Old 06-07-2012, 01:10 AM   #1
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
Default Installed new turbo inlet hose, BPV is very quiet
Before I installed the Perrin turbo inlet, my setup was stock inlet hose with Cobb SF intake and air box, catted turbo back exhaust, Cobb stage 2 tune. The BPV noise was pretty loud, as many of you know. The BPV gasket was replaced with a new one the last time I had it off, which was about 3 months ago.
Just installed the Perrin turbo inlet, double checked all connections, the turbo spool is a little louder but the BPV noise upon letting off the gas at low boost and below is almost non-existant, it's very quiet. At high boost it's back to being a loud whoosh. Is this normal? Does the new larger inside diameter hose cause this?
danny_d19 is offline   Reply With Quote
Old 06-07-2012, 10:36 PM   #2
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
anyone?
Old 10-03-2012, 09:23 PM   #3
jhaddock07
Member#: 262954
2005 Super Slow STI
Bump... Having the same issue... I've checked and rechecked all the connections regarding the inlet and can't figure it out... It ended up throwing my CEL which to me seems to be a vacuum leak but I can't for the life of me figure it out
jhaddock07 is offline   Reply With Quote
Old 10-03-2012, 10:42 PM   #4
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I had to do a significant amount of re-jigging with the bpv recirc hose when I installed my inlet. Make sure it isn't kinked.
mechatricity is offline   Reply With Quote
Old 10-04-2012, 10:56 AM   #5
jhaddock07
Member#: 262954
2005 Super Slow STI
That's the conclusion I came to yesterday evening... No boost or vacuum leaks... I have a Perrin replacement tube so hopefully that will fit better... A couple of buddies came over as well to help try and diagnose it to no avail...
Pulled the BPV off and it's takes. a LOT of force to open that valve up..worked on it some more this morning some more before work... I have an extra BPV and I tested how much force it took and its about the same as the other one... It's still not releasing pressure though... Any idea how tough it is to push that flange open generally? That's my last guess once I replace the factory tube with the Perrin silicone one?
Old 10-04-2012, 03:09 PM   #6
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I replied to your PM, but i've never actually tried to actuate the BPV by hand.
So does boost pressure actually fall off slowly when you let off the throttle?
turbo surge after new turbo inlet hose was installed ftarhooks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 12-13-2011 12:33 PM
FS: NoVA: 2005 STi parts: turbo inlet, turbo inlet hoses, BPV / BOV vent hose adjasont Engine/Power/Exhaust 47 02-09-2010 08:10 PM
Just installed Perrin turbo inlet hose on friend's car txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-10-2006 12:53 AM
2nd thoughts about installing my turbo inlet hose... WolfInSheepsCLothing General Community 5 01-18-2005 07:43 PM
to those that have installed silicone turbo inlet hoses... wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-21-2004 08:06 PM
