Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 06-04-2012, 04:41 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW Brake Master Cylinder Brace
NEW Brake Master Cylinder Brace For 2008-2012 WRX and STI
WHAT DOES IT DO?
The PERRIN Master Cylinder Brace locks down the master cylinder preventing unwanted movement due to a weak firewall. Allowing the driver to regain maximum braking force and increased pedal stiffness.
REDUCE FLEX
The thin sheet metal firewall isn't able to deal with the constant forces from repeatedly applying the brakes in all conditions. Over time it begins to flex and give as the brake pedal is depressed. The PERRIN Master Cylinder Brace creates a bridge between the firewall, master cylinder and shock tower, eliminating flex in the firewall while braking.
STIFFEN UP YOUR BRAKE PEDAL FEEL
The PERRIN Master Cylinder Brace eliminates the flex at the firewall, so you feel nothing but solid pedal feedback with every application of the brakes. Even slowing for a stop sign, the difference can immediately be felt after installation of the PERRIN Master Cylinder Brace.
CONSTRUCTION
The PERRIN Master Cylinder Brace is constructed of CNC Machined 6061 aluminum, and CNC formed Steel. This combination of different materials are used to add extra support compared to other systems. Making this from two CNC parts instead of a series of welded steel pieces, keeps the part extremely stiff as well as very light.
DESIGN
We constructed this part to bolt to three different surfaces around your shock tower. One surface runs parallel to the master cylinder, one perpendicular and another perpendicular but on a different plane. Triangulating the mounting points reduces flex even further than single plane designs.
FINISH
The aluminum portion is anodized black with a bold PERRIN logo laser engraved into the upper surface. The steel section is wrinkled powder coated in your choice of three colors to match your other PERRIN parts. Perfectly combines an aesthetic improvement to your engine bay as well as braking feel!
5 YEAR WARRANTY
PERRIN Performance warrants to the original purchaser, all PERRIN products to be free from defects in material and workmanship within a sixty (60) months period from the date of purchase.
Click HERE To Check These Out On The PERRIN Performance web Site
PERRIN is offline   Reply With Quote
Old 06-05-2012, 09:55 AM   #2
MotorolaBizz
Member#: 119290
2004 WRX 4EAT
Java Black Pearl
Like this new design
MotorolaBizz is offline   Reply With Quote
Old 06-07-2012, 09:38 PM   #3
cameredi
Member Sales Rating: (4)
Member#: 302950
2012 Impreza STI
Pearl White
Default Awesome product
I have had this on My STi for a While and I can say it is incredible, Really easy to install and you will have a WOW moment first time you hit the brakes. It does an excellent job of removing flex from the firewall and which in turn allows a much better firmer feel to the brake pedal. The older version was good and like everyone elses. This one spread the force out over a larger area so it just works better
Damn good Job Perrin, keep it up I need more goodies for My STi
cameredi is offline   Reply With Quote
Old 07-12-2012, 03:10 AM   #4
rlowery78
Member Sales Rating: (10)
Member#: 181076
2013 STI Hatch
Got it, Love it! Thanks Guys!
rlowery78 is offline   Reply With Quote
Old 03-20-2013, 09:05 PM   #5
exemptrevision
Member#: 328998
2011 Impreza WRX STI
I have to take out the intercooler for this one lol i don't have small enough hands to get to the two vertical bolts holding the one bracket in place
exemptrevision is offline   Reply With Quote
Old 07-07-2013, 06:28 PM   #6
2011boosted
Member#: 330937
2011 wrx
satin white
Got this from perrin. Love it Could tell a diff. Right away. Took me awhile tho cause i was tryin to make short cuts and ended up takin me longer haha
2011boosted is offline   Reply With Quote
FS : socal: grimmspeed brake master cylinder brace, PIAA si-tech wiper blades ALL NEW Blackout713 Engine/Power/Exhaust 6 06-13-2011 02:05 PM
FS : MI New Cusco Brake Master Cylinder Brace For Sti Wrx justanothrgi Suspension/Brakes/Handling 6 10-27-2010 10:52 AM
FS SoCal: Cusco Brake Master Cylinder Brace STI'sOnly Suspension/Brakes/Handling 10 01-15-2009 11:14 AM
Cusco Brake Master Cylinder Brace sndc5 Suspension/Brakes/Handling 5 08-22-2008 09:21 PM
Perrin Brake master cylinder brace, Spec Stage 2+ clutch Disk, Kartboy Pitch Stop powerlabs Drivetrain 8 09-30-2007 04:37 PM
