Old 05-29-2012, 12:17 PM   #1
Leonardo
Consigliere
Super Moderator
Member Sales Rating: (3)
Member#: 185
2009 Civic EX
Default Proto Tuning Tool (AccessPort) Holder
Well, I got this little gem from RallySportDirect and love it!
Here is the how to install and review for a 05-09 LegGT:
This is what you get in the box:
Simple instructions that give you the option for A/C vent clip or a more permanent mount that included #M tape and screws.
I opted for the clip mount.
Tried the center window vents but the holder is too heavy with the AccessPort in it.
Moved to the side vent and found good placement on the second vent fin bottom to top.
Took off the side cover and tucked the wire inside and pulled the panel where the mirror cover is and took out the cable through it.
And the final product:
In all, I love how it holds the AP and how easy it is to mount. I might try a smaller,thinner cable next. If you want to mount it any more solid, the solid mount is the way to go.
Thanks RallySportDirect for bringing this to us!
Leonardo is offline   Reply With Quote
Old 05-29-2012, 12:53 PM   #2
xluben
Member Sales Rating: (17)
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here's my review:
forums.nasioc.com/forums/showthread.php?t=2338143
Here are some photos of the Proto Tuning Tool Holder. It is an AccessPort vent mount from RallySportDirect. It is a pretty simple item, but does exactly what it is mean to do. Unlike other "universal" mounts (ie. GPS or phone mounts) it is a perfect fit for the COBB AccessPort and it allows for various mounting options.
The first, and easiest, mounting style is a simple vent clip. The tool holder also includes a mount that can be "stuck" on or screwed on. Once in place the mount has dual ball joints for a good range of adjustment and positioning, and then has a thumbscrew to hold it all where you want it. It's very easy to get it installed and setup for easy AccessPort viewing.
Here are some photos of the packaging and included items.
Comes with alcohol wipe, screw/stick on mount, screws, instructions, and AccessPort holder (with vent clip currently installed).
Here is a photo with the screw/stick on mount installed.
Here it is with an AccessPort.
Back View.
And here are a couple shots mounted in my car.
And in my brother's 2011 MS3.
xluben is offline   Reply With Quote
Proto Tuning Tool Holder (AccessPort Mount) from RallySportDirect xluben Interior & Exterior Modification 48 04-01-2013 01:41 PM
Proto Tuning Tool Holder!! RallySport Direct Vendor Announcements 5 04-23-2012 03:15 PM
Java UTEC Tuning Tool (JUTEC) Tgui Engine Management & Tuning 15 01-18-2005 06:14 PM
UTEC Logger Software! Tuning tools needed. woodruf Engine Management & Tuning 0 08-03-2004 01:32 AM
found special deal on tuning tool gypsymoth Normally Aspirated Powertrain 6 05-21-2002 06:39 PM
