Old 04-27-2001, 05:44 PM   #1
Jazz95
Member#: 4600
Da Ridge
Racer
Question Third gear grinding
Ever since I bought my subie, I've been experiencing a grind while downshfting into thrid gear. At first i thought it was me, but then I realized that it only happens when I'm doing more than 40 mph and put it in third. Is there a quick fix for this? Or will it cost me a new tranny?
Jazz95
Jazz95 is offline   Reply With Quote
Old 04-27-2001, 06:22 PM   #2
T-WReX 2.5RS
Member#: 5105
2000 Impreza
Post
i think that is considered a factory defect. check with your subaru dealer.
tony.
T-WReX 2.5RS is offline   Reply With Quote
Old 04-27-2001, 06:39 PM   #3
pottsie350
Member#: 6110
98 Impreza L
Red
Sounds like the third gear synchro may be bad, does it grind more if you shift into third faster? or does it grind the same no matter what speed you shove it into third?
pottsie350 is offline   Reply With Quote
Old 04-27-2001, 06:51 PM   #4
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Post
A little rev-matching and double-clutching can do wonders for an aging tranny...
-tim
TimStevens is offline   Reply With Quote
Old 04-27-2001, 11:20 PM   #5
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Jazz95, following what TimStevens mentioned, do you double clutch when you downshift into 3rd. The fact that you mentioned this occurs more often at a higher speed seems (coupled with it occuring in only while downshifting) makes me believe (I apologize ahead of time if I'm wrong) that you may not be properly double clutching.
FYI, the proper way to minimize syncro damage (and grinding) while downshifting is:
1) disengage clutch and shift into neutral
2) engage clutch and rev the engine until your engine is a little above the correct "engaging" rpm of the lower gear.
3) disengage clutch and shift into lower gear. The shifter should almost feel like it's being "sucked" into gear. This is how a good shift should feel like.
4) if needed, rev your engine again to match speed and release clutch (if matched really well, I'd just dump the clutch and go).
Joe
jhuang76 is offline   Reply With Quote
Old 04-28-2001, 06:53 AM   #6
neuromancer
Member#: 5973
2005 Scion tC
Post
Jhuang,
This is probably a dumb question, but what is the correct enganging RPM for a gear. I tought myself standard, and always did it by feel, I guess.
neuromancer is offline   Reply With Quote
Old 04-28-2001, 03:18 PM   #7
pottsie350
Member#: 6110
98 Impreza L
Red
Might be time for a synchronizer. You aren't running synthetic gear lube by any chance? If you are you should run one of the gear lubes that is designed for synchronized trannys. Another possibility, since you say it does it over 40, is that there is not enough freeplay between some of the other gears, and the 3rd gear cog is being drug along with the next gear simply by friction, and the friction from the synchro isn't enough get the gear up /down to the correct speed.
If you aren't using synthetic and you want it fixed then it sounds like a rebuild is in order. But don't do it just on account of my advice. Let a tranny mechanic listen to it. Or practice double clutching and live with it
Old 04-28-2001, 10:55 PM   #8
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
The correct engaging RPM is really complicated. You could calculate it based on the gear ratios AND your current RPM BUT, in real life, if you're braking, that changes things, the engine is decelerating, again, screwing things up.
For example: 4th gear is 1.088:1 and 3rd gear is 1.448:1 (for a 00 RS).
If you're in 4th at 2000 RPM (engine), then your tranny output shaft is at roughly 1838 RPM (2000/1.088). Now if you tried to shift into 3rd, AND assuming your wheels/tranny output is at the exact same speed, then your engine must be at 2662 RPM (1838*1.448). In other words, you will need to rev your engine (and the layshaft) to about 2700 before you should engage 3rd gear, or else the syncros will do the work.
As you can see, the percent change will stay the same ( x * 1.448 / 1.088 ) where x is your 4th gear rpm. BUT, the higner the absolute value of the RPM, the larger the gap. IE, at 4000 RPM in 4th gear, you'll need to rev to 5324 or 1324 RPM more!
BUT, on the other hand, if you're braking really hard, the time it takes to double clutch, your wheels/tranny output also slowed down SO you don't need to rev as much to match perfectly! SO - 1324 jump is only needed if you're on a level ground AND not braking (ie. coasting to a stop light that just turned green).
You should as an experience racer for this, but from my limited race experience, this is the reason why I like to downshift really quickly (when I'm braking hard). I'm literally pumping and dumping my clutch as fast as possible whem I'm running down my gears. I've developed a decent rhythm (again, dependent on the gear I'm in - almost a semi stab up high like 4th and 5th to a full stab going from 3rd to 2nd).
Thanks to ColinL, here is a website with all the gear ratio http://home.kscable.com/lockes/colin/imp_gears.htm
Hope this helps. If anybody sees and error, please let me know.
Thanks,
Joe
Old 04-28-2001, 11:21 PM   #9
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Jazz95, please think that I'm implying you're doing anything wrong by not double-clutching. In fact, on good syncros, you should never have to do it (heck, that's what syncros are designed to do)! The real fix is to have the tranny checked out by a professional. I'm just offering a quick fix if you will that'll at least stop the grinding (for now).
Joe
Old 04-29-2001, 12:59 AM   #10
Jazz95
Member#: 4600
Da Ridge
Racer
Post
Yes, it happens no matter how slow or fast I shift the gears. Double clutching huh? Well, I've been practicing, but I don't quite have it down yet. I start the process a little too late sometimes. But thanks for the info, I'll put it to good use.
Redline Shockproof and grinding third gear carveman Transmission (AT/MT) & Driveline 7 11-21-2008 07:35 PM
HELP!! RA Gears, third gear failed.... BlueByrd Transmission (AT/MT) & Driveline 4 07-18-2006 02:11 PM
strange third gear grind Jersey Dino Transmission (AT/MT) & Driveline 0 01-21-2006 06:47 PM
New Redline Gear oil = 1st gear grinding skoobywrx Transmission (AT/MT) & Driveline 6 10-26-2003 09:13 AM
AARRGGHHH! Third gear grinding!! RacerinLSL Mid West Subaru Owners Club Forum -- MWSOC 1 01-28-2003 10:32 PM
