Old 05-30-2012, 11:06 AM   #1
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Default A few things I have created lately
Well Ive been on a real fabrication kick lately and I thought you guys would enjoy seeing my creations.
I began with making some fender braces to replace the very flimsy stock units.
Then I decided I wanted to make a master cylinder brace.
Then I finally broke down and bought a tig welder. I had wanted one for quite some time and it just so happened that our local custom motorcycle shop was selling one of theirs. So I picked it up and promptly taught myself how to use it. At first it was a bit weird, but I quickly got the hang of it. Now I can't put it down! I love it. So, I thought I would weld of a sort of cage style brace to stiffen up the hole rear of the car. I made it out of aluminum.
Next im going to make a catch can, and maybe some under-car bracing
I--RIDE--BIKES is offline   Reply With Quote
Old 05-30-2012, 12:51 PM   #2
oguitar
Member#: 206720
2002 WRX Wagon
Very nice work.
oguitar is offline   Reply With Quote
Old 05-30-2012, 01:34 PM   #3
WiRX
Member#: 205930
Very Nice! Why buy it when you can build it!
WiRX is offline   Reply With Quote
Old 05-30-2012, 06:07 PM   #4
cenix
Member#: 246027
2011 STI
awesome work! please post more pics of your work!
cenix is offline   Reply With Quote
Old 06-06-2012, 05:23 PM   #5
auapaul
Member#: 322382
Very nice work! Are you painting or powder coating?
auapaul is offline   Reply With Quote
Old 06-07-2012, 04:25 AM   #6
scubynoob
Member#: 276157
2006 WRX sedan
how did you mount the trunk bracing?
scubynoob is offline   Reply With Quote
Old 06-07-2012, 10:36 PM   #7
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
I sanded, scuffed, then clear. Coated it. I like the raw finish look. In the trunk I mounted it to these holes that went through the "frame rails". They were covered by a small sticker.
Old 06-08-2012, 07:52 AM   #8
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
I would be very concerned about that brace if you get rear ended with passengers. You're going to transmit a lot of energy directly into the back seats.
Also, the rear cross braces should run all the way up to the front - having them pick up the middle of those tubes reduces the stiffness by a significant amount. Triangles are what you're after. If you have an opening which is not a triangle it's going to be compromised.
sniper1rfa is offline   Reply With Quote
Old 06-08-2012, 12:15 PM   #9
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
The way I have designed it in the rear, it should give out under a large hit before causing harm. It was too large to build as one unit then bolt it it, so instead it is 2 separate pieces that are joined together. The joint is a small sleeved section on one side and a half section of tube that slips over top of the internal aluminum rod,then bolts in. This area along with a couple other areas should result in a a crumpling under a large hit.
I couldn't run the x-brace all the way up because of the sections that needed to be cut to make it removable.
Thanks for your concern. Safety was in my mind when I was creating it.
Old 06-08-2012, 10:23 PM   #10
wadud
Member#: 258048
06 wrx
E.S.A.C
If you ever think about mass producing the braces let me know!! Outstanding work!! Godspeed
Jim
wadud is offline   Reply With Quote
Old 06-08-2012, 10:39 PM   #11
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
I was just thinking there was a lack of triangles. The braces do look pretty but some triangulation will get you the most out of it for chassis stiffening.
Now get on it...and sell me one!
SpamMansXe is offline   Reply With Quote
Old 06-13-2012, 09:49 PM   #12
eurotek
Member#: 270651
2005 vf39'd WRX
great job man! i really wish i could weld better.
eurotek is offline   Reply With Quote
Old 12-03-2012, 02:40 AM   #13
suuichi
Member#: 316952
2008 Impreza 2.5i
Dark Grey Metallic
Nice i would like to know where you learned how to do these things.
suuichi is offline   Reply With Quote
Old 12-03-2012, 09:25 PM   #14
tstirm42
Member#: 315212
2003 WRX Sedan
Awesome!! Love the master cylinder brace
tstirm42 is offline   Reply With Quote
Old 12-04-2012, 12:25 AM   #15
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Glad you like them. Really I've just self taught myself everything. I have a huge urge to constantly learn new fabrication skills. I just love to make things and say that you created them.
Old 12-16-2012, 04:17 PM   #16
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
Cool stuff!
Surb00 is offline   Reply With Quote
Old 12-16-2012, 06:27 PM   #17
TyConway
Member#: 193189
2002 wrx
which tig welder did you get? I'm looking to upgrade my diversion 180, just need to be able to adjust settings when doing aluminum. the auto set for frequency's is the only down fall. your work looks good, how much time have you spent tig welding?
TyConway is offline   Reply With Quote
Old 01-23-2013, 12:09 PM   #18
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
I have a Lincoln SquareWave 175. It doesn't have a TON of features but it seems to be doing just fine for me. Maybe in the next year or two i will upgrade.
Thanks. I really have only started tig welding last June and only use it when im I have that feeling that a have to build something haha.
Here are my other latest items ive build.
-My Gtspec strut bar that I had laying around would always contact my intercooler so I kept the mounting plates from it and fabbed up my own support/tie bar.
-Also here is a camera stabilizer/rig I made for videoing.
Old 01-24-2013, 01:07 PM   #19
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Nice work! I'm getting ready to buy a tig in the next month or so and have been debating on the Lincoln square wave 175 or something with more power like the miller synchrowave 200 which is 600 or so more dollars but i do want to be able to do some thicker aluminum nothing crazy tho
mecpgh is online now   Reply With Quote
Old 01-24-2013, 07:51 PM   #20
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Ya it is always nicer to be able to have headroom for welding thicker material, but preheating can help solve that issue. I know preheating has helped me in certain situations.
Old 01-24-2013, 09:46 PM   #21
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Good point, do you have any regrets with your machine?
Old 01-24-2013, 10:47 PM   #22
norexyet
Member#: 39149
11 elantra
yea i said elantra
I went to Lincoln electric a few years back for a few week course on tig/mig and some basic metallurgy. I was able to use their whole range of machines at the time. Even with that I prefer Miller over them. We have a dynasty 350 at work plus a square wave. The 350 is a beast of a machine.
norexyet is offline   Reply With Quote
Old 01-24-2013, 11:38 PM   #23
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
No regrets at all. I'm very happy with my machine. With that being said, If I had a ton of money I would have gotten a more capable machine but at that point I'd be spending thousands above my budget.
Old 01-25-2013, 10:10 AM   #24
mecpgh
Member#: 193014
02 WRX WRB, 05 STI
FPGreen E85 400+whp
Ya that's why I'm wondering if its worth it to go up to the next level machine were taking allot more cash $$
Old 01-26-2013, 03:08 PM   #25
Mr. Wagon
Member#: 244383
My advise is to take classes whenever you can. Self teaching is a good way to learn bad habits. I give you this advise form personal experience.
Mr. Wagon is offline   Reply With Quote
A few things we've been doing lately Maxwell Power North West Impreza Club Forum -- NWIC 9 10-17-2009 03:31 PM
Most useless thing you have seen lately? vapore0n Off-Topic 22 02-17-2008 08:56 PM
FS (again): Few things I have left over brian 126 North West Impreza Club Forum -- NWIC 5 08-12-2005 06:55 PM
FS: Few things I have no use for elguapo454 Private 'For Sale' Classifieds 16 06-16-2005 03:18 PM
FS: A few things I have lying around luvmyrs Tri-State Area Forum 5 01-20-2004 12:34 PM
