Old 06-02-2012, 12:07 AM   #1
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I just received a DIY alignment kit in mail today, which is used to check front toe settings. A vendor, "Quick Trick", I purchased from specializes in DIY equipment for checking alignment settings and provides fast shipping via USPS priority mail.
Kit comes with high quality arms and 2 tape measurement, which I fould very easy to set up and use.
I've measured multiple times using the kit and was able to get a delta of 1/8" repeatedly between front and rear of tire, which means my car has a toe-in (explains for uneven tire wear). For a toe-in, tie rod needs to be loosened; for toe-out, tie rod needs to be tightened.
All in all, I highly recommend this kit for those DIYers.
http://www.ebay.com/itm/Quick-Trick-...ht_2720wt_1168
Old 06-03-2012, 06:25 AM   #2
b1aze
Member Sales Rating: (7)
Member#: 284003
2010 Alpine 135i
What do you measure the toe against? The other wheel??
b1aze is offline   Reply With Quote
Old 06-03-2012, 11:59 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
yes, you measure distance between edges of two front tires.
QT toe setting alignment kit txl146 Brakes, Steering & Suspension 1 05-28-2012 11:22 AM
Toe setting & additude of car through out the Corner FuJi K Motorsports 14 01-30-2003 12:44 PM
measurement units of toe setting TheWRX Brakes, Steering & Suspension 13 05-29-2002 06:31 PM
questions on toe setting WRXhauls Brakes, Steering & Suspension 6 04-04-2002 06:19 PM
Tire pressure in 18's, and camber/toe settings fellfrosch7 Brakes, Steering & Suspension 4 04-16-2001 10:53 AM
