Old 06-05-2012, 11:17 AM   #1
Bariga
Member Sales Rating: (32)
Member#: 179846
07 STi Limited
EFR 7670 TS
Default Perrin Engine Mounts
Installation:
Installation of the mounts went like butter due to removable studs! This makes clutch changes so much easier as you don't have to jack the motor up all the way!
Usage:
The mounts are a bit stiffer than Group N mounts i had before on the car! They fall in between GroupN and Cusco Soild Mounts! Not to soft not to stiff where your teeth fall out
they are interlocked inside, and will not rip or break "per. Jeff"
Highly recommend this if you use GroupN or soild mounts to stiff for your daily driver!
Bariga is offline   Reply With Quote
Old 06-11-2012, 07:41 PM   #2
reid-o
Member Sales Rating: (3)
Member#: 103631
2004 STI
Are these available at this moment? I can't find them on the website.
reid-o is offline   Reply With Quote
Old 06-13-2012, 10:13 PM   #3
666stars
Member Sales Rating: (8)
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Yes more info Please!
666stars is offline   Reply With Quote
Old 06-14-2012, 02:44 PM   #4
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
These are not available yet, we have a few test mules out there .....
expect to see them late summer to early fall.
PERRIN is offline   Reply With Quote
Old 06-14-2012, 02:44 PM   #5
PERRIN
NASIOC Manufacturer
Member#: 6776
How the heck did this double post?
Old 06-14-2012, 05:09 PM   #6
silverhks
Member Sales Rating: (2)
Member#: 242402
Would you consider these SCCA autox ST class legal? If you don't know the rules I can be more specific
silverhks is offline   Reply With Quote
Old 08-10-2012, 12:01 AM   #7
weps
Member Sales Rating: (1)
Member#: 183495
WANT. Perrin; I can has yet, please?
weps is offline   Reply With Quote
Old 08-10-2012, 01:19 PM   #8
findurpath
Member Sales Rating: (10)
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
ST rules state that it can't have more "volume" of metal than the stock mount and this one obviously does.
findurpath is offline   Reply With Quote
Old 08-10-2012, 02:18 PM   #9
Speedster329
Member Sales Rating: (72)
Member#: 214652
2004 STI !
JBP !
Wow dosent look bad hopefully ill be in the market for some new mounts
Speedster329 is offline   Reply With Quote
Old 08-13-2012, 03:27 AM   #10
pariah48
Member#: 300705
2002 wrx
Very interested in this, looks like a good alternative to solid mounts
pariah48 is offline   Reply With Quote
Old 09-18-2012, 03:19 PM   #11
lancelucas
Member Sales Rating: (43)
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
I've also got a set of the pre-production ones like Bariga and I must say that I also found them to be a quite pleasant upgrade from GroupN that are still not quite as rough as the hard mount options.
I've battled a driveline shudder on clutch engagement ever since I went to an ACT 6-puck and adding these mounts with a solid pitch stop has made a huge improvement. I previously had issues getting the car cleanly into 2nd gear on the 1-2 shift; even during daily driving the 2nd gear shift was always "mushy". Shifts into all gears now feel improved!
I ended up raising idle 100 RPM as per the instructions to smooth out a bit of vibration in the cabin, but my car is well modified and has cams and every other bushing in the book, so I don't think most people will find this neccesary.
Installation of these is eased by the removable stud/bolt, no doubt. Using a flex-head 1/4" ratchet with shallow 14mm socket made removing and installing the rearward bolts a snap. I did have to re-raise the engine a tad and use a pry bar to re-center the engine in the cradle after initially dropping it, but that's normal for the job.
Great product. Thanks Perrin!
lancelucas is offline   Reply With Quote
Old 09-19-2012, 04:49 PM   #12
PERRIN
NASIOC Manufacturer
Member#: 6776
These are available NOW!
Old 10-07-2012, 01:44 PM   #13
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Thanks for the info, I will be tossing these on my 04 when its time to drop the engine back in her :-)
Scuby04STi is offline   Reply With Quote
Old 10-09-2012, 07:04 AM   #14
Battlewagon98
Member#: 334582
Mine fit like a glove on my 98 and on my 10 STI. Really stiffened up the battle wagon and the STI instal was crazy easy. Well, as motor mounts go. Def recommend! It really helped put more confidence behind the wheel bc I didn't feel as much give. All in all the STI rumbled a bit more but it helps put the baby to sleep so I can't complain.
Ya, being a parent and an autocross junkie don't always go well together but I won this one! No couch for me!
Battlewagon98 is offline   Reply With Quote
Old 04-16-2013, 09:44 PM   #15
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Got the mounts as planned, one of the best choices I have ever made. Motor practically fell into place.
Old 04-21-2013, 08:57 PM   #16
5.56x45
Member#: 305538
How hard was the installation for these?
5.56x45 is offline   Reply With Quote
Old 04-22-2013, 08:53 PM   #17
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
In my case extreemly easy (engine was already pulled out) but if that was not the case it would have still been easy seeing that you just need to lift the engine and set it back down after switching them. Not having a stud also drastically helps with pulling and re installing the engine.
Old 05-14-2013, 03:16 AM   #18
REXXYY
Member#: 265754
2003 STI
Hi I have the Perrin engine mounts and pitch mount rod installed into my STI and was wondering if anyone else running this has experienced any sort of extra vibration at times? I was told it may be due to the more solid mounts but Im just wondering if it may be something different that I should be worried about?
Thanks.
REXXYY is offline   Reply With Quote
Old 05-14-2013, 10:46 AM   #19
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
I have all their engine and tranny mounts, I don't have hardly any vibration. The little there is is not something that would have caused worry. How serious is it?
Old 05-15-2013, 08:16 AM   #20
REXXYY
Member#: 265754
2003 STI
It is pretty bad. It is not there all the time though. I can feel it though the floor and pedals.
Old 05-15-2013, 07:25 PM   #21
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
yeah I would get that looked at. I dont see these mounts being the issue, more something that pointed out an issue.
Old 05-16-2013, 12:35 AM   #22
REXXYY
Member#: 265754
2003 STI
Thanks I will get it checked out.
Old 08-30-2013, 05:56 AM   #23
WelDun1
Member#: 249130
1999 Ver5 STi RA
It seems like these are a Must for new Builds. They better be as good as the Hype, cuz $600 for the Engine/tranny mount set is kinda steep!
Engine/Tranny Mount set:
Megan:$190
Group N:$230
Cusco:$320
Beatrush$400
Hard race:$410
Perrin:$600!!!
WelDun1 is offline   Reply With Quote
WRX/STI TGV's, Intake Manifold, Perrin MBC, Engine Mounts, etc.. urlosn Engine/Power/Exhaust 7 11-29-2008 07:07 PM
STi Heavy Duty engine mounts vs.Stock WRX engine mounts Aspenbullet Transmission (AT/MT) & Driveline 16 04-30-2008 09:13 AM
SMC Alcohol Kit, Cusco Engine Mount & Group N Engine Transmission Pitch Stop Mounts Sti_ck_IT Engine/Power/Exhaust 27 07-23-2007 02:11 PM
FS: almost new Perrin blue IC hoses and sti engine mounts JoeJohnson North West Impreza Club Forum -- NWIC 1 05-11-2005 07:25 PM
Group N engine mounts, Perrin filter Trevor723 Private 'For Sale' Classifieds 12 03-23-2005 03:08 PM
