Old 06-04-2012, 04:40 PM   #1
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Default 5lipstream's 03 WRX
2003 Impreza WRX Sedan
Engine
Gruppe-S EJ257 Short block
--New Subaru EJ25 STI Engine case
--New Subaru STI Forged Crankshaft (balanced and nitrided)
--Cosworth bearings
--100mm Wiseco pistons
--Helix H beam rods
--ARP hardware
Ported and polished EJ205 heads
--3-angle valve job with combustion chamber work
--Kelford 272 cams
--Ferrea competition valves
--Ferrea guides, springs, retainers
--ARP hardware
Fastech Motorsports intake manifold
RMR 90mm throttle body with CNC machined adapter
Custom Peterson Fluid Systems catch can
Koyo radiator
Custom radiator overflow can
Samco radiator hoses
All lines except radiator hoses converted to AN
PWR oil cooler with Mocal thermostatically controlled sandwich adapter
Powder coated alternator with all new stainless hardware
Just about every bolt under the hood replaced with stainless
Fuel
Dual in-tank Walbro 255lph Replaced with a single Walbro 416 (7/28/12)
Earls AN -8 braided stainless supply line
Jegs AN -8 fuel filter
Custom fuel rails using RMR extrusions
Precision 1200cc injectors
Aeromotive FPR
AEM injector driver
Turbo kit & Exhaust
Precision 6266 CEA Billet Turbocharger (Polished compressor housing, Ceramic coated turbine housing)
Fastech Motorsports custom rotated up-pipe
Fastech Motorsports custom downpipe
Fastech Motorsports custom stainless exhaust (Burns Stainless components)
Gruppe-S exhaust manifold
Entire exhaust and turbo hotside housing ceramic coated at NitroPlate
Fastech Motorsports custom intercooler
Fastech Motorsports custom charge pipes
Fastech Motorsports custom intake pipe (K&N filter)
2-stage boost controller Replacing this with a MAC valve so AEM can control boost
Ignition & Electrical
AEM Series 1 EMS
New OEM coil packs
X2Power AGM battery relocated to trunk
Drivetrain
Full PPG 5MT
--Straight-cut, synchromesh 1-4, helical 5th
--Billet selector forks
--Billet transfer gears
ACT Clutch
Stainless clutch line (clutch delay valve deleted)
Carbonetic front LSD
Quaife rear LSD
B&M short throw shifter
Cusco engine and transmission mounts
Agency Power pitch stopper
Suspension/Chassis/Steering
Buddy Club Racing Spec coil overs
Adjustable pillow ball upper mounts
JDM carbon fiber STi strut tower bar
JDM aluminum STi LCAs
Whiteline ALK
Whiteline LCA bushings
Whiteline bumpsteer correction kit (lower ball joints and tie rod ends)
Cusco 21mm front sway bar
Cusco 24mm rear sway bar
Whiteline diff mounts
Custom aluminum power steering reservoir
All PS lines replaced with AN
Urethane steering rack bushings
Body
JDM V7 STi grille
JDM V7 STi HID projector headlights
JDM V7 STi v1 lip spoiler [waiting to be painted + installed]
JDM V7 STi Aeroguards front and rear [waiting to be painted + installed]
JDM V7 STi Strakes [waiting to be painted + installed]
APR GTC-200 wing
Carbon fiber side-marker covers
APR Carbon splitter [not installed yet]
Interior
Full interior from 2006 STi
06 STi instrument cluster
Worldsport stainless steel 540 gram shift knob
ATI 3-gauge hood
AEM Wideband gauge
Defi boost gauge
AEM serial gauge
Brakes
Stock WRX brakes (5x114.3 Brembos purchased 8/1/12 - Install this fall)
Hawk HP+ pads
Unknown brand slotted rotors (Replacing with DBA this fall)
Wheels & Tires
17x8.5 5Zigen FN01R-C (Replacing this fall TBA)
5Zigen lug nuts (Replacing this fall TBA)
BFGoodrich KDW 235/45-17 (Replacing this fall TBA)
Teaser pic:
Next Mods:
- 04+ STi rear bumper
- 04+ STi rear over-fender trim
- 04-05 tail lights
- New paint job
- 5x114 / Brembo conversion
- New wheels and tires
- Replace 2 stage boost controller with MAC valve so the AEM can control it.
- Cage
- Racing seats
- When AEM releases flex-fuel option for Series 2 EMS, I'm going to upgrade (I have a series 1) and go E85
5lipstream is offline   Reply With Quote
Old 06-04-2012, 04:41 PM   #2
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Exterior Shots
(Top few pics are the most current)
(From a couple of years ago)
Old 06-04-2012, 04:41 PM   #3
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Exhaust Pics
Turbo Pics
Old 06-04-2012, 04:42 PM   #4
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Engine Pics
(Newest on top)
Old 06-04-2012, 04:49 PM   #5
vooch
Member#: 322201
Looks great!
vooch is offline   Reply With Quote
Old 06-04-2012, 04:51 PM   #6
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Engine Pics Continued
(Last Year - GT4094R)
Power Steering
[Reservoir]
[Lines]
Oil Cooler
Old 06-04-2012, 04:59 PM   #7
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Old 06-04-2012, 06:52 PM   #8
|Rev|
Member#: 100651
2010 STI
Freakin sweet build man. I'm loving it.
|Rev| is offline   Reply With Quote
Old 06-04-2012, 09:30 PM   #9
Boost is Best
Member#: 102858
15' WRX
ISM
Beast Mode!
Boost is Best is offline   Reply With Quote
Old 06-04-2012, 09:37 PM   #10
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
Wooow!
waynoSTI is offline   Reply With Quote
Old 06-04-2012, 09:39 PM   #11
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
looks good. what size drill bit did you use on those turbo holes? I'm gonna do it on mine
rjrutzky is offline   Reply With Quote
Old 06-05-2012, 12:50 AM   #12
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Haha come on now.
Bad ass build, but how is this a 2.65L? 79mm crank and 100mm pistons is still a 2.48L really...
domestic_abuser is offline   Reply With Quote
Old 06-05-2012, 09:11 AM   #13
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Mr. Bawb... you can use whatever size drill bit you want. Bigger is better.
Originally Posted by domestic_abuser View Post
Haha come on now.
Oops... It's an 83mm crank. Which still only makes 2.6L so I'm not sure where the other .05L is supposed to come from. It was a Gruppe-S crate motor.
Old 06-05-2012, 10:24 AM   #14
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Car looks great!
2.5L Monster is offline   Reply With Quote
Old 06-05-2012, 10:33 AM   #15
B.R.E.D
Member#: 289606
06 WRX
white
Looks like a awesome build. Those rods really scare me at 600whp though.
B.R.E.D is offline   Reply With Quote
Old 06-05-2012, 10:59 AM   #16
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
I don't like them either. I would also have preferred that the block be sleeved. I bought the car with this motor in it from a friend. It's "supposed" to be fine to 700hp but we all know the difference between advertising and fact.
Most of the time the car will be on 93 octane and closer to 500whp.
This fall I'm going to start building a sleeved e-85 motor in the garage. It'll have much stronger internals and higher CR. Then I can turn the juice up to the 650-700 range.... That is unless I find a GTR in the $45k range then all bets are off.
Old 06-05-2012, 11:19 AM   #17
Slow_2.5
Member#: 292104
2006 Jawny jawn
Burple
Please tell me you got rid of that wing.
Slow_2.5 is offline   Reply With Quote
Old 06-05-2012, 11:43 AM   #18
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Haha the APR wing? No wayss! lol I'm having new 1 piece supports made to get rid of the little 2 1/2" risers. I know the wing is a bit much given the lack of any other aero but it'll all fit together once I'm done. I'm getting a JDM STi Ver2 lip, aeroguards and strakes, painting the side skirts, and getting either a Voltex or HKS diffuser. That should balance it all out.
Something along the lines of this:
Old 06-05-2012, 12:01 PM   #19
RallySoob
Member#: 74872
2006 STi
White/Black
Illmatik! ...you win
RallySoob is offline   Reply With Quote
Old 06-05-2012, 07:20 PM   #20
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
101mm pistons give you 2.65L and 102mm gives you the 2.7L but both require sleeves. Either way you have a bad ass car, no hate here.
Old 06-05-2012, 10:01 PM   #21
dudley123
Member#: 120831
PIA Purpose Built -
SEMA-FullRace/HRE/Cosw.
I like what I see.. should look awesome with the karltons!
dudley123 is offline   Reply With Quote
Old 06-06-2012, 09:16 AM   #22
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Yeah I think there may have been some confusion with the previous owner. I do know for sure that it isn't sleeved though. We gave him a lot of **** for cheaping out on that part when he did the original build.
Old 06-11-2012, 09:14 AM   #23
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
My friend Mike Zusin, owner of Track.One in Franklin, TN took a few pics this weekend while his awesome fabricator made me a new wastegate dump tube.
New Wastegate dump tube
Old 06-15-2012, 01:58 PM   #24
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
This thing is unreal!
JohnnyWas is offline   Reply With Quote
Old 06-20-2012, 12:23 PM   #25
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
6/18/12 - Started tuning the car Sunday night. Car was making boost VERY early. Like 3500rpms. That's at least 1500rpms faster than the old turbo.
Anyway, at about 5200rpms and somewhere around 16-18psi it goes lean as hell no matter how much fuel we add in the AEM. The tuner thinks it is the injector driver. I also want to check if the fuel filter is clogged. I had a clogged injector from where we replaced all the AN lines and I must have left some trash in the lines. I'll be checking the filter tonight.
Mike at Track.One has another injector driver he will let me try out. Hopefully its something simple.
6/19/12 - Ordered the Whiteline bumpsteer correction kit. I needed new tie rod ends and ball joints and the car is obviously lowered so it was a no brainer.
working on my 03 wrx with 2.0 heads and 2.5 SB, need feed back please! swhwrx Subaru Conversions 12 05-01-2012 01:41 PM
Why wont this Work? 03 wrx with 2.5 Swap Using WRX Intake Mani and Jdm ecu for avcs Ostrowrx Built Motor Discussion 3 02-11-2012 05:12 PM
FS : 03 WRX wheels, 2 studded 2 bare rsdawg Wheels/Tires 3 09-14-2010 08:20 PM
CA - 03 WRX with 2.5L shortblock and more! blueaway Private Vehicle 'For Sale' Classifieds 5 04-17-2008 06:10 PM
03 WRX in 2 mos. & STi in 6 mos.? anim8 News & Rumors 15 03-18-2002 06:34 PM
