Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 09-05-2012, 04:00 PM   #51
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
We are sure its a combination of both the transmission mount, rear subframe shifting, and the rear diff bushings.
Not to worry, both Cusco and Whiteline already have bushings for the trans and rear subframe. And its only a matter of time till the rear diff bushings are out.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 09-07-2012, 07:36 PM   #52
RallySport Direct
Member#: 33174
We are Open Late!
Old 09-07-2012, 11:02 PM   #53
ben_art
Member#: 172635
2003 WRX Wagon
i think i saw some lightning back there
ben_art is offline   Reply With Quote
Old 09-07-2012, 11:44 PM   #54
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Subscribed, love what you guys are doing I must be honest, hearing that Toyota paired up with subaru to come out with a non-turbo RWD vehicle to attract the "teen scene" wasn't very thrilling to me. Have always been a subaru fan and always owned AWD. But the write up's have really been quite encourageing to atleast be a little more accepting to this "new item" I must ask though I have herd rumors that the brz is a little different then the Toyota ft-86 and the FR-S. I was speaking to a buddy of mine works at subaru dealership. He informed me that the subaru suspension is actually tighter and stiffer then the frs and ft-86. He also stated that he believed the transmission was actually 2in farther back ? Then the other vehicles as well. He wasn't sure about the tranny but I figured I would ask here seeing as how this is where the learning process begun.
tjmmason93 is offline   Reply With Quote
Old 09-08-2012, 12:22 AM   #55
RallySport Direct
Member#: 33174
We are Open Late!
haha yeah, there was a beautiful storm rolling in behind us, made for a cool video though!!
Thanks,
Rick
Old 09-08-2012, 12:28 AM   #56
RallySport Direct
Member#: 33174
We are Open Late!
Take this with a grain of salt as my knowledge on the difference between the BRZ and the FR-S is pretty limited. I do think the suspension is different between the two models, in regards to what specifically, I am not 100% on that, but I have heard the BRZ is a bit stiffer. Now for the transmission and engine, they should be 100% identical, but someone feel free to correct me if I am wrong
Also, do your self a favor and go test drive one if you have not, it truly is an amazing car in 100% stock form. Not fast in anyway, but more than enough to get yourself into trouble/fun. The chassis, suspension, driving feel and feedback is just incredible though, and unlike anything I have ever felt, and worth trying out, even if you have no intentions of buying one.
Thanks,
Rick
Old 09-08-2012, 09:06 AM   #57
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Thanks,
Rick
U can't hate something uve never tried I suppose lol ill have to give it a shot when they become more popular and u can actually test drive one without buying it
Old 09-13-2012, 07:24 PM   #58
RallySport Direct
Member#: 33174
We are Open Late!
I was really excited when Whiteline told us they had a set of sways for our BRZ, and no more than one day later I got an email with a tracking number. So I cleared my schedule the day they were supposed to arrive here as I was super anxious to get these on. As you may already know, when we installed the Bridgestone RE-11 tires, the car lost its “Magic”, meaning that the rear end was not eager to break away for you on command, but we did receive massive grip. In fact, the car had so much grip that I nearly had to see a chiropractor after our Eibach spring test with the RE11’s as the grip flying through the cones just forced my head to whiplash back and forth. Not that the raw grip is ever a bad thing, but I missed the way the stock tires allowed the rear end to be so alive, it would almost dance as you threw the cars through corners, and was just an amazing experience. So I was really hoping and dreaming that the sways would give us back that magic that the factory BRZ had… and it did!
First lets touch on the install, as this was the first time I installed swaybars on the BRZ, and I figured it would be like the 08+ WRX/STi’s and to be honest, it was for the most part. We jacked the car up in the air, took off the skid plate, and started to rip that tiny front stock bar out. I removed the nuts that attached the sways to the endlinks, then the 2 bolts on the swaybar mounts. The stock bar came out with ease, but getting the new bar in would not be quite as easy. After struggling with it for a few minutes, I decided we just needed a bit more room, so I removed the brace that connects the front subframe to the unibody chassis of the car, once this was gone and out of the way, it allowed the new bar to slide in with ease. I greased up the bushings, put them in the right location and put the swaybar mounts back on, then installed the front endlinks. LAst, I dropped it back on the ground and torqued everything down. Now onto the rear, which I knew was going to be easy, so I left it for last. Once I got the rear end up in the air, it was as simple as removing the endlinks, and removing the swaybar mounts. Everything is easy to get to and you have plenty of space to work. The rear swaybar was about the easiest thing I have ever installed on this car. All in all I would say the front bar took around an hour or so, and the rear about 20 minutes. Once everything was torqued, I cleaned myself up and decided to take the car out for a quick test drive.
There is a stretch of road near work that I drive on every single day, now I am not sure if the city/planners/engineers had messed up, but there is a long 45MPH stretch of perfectly straight road, which eventually makes it way to a very tight, sharp, and bumpy S-turn, and guess what… no reduction of speed, so you can blast around it at 45MPH if desired, and I guess "technically" not break any laws by definition. Now I know if a cop saw me take this S turn at 45MPH, I am quite sure he would give me a ticket, but at least we would have something to argue about right? So anyway, not only do you get this nice tight S-turn, but it is followed by a very nice and curvy 35MPH road which I always find to be a great stretch of road to test out any car. It has a few tight technical turns, some off camber corners, and some nice bumpy corners. Cruising down this road, I could not help but break a smile, the magic was back!!! I had the rear 16mm swaybar on the middle setting, where the front is a 20mm non-adjustable bar. This combination proved to be just the ticket to bring the craziness back into this car. No longer did I struggle to make the rear end feel alive, now it was as simple as tossing the car into a corner, and let that rear end dance around as I controlled the madness with my right foot. It literally made me giggle like a school girl and all my worries that we may never get that feeling back quickly disappeared with the faint sound of tire squeal. My mad car is back, and it is glorious! I would even go as far as to say it is better, as you no longer get the feeling like you are driving on all seasons with the soft sidewalls, instead you get the razor sharp precision from the stiff and sticky RE-11’s, but at will, you can make the rear of the car do your evil bidding, but at the same time, it just feels so right. Everything is at peace with the world now, as I have my crazy puppy dog car back, or should I say crazy, baby albino rhino? Either way, I could not be happier with the car at this point. Other than the power, it is everything I was hoping the car would be. If you ever find yourself messing up the awesome feel of the stock BRZ with grippy tires, do not hesitate to throw on a set of front and rear swaybars, not only will it reduce body roll, which is what I should have really focused on in this write-up, but they will bring the fun back to the BRZ, which apparently means the most to me! Now I am sure we will upset the handling again in the future, but fear not, I will fight tooth and nail to bring the lunacy back to this car, as I don’t want to take away from what made this car so special to me in the first place.
As always, please let us know if you have any questions.
Thanks,
Rick
Old 09-13-2012, 07:33 PM   #59
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Whoa, are those collars on the factory bar?
Old 09-13-2012, 07:49 PM   #60
RallySport Direct
Member#: 33174
We are Open Late!
Yep! I thought that was pretty cool they have them from the factory.
Thanks,
Rick
Old 09-14-2012, 07:38 PM   #61
RallySport Direct
Member#: 33174
We are Open Late!
Cusco Front Strut Tower Bar Type OS w/ Master Cylinder Brace Subaru BRZ 2013 / Scion FR-S 2013
I’m not going to lie. Looking at the engine bay in the BRZ is less than inspiring, sure it is clean and laid out well, but nothing in there really invites you to take another look, and I at least wanted to put something in there that made it pleasing to the eye. Enter the Cusco Strut bar with the built in Master cylinder Brace. Not only do I love the Cusco blue color, but I figured some added rigidity in the front of the chassis and the addition of the master cylinder brace would be a nice modification to the car all around. Installation was a breeze at worst, but to me, it was a pleasure to install this.
I think this was the first modification I have done to the car where I was not on my back, and elbow deep in grime.
This should have only taken me 20 minutes at most, but after dropping a nut to the strut tower bar on the top of the skid plate, and spending 5-10 minutes trying to fish it out, it ended up taking about 30 minutes to install, and still taking my sweet time. We hooked up a camera in the engine bay to give before and after movement of the master cylinder, and even in person it was amazing to see the brace in action, it truly minimized the movement of the master cylinder.
Now, just cruising around town you may never notice this, but come in a bit hot into a corner and threshold brake, it becomes apparent why these braces are in existence. The BRZ brakes never felt bad in stock form, but after adding the brace, you could feel that the brake response was better, and you gained even more pedal feedback, which is always a plus. Now I was skeptical that the strut tower bar would make a difference, but after cruising though the work “test course” the front end really did feel more… planted? I don’t really know how to put this into words, as "planted" is not right, but basically you can feel that the front end is less independent of the rest of the car, and just more “tied in”, if that makes sense. Don’t think this bar made a night and day difference, because I would never say that, but if you are looking for something to add a bit of shine to the engine bay, the added rigidity to the chassis, and master cylinder brace makes, this a awesome mod all around. This Cusco Strut bar would be something I would recommend personally.
I would like to see if this bar makes any difference on a bone stock car, but I feel like with all of the extra grip we have added, we may be able to actually take advantage of the extra rigidity. Overall I thought it was a fun install, a great looking bar, and did add some extra feel and feedback to the car!
Thanks,
Rick
Old 09-14-2012, 11:00 PM   #62
WRX-Sora
Member#: 325550
2002 wrx
subaru blue
absolutely gorgeous car
WRX-Sora is offline   Reply With Quote
Old 09-19-2012, 10:39 PM   #63
RallySport Direct
Member#: 33174
We are Open Late!
Old 09-19-2012, 10:50 PM   #64
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Rick are you bringing her out to Subiefest?
Old 09-21-2012, 12:20 AM   #65
RallySport Direct
Member#: 33174
We are Open Late!
If you had to choose one, me or the BRZ, what would you pick? j/k.
I don't think we will be bringing the BRZ out, but we will be coming out, and if I play my cards right, I should be tagging along as well!
Thanks,
Rick
Old 09-28-2012, 01:34 PM   #66
Jadickinson08
Member#: 333570
Very nice additions to the car is rally sport direct making a turbo kit for the brz?
Jadickinson08 is offline   Reply With Quote
Old 09-28-2012, 11:31 PM   #67
RallySport Direct
Member#: 33174
We are Open Late!
No, I don't think we will be. Now I do not know if we will or will not add one in the future, but I sure do hope so haha!
Thanks,
Rick
Old 10-09-2012, 09:25 PM   #68
RallySport Direct
Member#: 33174
We are Open Late!
Just wanted to let you guys know we installed the new Invidia N1 with Ti tips on the BRZ Today! Check out the pictures and let us know what you think.
Please stay tuned for more updates as well.
Thanks,
Rick
Old 10-10-2012, 12:52 AM   #69
Jdub.csu
Member#: 283784
2013 EVO X GSR
Sound clip?
Jdub.csu is offline   Reply With Quote
Old 10-10-2012, 01:16 AM   #70
RallySport Direct
Member#: 33174
We are Open Late!
We will be working on the video shortly, and I will post it up as soon as we get it done.
So far I am very impressed, the exhaust looks great with the rear diffuser, and sounds great as well!
Thanks again,
Rick
Old 10-10-2012, 03:05 PM   #71
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Sex!!!!
Boxer112 is offline   Reply With Quote
Old 10-10-2012, 03:13 PM   #72
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
I've read that BRZ's are having issues with hesistation and actually shutting off, have you experienced any issues?
Old 10-10-2012, 11:03 PM   #73
RallySport Direct
Member#: 33174
We are Open Late!
Old 10-11-2012, 01:30 PM   #74
04STIscore
Member#: 305390
2004 STI
JBP
subscribed, great work so far!
04STIscore is offline   Reply With Quote
Old 10-11-2012, 01:35 PM   #75
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Double
RallySport Direct's BRZ: The Albino Rhino RallySport Direct BRZ Forum 179 07-18-2014 11:37 AM
RallySport Direct's 2011 STI Sedan! RallySport Direct NASIOC Project Cars 540 04-07-2014 02:31 PM
RallySport Direct's 2011 STI Sedan! RallySport Direct Rocky Mountains Impreza Club Forum -- RMIC 192 12-27-2010 03:07 PM
RallySport Direct's 2011 STI Sedan RallySport Direct Member's Car Gallery 119 08-25-2010 04:06 PM
OMG - I think I made the theme track to the Spearmint Rhino... sherifx Southern California Impreza Club Forum -- SCIC 9 05-19-2004 05:41 AM
