Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 06-03-2012, 11:38 AM   #1
rice h8r
Member#: 94524
Question How are you supposed to change the rear most spark plugs?
I checked out a Scion FRS at a Scion drive event yesterday and I noticed the rear spark plug on the driver's side seems to be impossible to remove. How are you supposed to take it out? It looked like there wasn't enough room between the valve cover and the frame rail to take out the spark plug let alone fit a ratchet with a socket and extension in there.
rice h8r is offline   Reply With Quote
Old 06-03-2012, 01:11 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Pull the engine.
Old 06-03-2012, 02:00 PM   #3
rice h8r
Member#: 94524
Seriously???
They better have some 100K platinum plugs in there then.
Old 06-03-2012, 03:46 PM   #4
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Originally Posted by rice h8r
Seriously???
I believe they have iridium plugs.
illmatic is offline   Reply With Quote
Old 06-03-2012, 03:48 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Originally Posted by rice h8r View Post
Seriously???
Well if you have a lift, might be easier to just drop it a bit instead.
Old 06-04-2012, 08:45 AM   #6
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Welcome to Subarus.
wcbjr is offline   Reply With Quote
Old 06-04-2012, 10:15 AM   #7
Chrislon
Member#: 126075
05 GRP LGT 5MT
Smayshed
You pull the fender liners out and do it from the wheel wells. It's been covered 100 times.
Chrislon is offline   Reply With Quote
Old 06-04-2012, 04:29 PM   #8
rice h8r
Member#: 94524
^ Have you looked at the engine bay in person like I did?
Like I said in the original post, the one towards the firewall is right against the FRAME RAIL, with the subframe below it and the sway bar right behind it. There was maybe 2.5 inches between the valve cover and the frame rail for the driver's side. I didn't take a look at the passenger side.
Old 06-04-2012, 07:38 PM   #9
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
apparently the way to change the rear plugs is to lift the engine about 5 or so inches.
2pt5RS is offline   Reply With Quote
Old 06-11-2012, 07:02 PM   #10
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Find a friend with skinny fingers. I broke stuff on my WRX replacing plugs, we'll see if I even try it on the BRZ.
2point0 is offline   Reply With Quote
Old 06-11-2012, 08:23 PM   #11
RallyColtTurbo
Member#: 16819
Are you sure there isn't a hole in the sheet metal to allow a socket and extension to get in there from the wheel well?
RallyColtTurbo is offline   Reply With Quote
Old 06-11-2012, 10:53 PM   #12
rice h8r
Member#: 94524
I didn't see any holes and it seemed like there wasn't enough room between the valve cover and the frame rail to take the spark plug fully out of the hole to be able to slide it out.
Could someone take some photos to show what I'm talking about? I'm an idiot for not doing so.
Old 06-12-2012, 03:01 AM   #13
scramjett
Member#: 192526
2008 WRX FMIC/VF48
Red/Steel Grey
The driver side plugs on my WRX was a royal PIA (especially the rear). You know what works... Here's what I did: just apply enough torque to break the plugs loose. Then use some properly sized vacuum hose or water hose and snake it in there onto the plugs. The hose while "snaked" and not straight can be rotated counter clockwise and ... presto! Plugs come out. To insert, do the same thing in reverse.
The key is the properly sized hose to fit over and "grab" the plugs, and the key is that the hose can be all "S" shaped and still rotated (spun).... IDK, maybe the BRZ is even worse than the driver rear on my WRX.....
scramjett is offline   Reply With Quote
Old 06-12-2012, 12:52 PM   #14
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
The BRZ requires you to lift the engine to access the rear spark plugs...
Opie is offline   Reply With Quote
Old 06-12-2012, 10:08 PM   #15
immortal_suby
Member#: 1711
140 rogue points!
2013 GBS BRZ Limited 6MT
Can't be any harder than the svx plugs.
immortal_suby is offline   Reply With Quote
Old 06-15-2012, 09:56 AM   #16
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
There is a secondary hood prop mounting location (pull the stock one out from the radiator support) on the strut tower. The hood will sit vertical.
Then you raise the motor (unbolting / removing all applicable bolts / parts neccessary) about 5-6 inches, be very careful not to kink or break the a/c lines when raising the motor.
That will let you services the plugs.
Illusive is offline   Reply With Quote
Old 06-15-2012, 09:56 AM   #17
Illusive
Member#: 90436
2005 STI
Double internet post fail, please delete
Old 06-25-2012, 04:17 PM   #18
nquillen
Member#: 323734
Illusive's post is the way the service manual describes. I'm hoping someone comes up with a "trick" way of doing it.
nquillen is offline   Reply With Quote
How often do you need to Change the rear differential fluid in a 2001 Outback Sport? chillington Service & Maintenance 6 09-02-2005 03:01 PM
Are you supposed to tip the room service people? Fach Off-Topic 17 08-25-2004 11:51 PM
are you supposed to buy the boss a gift? catass Off-Topic 34 12-15-2003 01:14 AM
How are you supposed to torque a fluid line? Corn-Picker Service & Maintenance 5 01-02-2002 05:56 PM
