05-29-2012, 04:25 PM | #1 |
Member#: 243697
Vehicle:2002 TOPSCOOB031 HighwaystarGarage |
A/C Compressor randomly engaging when turned on - freon overfilled?
I finally replaced a broken A/C. tensioner bolt and plugged in a new A/C compressor (45K miles). The freon is full.
The problem I am now having -- while turned on, the A/C compressor randomly engages. Engagement is not consistent, but while the compressor is engaged, the A/C is quite cold. I do not believe the compressor has any issues, because it's not emanating any noises associated with a broken clutch or worn out bearings. The system is also not freezing. My only diagnosis thus far is that the freon could be TOO full, which according to basic NASIOC research can lead to this problem. So, time to grab a PSI gauge and measure. NASIOC braintrust - any other ideas before I tackle this?
05-29-2012, 05:19 PM | #2 |
Member#: 236927
NESIC
Vehicle:2015 BRZ 86 GL Hatch 1984 BRAT |
It's completely normal for the compressor to engage and disengage while being operated. It should cycle regularly if it is functioning properly.
As long as it is not flickering or engaging and disengaging rapidly, which would indicate too much pressure in the system. If not then you probably don't have a problem. |
05-29-2012, 05:23 PM | #3 |
Member#: 60276
Vehicle:2015 Camaro SS 03 WRX/STi hybrid sold :( |
is it engaging while your front defogger / defroster is on? Remember that your A/C condenser WILL kick on while that mode is selected to draw moisture OUT of the cabin.
just a simple heads up just in case |
05-30-2012, 07:15 AM | #4 |
Member#: 243697
I anticipate the system will engage and disengage while being operating, and believe (rightly or wrongly) that this fluctuations based at least partially on engine load. However, my frustration is the compressor isn't engaging long enough to keep temps cool in the vehicle. I'll be driving along and it's working fine, then disengages.. and it'll get hot in the car. A few minutes later the compressor engages again and it gets cool. At the end of the day, the compressor seems to have a mind of its own
05-30-2012, 08:22 AM | #5 |
Member#: 311801
NWIC
Did you evacuate the system after you opened it? Air is non-condensable and it will cause the pressure to overshoot if left in.
If you didn't pull a vacuum, then you should recover the charge, evacuate and recharge. How much refrigerant does the system call for and how much did you put in? Charging by weight gives the best result if you have the patience to do it right. |
05-30-2012, 08:49 AM | #6 |
Member#: 62408
South East
Vehicle:2002 wrx w/ STi guts 174k miles on Mobil 1 |
A good starting point is to use the "real" gauges that tell you both low and high side and check the static pressures (engine not running). Let everything cool down for a few hours (meaning don't drive 500 miles and check it - the underhood temps will throw off the readings). The static pressure on both gauges should be close to the ambient air temperature.
As someone else stated, it's completely normal for it to cycle - it's when it doesn't cycle and continuously runs that indicates a problem. Now when it's running... These numbers are by no means "carved in stone" but it's a good starting point, so if you notice a 10% +/- don't get all gung ho and pump more into it. |
06-21-2012, 08:55 PM | #7 |
Member#: 243697
Turned out the shop that put in freon overfilled it. Once the engine got hot enough to build pressure in the AC lines the compressor would shut down to avoid damage.
My low side pressure at operating temperature was more than 300 PSI at 100ish degrees. Wow. Fixed now |
Clunk When Turning Wheel - Memory Steer? | jjbehren | Newbies & FAQs | 19 | 07-25-2013 04:43 PM |
AT Fluid Temp CEL only when turning on headlights | MY99 2.5GT | Service & Maintenance | 1 | 04-14-2003 10:54 AM |
Very loud noise when turning on headlights? | GameMastyr | Newbies & FAQs | 9 | 01-29-2003 05:58 PM |
Lock/Unlock when turn On/Off the car? | iBlueVirus | General Community | 11 | 07-09-2002 11:05 AM |
Loud click noise when turning on/off headlights | MooBob42 | Warranty Issues & SOA Problems | 3 | 02-26-2002 07:31 PM |
