Old 06-01-2012, 02:36 AM   #1
hoofhearted
Member#: 293554
Default 2011 WRX side vent LED turn signal mod.
So I have always wanted the STI side mirrors because of the side marker and turn signal that is built into them but I did feel like spending the money on them. This is my solution to that. Total cost was under $30 ($28 ish). Install took me about 2 hours because I took my time to make it as clean as possible. It looks like there might be some burnt out LEDs on the driver side but they are not, they are just being blocked by the plastic grille. I cut out the smaller grille pieces so the LEDs were not blocked but I did not cut the big grille pieces.
hoofhearted is offline   Reply With Quote
Old 06-01-2012, 02:41 AM   #2
hoofhearted
Member#: 293554
Connect the positive wire of the LED strip to the red wire going into the turn signal bulb if you want the LED strip to illuminate only when the turn signal is on. Connect the positive wire of the LED strip to the green wire if you want the LED strip to turn on and stay on when ever your parking nights are on. Connect the negative wire from the LED strip to the black wire going into the turn signal.
Old 06-01-2012, 02:50 AM   #3
d0ugch0i
Member#: 198861
2004 WRX
wow great write-up. if i had a 11' id definitely do this.
d0ugch0i is offline   Reply With Quote
Old 06-01-2012, 06:21 AM   #4
erik11876
Member#: 275888
2011 WRX Limited
Very original, but those vents are a functional heat extractor for the engine. Did you check to see how hot it gets there?
erik11876 is offline   Reply With Quote
Old 06-01-2012, 08:43 PM   #5
Avalon786
Member#: 297031
2011 WRX Sedan
WRB...duh!
Smile
I am curious, how hot does it get
Avalon786 is offline   Reply With Quote
Old 06-01-2012, 09:35 PM   #6
Tdiggidy
Member#: 183097
2012 WRX Sedan
Very cool I think. You're idea inspired this idea. Instead of the vent, I thought about illuminating the WRX side marker right next to it and doing the exact same thing. So a cut out of the WRX part and either LEDs or a light bar or something behind it synced with the turn signals?
It wouldn't be nearly as clear as this set up, but might be a nice touch. I'm sure it can be done, but to what extent of the work needed to get it done I really would have no clue.
Thoughts anyone?
Tdiggidy is offline   Reply With Quote
Old 06-01-2012, 09:41 PM   #7
hoofhearted
Member#: 293554
Thoughts anyone?
it's been done before there is a picture floating around on the internet someone put red leds behind the wrx symbol
Old 06-01-2012, 09:43 PM   #8
jwong1208
Member#: 308816
2012 WRX
Obsidian
Thoughts anyone?
wow, thats EXACTLY what i was thinking.
cut out the WRX.
I'm sure it would be the same procedure in terms of wiring, just with a smaller led strip, or a bulb, and a very small clear piece of plastic to go beneath the open letters..
To cut out the side marker, maybe a dremel?
jwong1208 is offline   Reply With Quote
Old 06-01-2012, 09:57 PM   #9
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
my salesman told me when i picked up my car the other day that those vent are functional and pull heat out of the engine bay. Is this going to interfere with that? or maybe its so marginal it wont matter? or he was bs'ing me
edit that i took those puppies off the other day to do my rally armor mudflaps and on way those are functional
Dmochowski is offline   Reply With Quote
Old 06-01-2012, 10:03 PM   #10
hoofhearted
Member#: 293554
I'm sure some heat comes out the vent but did you see the size of the only 2 holes behind the cover? Hardly big enough to 2 finger it, it doesn't look like much heat could come out. I'm not worried about it one bit.
Old 06-01-2012, 10:06 PM   #11
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Very cool setup OP.
Not to thread jack, but Tdiggidy I did exactly that mod last summer. It's not that hard to modify the badge, but space behind the badge is tight. I originally had a 2.4 inch LED strip behind each badge, but just today I pulled those and installed 3 of these Surface Mount LEDs on each side and it's much brighter and more even light. I have it wired to come on with the headlights, not as a sidemarker.
This is the old setup.
atf78 is offline   Reply With Quote
Old 06-02-2012, 12:31 PM   #12
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Are those just the LED strips you can pick up at Autozone? Also how do you pop that panel off? Thanks. Looks real good.
atf78...thats pretty slick man.
SouthernWRX is offline   Reply With Quote
Old 06-02-2012, 01:29 PM   #13
Tdiggidy
Member#: 183097
2012 WRX Sedan
Cool I was sure somebody did it before. I really like that idea. Did you paint the wrx emblem or wrap it? I want mine black also. Hard to see from my phone but I like the look.
And as for the heat coming out the vent. Its probably a negligible difference with the LEDs in there. I wouldn't worry about it either.
Old 06-02-2012, 03:33 PM   #14
Airplay355
Member#: 213825
2013 BRZ
Looks clean, great job!
Airplay355 is offline   Reply With Quote
Old 06-02-2012, 10:35 PM   #15
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Looks much better than I thought it would. Anyway to sync the front and sides together so it's not so many different blinks?
smeerone is offline   Reply With Quote
Old 06-02-2012, 11:53 PM   #16
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
I have led turn signals, and the module that comes with them that allows them to blink at a normal rate. I wonder if that would allow the front and side signals to blink together. It is a little disconcerting, having everything blinking out of phase. Is it easy to get different wavelengths of light, from blue to yellow? What about an amber to match the color of the front turn signal?
Dale2011WRX is offline   Reply With Quote
Old 06-04-2012, 06:07 PM   #17
scx89
Member#: 269388
2011 Impreza WRX
obp
OP, could you please post up what exactly you used?
How big was the LED strip? To get to the turn signal bulbs, did you have to remove the headlights or was it an easy pull out?
scx89 is offline   Reply With Quote
Old 06-04-2012, 09:31 PM   #18
dannyngnX
Member#: 303207
2012 Wrx
Pearl freakin white
just finished this
ill post pics up later, but my local autozone didnt have amber led's
so had to subsitute for white ones. Its legal here in texas, soo im all good.
only one problem, my driver side automatic power window isnt working now -__-
hmmm.. unless the turn signal fuse and driver side power window are together?
dannyngnX is offline   Reply With Quote
Old 06-04-2012, 10:24 PM   #19
hoofhearted
Member#: 293554
Originally Posted by dannyngnX
just finished this
I have a video on how to fix that in my YouTube page. WWW.YouTube.com/diyallday
Old 06-04-2012, 10:28 PM   #20
mw1484
Member#: 239546
2011 WRX TP Stg2+AEM
Spark Silver Sedan
very cool, and unique - nice work OP.
mw1484 is offline   Reply With Quote
Old 06-08-2012, 03:41 AM   #21
scx89
Member#: 269388
2011 Impreza WRX
obp
OP, can you tell me what kind of amber led strips you used? I searched on amazon but I don't see any that are amber colored. Just orange. Brand name? etc??
Old 06-08-2012, 11:32 AM   #22
Tdiggidy
Member#: 183097
2012 WRX Sedan
I was reading another post on lighting and saw that LEDs need a resistor? in line because of the difference in ohms between bulb types. I will see if I can find that again and post the link here. That module might be what you need to make them blink in sync.
Old 06-08-2012, 11:37 AM   #23
Tdiggidy
Member#: 183097
2012 WRX Sedan
Here's the link to the bulb sticky. That should tell you what you need to make them blink correctly:
http://forums.nasioc.com/forums/showthread.php?t=954736
Old 06-25-2012, 03:21 PM   #24
pakbot
Member#: 284229
2011 WRX Hatch
Satin White Pearl
Got the LED strips to do this today but the pics above have exceeded bandwidth. Anyone have an alternate link or copies of the pics?
pakbot is offline   Reply With Quote
Old 06-25-2012, 03:29 PM   #25
civicdelslow
Member#: 309678
2012 WRX
Dirty Black
You better fix those pictures before this place riots.
Very cool idea BTW
civicdelslow is offline   Reply With Quote
FS : 08-11 STi LED Turn Signal Mirrors WRX Conversion bustedstuff210 Exterior/Styling 9 02-21-2012 12:24 AM
wing riser w/ LED turn signal (w/ videoclip) satrya Interior & Exterior Modification 21 07-16-2003 12:16 PM
how come my LED turn signal bulbs are barfing on my '00 RS? sir_aspen_white Electrical & Lighting 16 03-11-2003 02:21 AM
1999 RS w/ LED turn signals Basshead Electrical & Lighting 6 03-11-2003 02:20 AM
Anyone using LED turn signal bulbs... Norb Interior & Exterior Modification 18 11-01-2001 10:14 PM
