit sandpaper with water
Step 4: Repeat step 2
The headlight should still look cloudy and white but to a lesser degree
Step 5: Spray headlights and 3000 grit sandpaper with water
Step 6: Repeat step 2
Step 7: Wipe off headlight with microfiber cloth and inspect the light to make sure the surface is now smooth and the light has the finest of scratches.
Step 8: Mist the Purple Compounding pad with a spray of water then apply a dime size of compound.
Step 9: Start compounding the light making at least 4 passes or until the compound breaks down and you start to see through the light.
Step 10: Wipe light off with microfiber towel
Step 11: Mist the Black Polishing pad with a spray of water then apply a dime size of rubbing compound (Polish)
Step 12: Repeat step 9
Step 13: Repeat step 10
Step 14: Apply a dime size of Meguiar's Sealant to the black polishing pad
Step 15: Start Sealing the light making about 3 passes or until the light is fully clear and transparent
Step 16: After 10-15 minutes wipe light off with a clean microfiber towel to remove excess residue.
Step 17: Enjoy your new-looking headlight and take pictures to compare!
Old 05-30-2012, 12:35 PM   #21
d0ugch0i
Member#: 198861
2004 WRX
meguiars has a new product that they came out with called headlight protectant.
d0ugch0i is offline   Reply With Quote
Old 05-30-2012, 03:23 PM   #22
XERO287
Member#: 253541
Right, that's what I've been saying...
http://www.autogeek.net/meguiars-hea...rotectant.html
Old 05-30-2012, 04:32 PM   #23
Jdub.csu
Member#: 283784
2013 EVO X GSR
"With regular use"
**** that
Do it once with renulite and be done with it
Old 05-30-2012, 05:32 PM   #24
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
jdub is basically saying the exact thing I've been saying for years... you have to SEAL the headlight or it will get worse once the polish wears off. I go as fine as 3000 grit when i restore head lights though.
That sealant is a nice solution and a good find. If you cant get that, clear exterior poly will work just as well.
Old 05-30-2012, 06:00 PM   #25
Jdub.csu
Member#: 283784
2013 EVO X GSR
Finally someone gets it, you can go finer grit I just don't find it necessary with that compound we use.
Need Guidance on Unique 05' Headlight Restoration DexteRS Car Care & Detailing 11 10-26-2012 12:59 AM
Paint sealant on top of a paint sealant? frickfrack Interior & Exterior Modification 5 11-03-2011 09:19 AM
Turtlewax headlight restoration... ruined my headlights? krimghor Car Care & Detailing 14 05-27-2011 11:10 AM
Did some headlight restoration on my moms car. SickScoob Car Care & Detailing 6 05-21-2010 01:28 AM
Need some headlight restoring help Boostinbildo Car Care & Detailing 6 05-14-2010 11:15 PM
