Old 06-05-2012, 10:49 PM   #1
elbertmurphy
Member#: 268256
2005 STI
Question Looking for advice on radiators
So I've been looking at replacing my radiator with an aftermarket one. I don't have the cash for a koyo and I've found reviews and youtube clips saying their fresh out of the box mishimoto's are leaking so that has steered me away a mishimoto. How are the Megan racing radiators, or the GMS ones? I know IIR sells a lot of GMS radiators, and Megan racing has some good stuff out there... Please send some advice my way
elbertmurphy is offline   Reply With Quote
Old 06-06-2012, 12:12 AM   #2
02wrxej208
Member Sales Rating: (10)
Member#: 295496
2002 ej208 vf34 wrx
I would steer away from Megan, I recently purchased the GMS radiator and mishimoto thermostat combo from IIR, Josh got me a great deal and it was here in 2 days, the welds are beautiful, its clean, I have turned it upside down and no signs of any spot where it would leak. The car is out of commission for a spun bearing so I cannot contest too its effectiveness however. Also I had the right bolts laying around(stock fan bolts won't work) and the oem fans mounted right up with 0 issue. and with a lifetime gaurantee where can you go wrong?
02wrxej208 is offline   Reply With Quote
Old 06-06-2012, 03:16 PM   #3
elbertmurphy
Member#: 268256
2005 STI
What was the issue with the bolts not working(too big or small), and how much did the radiator and thermostat combo run you?
Old 06-06-2012, 03:49 PM   #4
Strider327
Member Sales Rating: (12)
Member#: 131280
2004 Impreza WRX
Just get a Koyo one. If you don't have enough dough, get a credit card. Go cheap and you'll end up paying more than you originally planned for.
Strider327 is offline   Reply With Quote
Old 06-07-2012, 12:54 AM   #5
02wrxej208
Member#: 295496
2002 ej208 vf34 wrx
different threading, same size, 225 shipped
Old 06-10-2012, 03:58 PM   #6
MisteR2rbo
Member Sales Rating: (2)
Member#: 160914
04 WRX Wagon
Just a little input here...the mishimoto radiator isn't a bad choice really. The leaking issue is a possibility but a little modification would fix it right up. The issue is that they're using a HUGE o-ring at the shoulder of the screw to create a face seal, but leaving the o-ring exposed after tightened down. Even if it didn't leak right out of the box, the exposure to heat, etc will dry that sucker up and leak in the future. If it was done right, there would be an undercut at the top of the threads to allow the o-ring to (1) create the right seal and (2) be enclosed in the assembly. If it were me, I would've put a relief at the internal threads, used a MUCH smaller o-ring and had an ID seal.
The reason why people are complaining about the screw being only finger tight, I believe they're assembling it dry. W/ a dry o-ring, you'll only be able to tighten it so far before friction kicks in. Throw some silicone oil or grease on that o-ring and you can tighten it down properly. This still really doesn't solve the issue though. Go out and get a drain valve w/ the same threads, a crush washer (in lieu of an o-ring) and install that instead. Oh, and forget the teflon tape...you don't need sealant on straight threads. Good luck.
MisteR2rbo is offline   Reply With Quote
Old 06-10-2012, 09:43 PM   #7
ezil71
Member#: 207118
2003 Wrx Wagon
I've had a mishimoto for a few years with no issues at all. Quality is top notch.
IMO 'gimmick' is just that. ebay available parts rebranded. same with fms/ajw etc.
ezil71 is offline   Reply With Quote
Old 06-11-2012, 10:38 PM   #8
MyOtherRideIsUrMom
Member#: 159636
2007 WRX -18G EWG
I have 10k on my mishimoto aluminum rad and no problems. My drain plug came with thread sealant paste and o ring. Tightened it down and no problems. It wasnt tightened out of the box.
MyOtherRideIsUrMom is offline   Reply With Quote
Old 06-17-2012, 07:39 PM   #9
brew02wrx
Member Sales Rating: (11)
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i got a fms/gms radiator when my stock one popped and i needed a new one for cheap, been on for almost a year now and ZERO problems, fitment was perfect.....i'll eventually replace it with a koyo but for now it ain't broke i aint fixin it
brew02wrx is offline   Reply With Quote
looking for advice on a good setup for my 02 wrx dudenhoeffer02wrx Newbies & FAQs 8 04-19-2011 09:44 PM
NC: Looking for advice on replacement radiator (non plastic endtanks) dowroa South East Region Forum 8 10-10-2007 09:23 PM
Looking for advice on speakers for a setup without a subwoofer. Hukabus Car Audio, Video & Security 2 05-20-2005 12:19 PM
looking for advice on some future shopping RChampion Normally Aspirated Powertrain 2 08-14-2002 10:49 PM
Looking for advice on a personalized plate mr_disco Bay Area Impreza Club Forum -- BAIC 13 07-16-2001 05:28 PM
Message Board Statistics All times are GMT -4. The time now is 12:58 PM.
