Old 09-13-2012, 12:48 PM   #451
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
Originally Posted by Jdub.csu View Post
Enjoy children
"I have a vibration... are you sure you didn't hit anything"
My cousin bought a set of rims for his Acura and one of the tires had a bulge like that, though it wasn't nearly that big. We were working on our cars and he decided that it would be a good idea to pop it with a knife. Needless to say, the thing exploded and hit him with rubber shrapnel. It was loud as hell. dumbass.
abosworth is offline   Reply With Quote
Old 09-13-2012, 02:02 PM   #452
rudymcskoody
Member#: 257618
2006 wrx
aspen white
That wasn't smart.
rudymcskoody is offline   Reply With Quote
Old 09-13-2012, 08:28 PM   #453
zackg
Member#: 248581
2012 STI
Originally Posted by jebjkey View Post
What are we supposed to be looking at?
I do not see what you found.
Maybe only 125 miles to a full tank?
zackg is offline   Reply With Quote
Old 09-13-2012, 10:32 PM   #454
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Needless to say, the thing exploded and hit him with rubber shrapnel. .
He's lucky the knife didn't become part of that shrapnel.
ManualOverAuto is offline   Reply With Quote
Old 09-13-2012, 11:12 PM   #455
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
That looks photoshopped. I know it isn't, but seriously, it does look like it.
bugeyetex is offline   Reply With Quote
Old 09-13-2012, 11:27 PM   #456
easterbran
Member#: 307359
'05 STi Stage II
I was thinking the exact same thing....
easterbran is offline   Reply With Quote
Old 09-13-2012, 11:58 PM   #457
somecoolbox
Member#: 328190
This thread = how much "fail" is driving around us every second of everyday..
somecoolbox is offline   Reply With Quote
Old 09-14-2012, 12:01 AM   #458
Jdub.csu
Member#: 283784
2012 SWP WRX HATCH
Scary to think about right?
Jdub.csu is offline   Reply With Quote
Old 09-14-2012, 02:13 AM   #459
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Replace the battery, cables, and buy a corrosion inhibitor spray.
It's usually a purple looking stuff. We spray it on every battery we install
buy agm battery and done
Old 09-14-2012, 05:47 AM   #460
Black94Snake
Member#: 274499
2007 CGM VF'd WRX
12.9 @ 105mph
That's all well and good for you, me, and the other folk around here that know better... But the average jackoff is WAY to cheap to go AGM. Hell, they are usually too cheap to pay for a battery terminal cleaning.
Black94Snake is offline   Reply With Quote
Old 09-14-2012, 07:11 AM   #461
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Enjoy children
I've seen a bigger one off a f 250. A few years ago when I worked for discount tire. We let all the air out but the bubble was still inflated. We were afraid to use the mechanical ARM to break the bead so we pit it in the tire cage, tied a knife to the end of a broom to POP it. It was pretty funny. It took a few good pokes and sounded like a bomb went off when it finally popped.
Old 09-14-2012, 07:52 AM   #462
Ian G.
Member#: 303086
2008 Subaru WRX
Dark Grey
Lol I see the bubbles like that all the time. One of my coworkers thought it was a good idea to set the auto pressure hose to 80 psi and see what happens. The bubble popped so loud it was like a bomb ( tire jumped in the air about 3 feet ) . Terrible idea, especially if the rim is damaged. Another horrible situation...don't see this one much.. A kid tried installing 16 inch tires on a 16.5 inch rim, they fit snug but when he went to install/ inflate he was standing over the assembly. Needless to say the assembly exploded about 15 feet in the area after the beads where seated, made him deaf in one ear, and needed serious surgery on his elbow
Ian G. is offline   Reply With Quote
Old 09-14-2012, 08:23 AM   #463
rudymcskoody
Member#: 257618
2006 wrx
aspen white
That's why discount won't change half sizes anymore.
Old 09-14-2012, 08:54 AM   #464
Ian G.
Member#: 303086
2008 Subaru WRX
Dark Grey
You can tell if you have the 16.5 measuring tool , but I'm sure you know that most people will neglect to check with that. You can only really tell the difference by the angle of taper on the rim flange. I've only seen .5 sizes maybe three times in seven years
Old 09-14-2012, 09:53 AM   #465
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Some box trucks use them, utility trucks, older RVs, that kind of thing. We usually just checked the tire size. If it was a half size we didn't touch it.
Old 09-14-2012, 09:56 AM   #466
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
HMMWV's are 16.5, but the wheels are 2 piece.
340Duster is offline   Reply With Quote
Old 09-14-2012, 11:11 AM   #467
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Most half sizes are, aren't they?
Old 09-14-2012, 11:30 AM   #468
Black94Snake
Member#: 274499
2007 CGM VF'd WRX
12.9 @ 105mph
No. 70's and 80's gmc trucks used one piece 16.5" wheels.
Old 09-14-2012, 03:36 PM   #469
guidojuicehead
Member#: 254153
98' GF9.257
88' Chevy LWB
Speaking of split rims...
My father and I picked up a free 1ton 71' Dodge Powerwagon after it sat for 20 years back until the mid-90s. The truck was so heavy, it had sunk up to its axles in red clay. It had been used for 44k on a Safari trip in Africa, and put away. Preparing the truck for Africa involved modifying the 318 to burn the low octane fuel of the country. If fired up with 20 year old fuel and a new battery.
The truck was running... Why not try to move it out of the clay while it was wet? Dana70's front and back and 4.88 gears, "It was built for Africa... and should be just fine" were the last words...
The end result, was a stripped rear ring/pinion, and a lock ring in two pieces. One 200 feet away, the other was impaled an oak tree. That might have been the scariest moment of my life, until... When we brought the remaining five wheels into a salvage yard that was willing to deal with them, they treated them like time bombs. The forklift driver had one ring explode just as he put it in the cage due to heat. I had just turned around with a smile and sigh of relief, and BOOM... That was the second time I nearly crapped myself.
guidojuicehead is offline   Reply With Quote
Old 09-14-2012, 09:35 PM   #470
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
More proof that nothing is free...
Old 09-17-2012, 08:51 PM   #471
psychodad
Member#: 188168
08 outback
Two of my buddies are supposed to be putting studs in their new snowmobile tracks one night. They bought the studs with the plastic backers, which are supposed to be torqued to 32 INCH-POUNDS. But they can't read directions.
Buddy 1 says to me,"We keep crushing and breaking the backers when we torque them down."
Me "The torque wrench is in foot pounds"
Buddy 1 to 2 "We weren't doing anything wrong, the stupid torque wrench is in the wrong scale"
Buddy 2 says "How many inch pounds in a foot pound?"
psychodad is offline   Reply With Quote
Old 09-25-2012, 12:11 PM   #472
abosworth
Member#: 53856
2003 WRX
Stage 2 taxi
Bump.... Who's got some more good stories and pics? I don't want this thread to die.
Old 09-26-2012, 01:02 AM   #473
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
I, too, don't want this thread too die. Soon I will have more, but this should help for now....
Rice fail- (notice the duelling fart cans...)
And, did they pay for this stripe????
And yes, thats my lumpy hood. Aluminum + Hail =
Old 09-26-2012, 01:21 AM   #474
oneillsurf5
Member#: 317333
2004 RS 2.5
Sometimes I hate that I drive a 2.5RS oh wait I hate that all the time lol
oneillsurf5 is offline   Reply With Quote
Old 09-26-2012, 02:39 AM   #475
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
oh no its going ot
bue car is offline   Reply With Quote
NASIOC, sometimes I hate you so much! Jard Off-Topic 50 08-25-2010 10:55 PM
sometimes i hate my job koolaideprived Off-Topic 17 07-01-2004 11:06 AM
Sometimes I hate suspense... LinuxGuy New England Impreza Club Forum -- NESIC 21 03-07-2003 10:03 AM
Sometimes I Hate Living Where I Do... S-K South East Region Forum 1 09-24-2002 11:51 PM
Message Board Statistics All times are GMT -4. The time now is 04:48 AM.
