Old 11-19-2012, 11:18 AM   #1
Nemwad
Member#: 291502
2008 Impreza WRX
Dark Grey Metallic
Default 08 WRX Assembly Help
Hello everyone. After several several hours of searching various Subaru forums and looking through the FSM, I have been unable to locate any diagrams on how to reassemble my EJ255 motor (more appropriately, how the oil feed lines and whatnot are run along the top-half of the motor).
A little back story; I spun a rod bearing a few months ago on my 2008 WRX. I tore it down, had the block reworked and replaced virtually everything internally on the motor. I've been able to successfully reassemble the crank case, heads, and everything else asside from the oil lines on the top of the motor from the turbo and the misc. vacuum lines.
I had taken pictures and video of the motor throughout the teardown process but, due to an SD card failure on my camera, I lost everything. The big part of the puzzle, for me, is where the oil lines connect via the banjo bolts across the top of the motor and the turbo. The car is completely stock, in regards to the headers, wiring harness, and oil flow lines. If anyone can provide any pictures, diagrams, videos, or can direct me to anything to aid me in my quest, I would be forever appreciative.
Nemwad is offline   Reply With Quote
Old 11-19-2012, 06:14 PM   #2
rebornS14
Member#: 338337
1997 S14
i think i can help. sent you PM.
rebornS14 is offline   Reply With Quote
Old 11-19-2012, 07:59 PM   #3
Snakebite420
Member#: 199730
2000 2.5rs
BRP
lol i know who you are! hehe
Snakebite420 is offline   Reply With Quote
Old 11-19-2012, 08:25 PM   #4
Nemwad
Member#: 291502
2008 Impreza WRX
Dark Grey Metallic
Bahahaha, stalker. Hurry up and do your swap so you can get bored with it and I can buy your car.
@rebornS14: Replied to your PM. You're awesome.
Old 11-19-2012, 09:21 PM   #5
rebornS14
Member#: 338337
1997 S14
email sent!
Message Board Statistics All times are GMT -4. The time now is 03:52 PM.
