Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 11-19-2012, 01:22 PM   #726
T-WRX
Member#: 2468
08 RS4
05 STi
Car's in the shop for blinking cruise.
CEL says misfire cyl's 3 and 4.
T-WRX is offline   Reply With Quote
Old 11-19-2012, 01:38 PM   #727
SRP WRX
Member#: 103530
2003 WRX
Sedona Red Pearl
I had a cyl 4 misfire...looks like mine was spark plug gap. Hopefully yours is easy
SRP WRX is offline   Reply With Quote
Old 11-19-2012, 02:48 PM   #728
sonicshortbus
Member#: 44127
2006 STi
CGM
Can anyone suggest a reputable place or know someone trustworthy to have repairs done in Jax? (as I am not able to do my own)....currently looking at p/s pump woes... thanks in advance
sonicshortbus is offline   Reply With Quote
Old 11-19-2012, 03:15 PM   #729
SRP WRX
Member#: 103530
2003 WRX
Sedona Red Pearl
Whats wrong with it?
Old 11-20-2012, 07:08 AM   #730
T-WRX
Member#: 2468
08 RS4
05 STi
Yes, a number of things can cause this misfire...
http://forums.nasioc.com/forums/show...7#post36504277
I had my PS pump replaced at SoJax about 4 years ago. The replacement itself is not that difficult, but it is an expensive part.
However, have you tried replacing the PS fluid first?
Old 11-20-2012, 10:05 AM   #731
T-WRX
Member#: 2468
08 RS4
05 STi
Per sparks, it was item #2 on the list above...
2. Clogged/dirty injectors or fuel filter. Try changing the fuel filter. The maintenance schedule for the filter is every 30K miles. Have the injectors professional cleaned or at least run several bottles of a good injector cleaner through the gas tank. Also make sure you are using the correct octane gas! Either 91 or 93 unless you are specifically tuned for another octane!! (IE: race gas or E85) You can swap injectors from another cylinder and see if the misfire follows. If so this would indicate an injector issue if it does move. .
Hopefully I'm back on the road ASAP!
Old 11-20-2012, 02:42 PM   #732
sonicshortbus
Member#: 44127
2006 STi
CGM
the whole steering vibration, whining noise and did recent p/s flush after dealer said needed a new pump...
Old 11-20-2012, 09:45 PM   #733
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
it may just be an air leak
Old 11-21-2012, 07:46 AM   #734
T-WRX
Member#: 2468
08 RS4
05 STi
Car is back on the road with no more misfire CEL! Root cause was identified as dirty injectors. After Brent and SoJax team read a high roughness monitor (41 and 18 on cyls 2 and 3), they swapped the injectors and noted the high counts tracked with the injectors. So they ran some type of induction cleaning cycle on the injectors (in place) and the roughness monitor went down to 0 or 1 on all injectors. CEL went away.
Old 11-21-2012, 07:49 AM   #735
hjz420
Member#: 265757
Do you happen to know what they used exactly?
I run the Lucas stuff about every other month.
hjz420 is offline   Reply With Quote
Old 11-21-2012, 07:54 AM   #736
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
what fuel have you been buying??
and maybe you should use a fuel additive to help prevent these issues....
Old 11-21-2012, 07:55 AM   #737
Sparks
Member#: 16495
2013 BRZ
Sterling Silver Metallic
We used Subaru's fuel injector cleaner SOA868V9140. You loop back the fuel to the tank and use the cleaner to run the car for about 15 minutes.
Joe and I talked about a regular schedule for using Redlines's S-1 to prevent this problem in the future.
Sparks is offline   Reply With Quote
Old 11-21-2012, 08:00 AM   #738
hjz420
Member#: 265757
Thanks shaun
Old 11-21-2012, 10:07 AM   #739
franchisco7
Member#: 286429
2002 Impreza WRX
SRP
Anyone hanging out for the next 4 days. I should be back in Jax tonight and wouldnt mind meeting up with some suby guys for a change.
franchisco7 is offline   Reply With Quote
Old 11-21-2012, 11:05 PM   #740
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars Evenin' JMS...
Woah, another SRP...Tilted meet on Sunday, other than that, I'm not sure.
prochucker is offline   Reply With Quote
Old 11-22-2012, 07:12 AM   #741
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
happy turkey day all yous guys....be thankful for what ya got....
Old 11-22-2012, 02:34 PM   #742
02BluWRX
Member#: 17924
2008 Prius
Happy Thanksgiving to all from Lakeland Hope everyone is eating lots of food and watching lots of Football if thats your thing
02BluWRX is offline   Reply With Quote
Old 11-23-2012, 06:21 PM   #743
T-WRX
Member#: 2468
08 RS4
05 STi
Scotty - I usually get Shell, but sometimes get Gate if I am low and have no alternatives. Not always easy when you only get 200 miles per tank.
Yes, this. I'll try it out!
Old 11-23-2012, 07:24 PM   #744
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
hess gas is better than gate
and forget bp.....it is either ok or ****....never know
Old 11-23-2012, 07:28 PM   #745
hjz420
Member#: 265757
This^^^^
Old 11-23-2012, 09:46 PM   #746
T-WRX
Member#: 2468
08 RS4
05 STi
Had my share of BP/Amoco in Chicago. Worst gas for Subarus ever.
No Hess on SS of Jax near me.
Old 11-24-2012, 07:42 AM   #747
hjz420
Member#: 265757
Beach Blvd and forest
Old 11-24-2012, 08:24 AM   #748
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
+300 miles on 1 tank..
Old 11-25-2012, 04:09 AM   #749
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
yeah....im getting 23-25mpg going 80-90 FULLY loaded with the ac on at 100*F..... and i can tell it is a bit too rich
im sure i could get 27-28 if i played with fueling a lil
if i was only getting 200 to a tank, id be looking at the tune as being a bit rich.....or the driver as being a bit
or both
Old 11-25-2012, 07:32 AM   #750
T-WRX
Member#: 2468
08 RS4
05 STi
or both
LOL - you know I drive it like I stole it every day.
and all of my driving is short distance city driving. I'm happy if I have an excuse to get on Butler, 9A or I95 to open it up a little (which wouldn't help mileage either).
If I take it easy on a trip (say... Gainesville), then I will get 300 miles... but even then I usually romp on a bit too much.
Jacksonville Mod Squad #5 Diversion South East Region Forum 208 08-04-2002 06:46 AM
Jacksonville MOD Squad #4 Sparks South East Region Forum 164 07-14-2002 01:45 PM
Jacksonville MOD Squad #3 Sparks South East Region Forum 215 06-30-2002 08:41 AM
Jacksonville MOD Squad #2 Diversion South East Region Forum 33 06-13-2002 12:38 AM
Jacksonville MOD Squad Sparks South East Region Forum 96 06-12-2002 09:33 PM
