South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 06-05-2012, 03:18 AM   #1
BACANA
Member#: 285053
1998 2.5L
fake WRB
Default engine fired up, oil everywhere!!!!!!
So after way to long, my wrx is all put back together! but then when i went to start her up i got nothing...
it appears that i have a P0335 crank sensor malfunction, does this mean i need to replace the sensor? i read that this can happen when adding a light weight crank pulley (which i did). i tried clearing the code, unplugging the sensor and plugging it back in, but to no avail still not cranking or even tring to kick over
suggestions??
BACANA is offline   Reply With Quote
Old 06-05-2012, 03:49 AM   #2
Converted STi
Member#: 227723
20XX 5.0
Booosssttttteeeddddd
I would suggest checking the wires and plug, and if that doesn't work try a new sensor. The crank pulley shouldn't throw the code till after the car has run for a while, and those are generally misfire codes from what I have seen.
Converted STi is offline   Reply With Quote
Old 06-05-2012, 03:59 AM   #3
BACANA
Member#: 285053
1998 2.5L
fake WRB
the wires seem fine, but its been a long night so im gonna call it quits and start looking for more solutions in the morning before work
Old 06-05-2012, 04:31 AM   #4
Converted STi
Member#: 227723
20XX 5.0
Sounds like a good idea. I would assume that it would be the sensor if the wires and plug are intact, but then again you know how effective online diagnostics are.. haha, good luck man.
Old 06-05-2012, 05:47 AM   #5
brocksdad
Member#: 107352
Not Respectable
I just did a quick search and found this
http://forums.nasioc.com/forums/show...2020700&page=2
Originally Posted by Audiosavvy View Post
UPDATE- problem solved.
It was the battery. It tested fine in every way, but after leaving the car sitting for the last 6 months (been driving my other DD) I tried another battery just for giggles, and it solved the problem. I didn't have another battery before, and didn't want to buy one just to try, but ended up having one given to me, and so I tried it.
I'm still baffled how a battery could have caused this, since it wouldn't start immediately but would start after many cranks.
Does anyone have any insight as to how it could do this? I would assume that if the battery didn't have the oomph on the first 100 cranks, why would it magically work after try # 101?
Thanks to everyone who contributed, and yes, I do feel like a moron for it being so simple
brocksdad is offline   Reply With Quote
Old 06-05-2012, 11:28 AM   #6
Momosaurus WRX
Member#: 214737
That's such a weird problem.
Momosaurus WRX is offline   Reply With Quote
Old 06-05-2012, 11:31 AM   #7
BACANA
Member#: 285053
1998 2.5L
fake WRB
yeh i saw that too, but my battery is brand new, however i cleaned the battery cables anyways... nothing, now i guess i should check grounding.
how many grounds should there be?
-1 on the fender by the battery
-2 on either side of the intake manifold
Old 06-05-2012, 12:08 PM   #8
BACANA
Member#: 285053
1998 2.5L
fake WRB
a new crankshaft sensor from subaru is $100!?! wtf!
Old 06-05-2012, 12:10 PM   #9
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
lol maf sensors are like $300
07VTRex is offline   Reply With Quote
Old 06-05-2012, 01:48 PM   #10
BACANA
Member#: 285053
1998 2.5L
fake WRB
well chandler subaru hooked me up with a new sensor, installed it... and... same freaking story!!!!!!!!!!!!
Old 06-05-2012, 01:54 PM   #11
BACANA
Member#: 285053
1998 2.5L
fake WRB
could it be my viper alarm system?? the car has sat for 3 months with no battery, anyone know about these things locking up the starter, or how to fix it?
Old 06-05-2012, 02:40 PM   #12
DooDooPWR
Member#: 224088
04 WRX
was the crank sprocket replaced? ive seen people accidentaly put an NA crank sprocket on a turbo car and have similar issues.
DooDooPWR is offline   Reply With Quote
Old 06-05-2012, 02:41 PM   #13
DooDooPWR
Member#: 224088
04 WRX
-1 in the back of the starter flange
Old 06-05-2012, 02:44 PM   #14
Evil Imports
Member#: 14732
+ 13 B8
Did you put the timing belt on correct?? there is 2 marks on the crank gear, a line and a arrow, what one did you use?
Evil Imports is offline   Reply With Quote
Old 06-05-2012, 02:46 PM   #15
BACANA
Member#: 285053
1998 2.5L
fake WRB
Car started! Thx to Yman and momosaurusrx. But the it revved up to 4k on its own and spot about a quarry or two of oil on the ground... New problem lol
Old 06-05-2012, 02:49 PM   #16
03.dub.r.x
Member#: 307997
1996 Impreza
Glacier White (230)
maybe that i had viper alarm in my truck set off the dash ( made it look like a year round xmas tree) and started having problems such as not startin up. took that crap off now starts runs without issues.
edit: noticed you started it after i put my 2 cents in
03.dub.r.x is offline   Reply With Quote
Old 06-05-2012, 02:57 PM   #17
Evil Imports
Member#: 14732
+ 13 B8
sounds good for a brand new motor
Old 06-05-2012, 03:02 PM   #18
BACANA
Member#: 285053
1998 2.5L
fake WRB
looks like its the hard oil line under the turbo that is the culprit of the oil spitting, but what would cause it to rev like that?
Old 06-05-2012, 03:31 PM   #19
yman
Member#: 199051
04 sti
psm
bad idle air control valve or maf sensor?
yman is offline   Reply With Quote
Old 06-05-2012, 03:57 PM   #20
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Vacuum leak.
Old 06-05-2012, 04:12 PM   #21
02blkwagn19
Member#: 146496
02 WRX Wagon 2.1L
Built not bought. #0003
Originally Posted by kpluiten
Vacuum leak.
This.
Or check your throttle cable and make sure it's not hung up on anything. Happened to me before.
02blkwagn19 is offline   Reply With Quote
Old 06-05-2012, 04:25 PM   #22
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
Vacuum leak.
This. Fix leaking maf o ring
dirtslayer is offline   Reply With Quote
Old 06-05-2012, 04:46 PM   #23
BACANA
Member#: 285053
1998 2.5L
fake WRB
Like where it connects in the air intake?
Old 06-05-2012, 04:53 PM   #24
dirtslayer
Member#: 242550
olive drab
Yeah. That's the first thing I check on peoples cars. Most leak it seams like.
Pull the two screws and pull maf out to replace o ring.
Did you happen to install a new maf pipe?
Old 06-05-2012, 05:01 PM   #25
yman
Member#: 199051
04 sti
psm
oh btw that o-ring usually isn't in stock at the dealership, you're gonna have to find a hardware store that carries o rings...
Holy crap my wrx almost burned to the ground 92XXX Electrical & Lighting 16 02-01-2010 07:17 PM
selling my car, 03 WRX, almost stock SETH L TXIC Private Classifieds 3 02-06-2007 09:55 PM
I almost wrecked because a F-18 buzzed my WRX The_Triton Off-Topic 19 04-22-2005 07:33 PM
