Old 06-03-2012, 12:07 PM   #1
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Default EJ20K running rich
So my car is all running now with Apexi PowerFC and tuned up and it's running super rich I believe. After cruising a few miles, there's a bunch of soot in my tailpipe. I was getting horrible gas mileage for a while, then I filled up at a Texaco later and it was doing just fine?
At times, it smells like it's catless, but it isn't; it's stock downpipe.
The car does fine at low speeds in the lower gearing, but struggles on hills particularly and higher speeds. It sputters and struggles, and I can definitely hear the BPV sputtering while trying to make boost. Why is this?
Cruising at about 60, it does great and I get pretty good gas mileage.
Mods:
-Apexi N1 catback
-Apexi Power Intake
-Walbro 255 fuel pump
-Apexi PowerFC
Last time I checked, the spark plugs were clean, but should i check them now?
Smoke is offline   Reply With Quote
Old 06-03-2012, 03:07 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
Can you distinguish closed from open loop?
eg33GC is offline   Reply With Quote
Old 06-03-2012, 05:26 PM   #3
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Well, these terms are still a little new to me.
It seems to be struggling a little above 3000 rpm on hills (open loop?) and bogs down, slowly making it up.
So it's a little difficult to tell the difference.
Idles just fine.
Old 06-03-2012, 06:59 PM   #4
RallyColtTurbo
Member#: 16819
IIRC, the PFC doesn't use closed loop like a factory ECU. It only tries to use closed loop on cells programmed with 14.7:1 (or very close to it).
Most of the advice I have been given is to disable closed loop altogether until you like your map.
RallyColtTurbo is offline   Reply With Quote
Old 06-03-2012, 08:55 PM   #5
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I feel so dumb right now, but SO relieved.
The BPV hose popped off and it was just hidden enough for you to think it's attached.
I attached it and runs like a charm now. Even runs like normal now on hills.
However, at high boost, it pops off...I'll find a better solution.
Check engine light flashes too, but I remember the tuner told me because 18.2 psi is a lot for a VF24.
Old 06-04-2012, 05:22 PM   #6
RallyColtTurbo
Member#: 16819
Flashing CEL on a PFC usually means knock is above the programmed threshold.
Old 06-04-2012, 06:06 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Is there any way to get rid of that?
Old 06-04-2012, 08:28 PM   #8
RallyColtTurbo
Member#: 16819
If it's real knock, you need to tune it out.
If it's false knock, either Apexi's software or Datalogit software will allow you to change the value that it flashes at. The handheld Commander does not have access to this parameter.
Old 06-04-2012, 08:50 PM   #9
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I had it professionally tuned, so I hope it's not the tune issue.
It does have the FC Datalogit.
Old 06-07-2012, 11:35 AM   #10
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
the flashing CEL could be one of 3 things. your maxing out your injectors, your maxing out your MAF sensor, or you're hitting your knock count threshold which is 60 out of the box but can be set to whatever you choose.
at 18psi, I'm willing to bet your MAF is at its limits
simer1228 is offline   Reply With Quote
Old 06-07-2012, 02:22 PM   #11
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
It's at max boost, my tuner said. It would make sense my MAF is also at it's limit as well.
I'm guessing 18 psi is definitely the max of the VF24.
Would it be bad if I got a turboback?
Old 06-07-2012, 08:36 PM   #12
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
How could that possibly be a bad thing?
TommyAtomic is offline   Reply With Quote
Old 06-08-2012, 10:37 AM   #13
simer1228
Member#: 171039
99 RSTi Type-R LTD
Black Diamond Pearl
I would find out why your PFC is flashing the CEL first before any more modifications.
I realized there's a good chance you could be maxing out your injectors too/instead. I'm running 1.2bar(17.4psi) on my VF28 with stock 550cc injectors. At WOT my injector duty is hitting mid 90's. That's after leaning out my A/F ratio to 10.6-10.8 : 1.
Running Rich and Rough Idle after runs for a while 0wrx6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 04-15-2011 12:23 PM
help make my ej20k run PhilbertGodphry Newbies & FAQs 1 11-02-2009 08:35 PM
MBC WRXes running rich? jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-03-2001 02:55 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
MY00 Running Rich (C.E. Light) w/ Cobb Intake, Stromung Exhaust Swivel1000 Normally Aspirated Powertrain 8 03-11-2001 03:21 PM
