Old 10-28-2012, 10:36 PM   #26
shawnhayes
Member#: 330882
Any pics of the access hole from underneath?
Shawn
shawnhayes is offline   Reply With Quote
Old 10-29-2012, 05:15 AM   #27
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
If you're afraid that you won't be able to find the access hole and drain plug, don't worry. It's easy to find once you're under the car.
sgoldste01 is offline   Reply With Quote
Old 11-15-2012, 01:30 PM   #28
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
I also had a Subaru 15208AA160 oil filter and a new crush washer (Subaru part number 803916010).
Is there a crush washer on the oil filter? If so, were they included with the filters you purchased?
Blur125 is offline   Reply With Quote
Old 11-15-2012, 05:56 PM   #29
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
When I bought Subaru 160 filters online, they didn't come with crush washers. But that's OK, since I have a Fumoto valve installed.
Old 11-16-2012, 02:52 PM   #30
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
This might be a dumb question, but is there any chance of the fumato valve getting hit and losing your oil?
Old 11-16-2012, 04:19 PM   #31
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ Not much of a chance. The valve doesn't hang below the plastic belly pan. I suppose someone who does off-roading with a Subaru might have reason to be concerned, but the Impreza isn't an off-roading car, so that shouldn't be much of a concern. If you break the Fumoto valve off your oil pan, you've probably done other damage to your car too (exhaust and more).
My oil change with the valve was much less messy than my first oil change using the drain plug. 0W-20 oil is super thin (especially when it's hot), and with the drain plug it dumps out of your oil pan FAST. I don't care how you position your catch pan, you're going to splash some oil. The Fumoto valve with the nipple (F-108N, I believe) and hose gives much better control of where the oil goes.
Old 11-16-2012, 06:27 PM   #32
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Totally agree about the added ease of oil changes. I'm just more curious as to how much pressure it would take to dislodge the adapter valve and lose your oil. I guess its a 1 in a 1,000,000 shot that a rock would dislodge it. In for one, thanks for your input!
Old 11-17-2012, 07:21 PM   #33
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Default Fumoto valve installed
For those who want to see what the Fumoto valve looks like after installation:
As you can see, the bottom of the valve is recessed up into the hole in the plastic belly pan. I think you'll agree that knocking the valve off the oil pan with a rock or other obstruction would be VERY difficult!
Old 11-19-2012, 02:49 PM   #34
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Exactly what I wanted to see!! Thanks sgodste01! I'll be contacting you shortly about your head unit, you have the best application so far on that thread.
Old 11-19-2012, 03:04 PM   #35
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ Glad I could help answer some questions.
Old 11-19-2012, 11:02 PM   #36
subi400
Member#: 216984
1996 Impreza outback
Green
Just a FYI to everyone here, I don't own a "new" subaru, but one thing that I have noticed is the paint on the oil pan where the oil pan plug goes and if a little piece of paint gets worn away it will cause a leak. So, if anyone is having a problem with the whole leaking thing, sand away the paint where the crush washer sits and then finish up with a smooth grit and it shouldn't be a problem.
subi400 is offline   Reply With Quote
Old 11-20-2012, 05:16 AM   #37
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^ Or use a Fumoto valve, which protects the oil pan paint since you don't have to unscrew and re-install the valve at each oil change.
Old 11-20-2012, 06:08 AM   #38
lymphomaniac
Member#: 334451
2013 Impreza2.0i CVT
DGM (sedan)
Just to confirm, is that the F-105N?
There's apparently a local distributor within driving distance, and I'm thinking of paying them a visit.
lymphomaniac is offline   Reply With Quote
Old 11-20-2012, 07:52 AM   #39
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No, you want the F-108N.
I think the F-105N might be the correct valve for pre-2012 Imprezas, but I'm not sure about that. I also don't know the correct fitment for 2012/2013 WRX and STI.
The F-108N is the correct valve for 2012+ Imprezas with the 2.0i normally-aspirated engine. I'm certain of that.
Here's your price to beat:
http://www.amazon.com/Fumoto-F-108N-Engine-Drain-Valve/dp/B003VCB9WC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1353415928&sr=1-1&keywords=f-108nhttp://www.amazon.com/Fumoto-F-108N-Engine-Drain-Valve/dp/B003VCB9WC/ref=sr_1_1?s=automotive&ie=UTF8&qid=1353415928&sr=1-1&keywords=f-108n
Old 11-20-2012, 02:17 PM   #40
lymphomaniac
Member#: 334451
DGM (sedan)
Thanks! Good thing I asked, instead of blindly following the Fumoto Canada site.
Old 11-20-2012, 04:34 PM   #41
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah, you'd think they could have updated their web site by now.....
Old 10-21-2013, 11:47 AM   #42
protivakid
Member#: 265148
2001 Legacy
Did the change at 7.5k on my crosstrek. I did it cold because I didn't want hot oil burning my hands and one problem I has was when I took the oil filter off I did it slow but a ton came out and almost filled the little round tray the oil filter sits in. I had to shop towel all the old oil out of that tray before installing the new filter.
Is there a way to avoid this mess? Is it just because the oil was cold?
protivakid is offline   Reply With Quote
Old 10-21-2013, 12:11 PM   #43
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
This was after you drained the oil from the plug? How long did you let it drain?
Old 10-21-2013, 01:02 PM   #44
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
^^That's what I was going to ask, too. Whenever I drain the oil first and then remove the filter, I get no mess.
Also, it's generally recommended to not drain cold oil, as it doesn't flow as fast (that flow is what flushes out some sediment).
You should check out a Fumoto valve. That would allow you to drain hot oil without getting any on your hands.
Old 10-21-2013, 01:49 PM   #45
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
+1 Where's the "like" button? ha
Old 03-23-2014, 02:55 PM   #46
subie 14
Member#: 385461
2014 impreza sport
gray
Default new 2014 subie
hello, just got a new 2014 impreza sport, was talking to my dad ( he does autobody ) and said/ seen that i could get a oil filter cover ? something to keep the dirt and stuff getting in the little hole to prevent it from clogging. has anyone seen this if so let me know.
thanks Joe.
subie 14 is offline   Reply With Quote
Old 03-23-2014, 03:19 PM   #47
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
thanks Joe.
Huh? To keep dirt from getting into the hole for the couple of minutes when the old oil filter is off, but before the new filter goes on? Is that what you mean?
Old 03-23-2014, 03:42 PM   #48
Trevorjackson69
Member#: 384605
There shouldn't be a hole in the oil filter
Trevorjackson69 is offline   Reply With Quote
Old 03-23-2014, 04:33 PM   #49
subie 14
Member#: 385461
2014 impreza sport
gray
to keep dirt from getting in the hole after doing a oil change. Not to soak it up or anything like that just so nothing can get in there when driving and such or does that not happen. Thanks again
Old 03-23-2014, 04:47 PM   #50
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I still don't understand what hole you're referring to.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
('11-'14) 2012 Impreza 2.0i Stability Control Function riccnick Impreza Forum 420 02-14-2015 05:53 PM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 02:49 PM
2012 Impreza 2.0i Mobil1 oil filter model # jr0bb5 Service & Maintenance 27 01-04-2013 05:18 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 05:07 PM
