Old 06-03-2012, 08:10 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Just curious how hard it would be to rewire?
So I'm graduating with my MA next year and will prob. have to move to California, so EJ20G in OBD2 car is prob a bad idea. How difficult would it be to rewire my car from EJ20G to EJ257? I know the 257 has AVCS+modern crank sensors/diff. intake manifold, but would it be a matter of just replacing all of the sensors, or is it more involved?
JDMFLCL is offline   Reply With Quote
Old 06-03-2012, 09:40 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
way more involved .. sell car build new
Old 06-03-2012, 09:58 AM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I hate to do this but your question doesnt make alot of sense and needs significant clarification.
You may need to move to California. OK. Cali is strict on emissions. Well known fact.
Does your car has a EJ20G engine in it currently? Is the engine there from the factory like a RHD JDM or is it a motorswap?
If its a motorswap are you wanting to swap in a full EJ257 drivetrain?
I do not understand your comment about EJ20G in obd2. Are you concerned that installing a standalone Engine management computer that supports OBD2 would go badly? I dont know that one exists but if it was a complete engine management package I doubt it would go badly.
How exactly do you intend to rewire an EJ20G to EJ257? Are you talking about taking the ECU and complete wireing harness from an EJ257 and merging it into the EJ20G wiring harness? Like the wiring harness portion of a motor swap without swapping the motor? Pretty sure it wont work.
If one exists to do what your asking I think you want a whole OBD2 compatible standalone engine management package.
I dont know exactly what your asking (I can only guess) but my best guess is that you do not want what your asking. I suggest instead you look into "the out of state registration requirements" in Cali and start there. If your vehicle is licensed and registered in Colorado or where ever you live you should be able to re-register it in cali when you move there.
TommyAtomic is offline   Reply With Quote
Old 06-03-2012, 04:54 PM   #4
JDMFLCL
Member#: 180513
Baby Baby C'mon!
1.) Yes. Swapped 95 WRX into 99 RS.
I already have a PFC+bolt ons. I'd prefer to have a USDM ecu for plug in purposes/open source tuning
I'm asking how involved is it to rewire the car for the USDM motor.
Old 06-03-2012, 06:52 PM   #5
RallyColtTurbo
Member#: 16819
If you've done it once, you can do it again.
Everything else being equal, there are more wires to run and more things to go wrong. However, having done it once before should put you in front of the curve far enough to make it worth it.
It sounds like you already know the EJ20g has to go and a new motor needs to take it's place.
Idea....maybe you can find somebody that balled thier swap and is parting out a pre-merged harness?
RallyColtTurbo is offline   Reply With Quote
Old 06-03-2012, 06:57 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's just as hard as any other swap.
Remove all the EJ20G wiring, get an EJ257 harness and merge that in.
If you want this to be legal in CA, you need to go all out, the fuel tank and everything else back there needs to go in, all the emissions gear, both cats etc.
Old 06-03-2012, 08:37 PM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
So i'd basically have to start from scratch. Meh.
Old 06-06-2012, 10:29 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no worse, its impossible... i know of one that has been done and the guy had to weld/machine cam gears to match the newer pickup style
Anyone know how much it would cost to do this? (pic inside) trustWRX Off-Topic 93 05-16-2005 10:33 PM
how hard is it gonna be to make my car 4WD Sojuuk Legacy Forum 9 05-19-2004 12:49 AM
anyone know how hard it is to rewire your head lights? Ghostrider Electrical & Lighting 6 03-22-2004 11:14 AM
Just curious, how much would an equal length header help us? Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 9 04-15-2002 09:42 AM
