Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 06-07-2012, 03:29 PM   #1
bpang1
Member#: 67225
2015 Audi S4
Red
Default Undercarriage / Undercar Care
As many of you in the midwest know, there was a recent recall for our cars because of control arm failure due to rust. I had my recall service done here in WA as we have moved and they basically just put a new coating of whatever that undercar stuff is.
I also had a mechanic guess that my wife's car was in the midwest due to a lot of rust under the car during an oil change.
These two incidents got me thinking, "is there a way to refinish the undercarriage?". Like can I just wash the undercarriage then apply more undercoating via rattle-can or do I need a professional to do it to make sure I don't hit anything that I shouldn't?
bpang1 is offline   Reply With Quote
Old 06-07-2012, 07:06 PM   #2
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
what i would do if I was going to tackle the job myself would be to sand down the rusted parts then apply something like bed liner or some type of rust proof paint.
djinn is offline   Reply With Quote
Old 06-07-2012, 07:24 PM   #3
Xjawgi
Member#: 300487
02 Wrx
SRP
I will be tackling the undercarriage of my 02 in the next few weeks. Im in the middle of an engine rebuild so i have some time to clean the undercarriage up. I will wirewheel everything, then pressure wash it. Once its good and clean i will use a bedliner like herculiner or duplicolors bed armor. Ill post up pics when i start.
I just did something similar to my jeep and it came out great.
Xjawgi is offline   Reply With Quote
Old 06-12-2012, 03:08 AM   #4
bpang1
Member#: 67225
2015 Audi S4
Red
^^^Will look forward to that.
Seems like a solid plan just not sure if I can execute as good as others ha ha ha!
Old 06-15-2012, 12:59 PM   #5
wrxfr3ak227
Member#: 236414
2010 BPM Sport ///M3
Alpine White/Red
Subscribed!
wrxfr3ak227 is offline   Reply With Quote
Old 06-16-2012, 02:34 AM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
When I lived in NY, I used to get under my car 2-3 times a month in the winter months to rinse off all the salt and crap(not with high pressure). At the beginning and end of the winter season I would spend several hours with a penetrating oil(like WD-40) on all the bolts then rub as much of all the other components down with the same. When I left NY after 10 years of daily driving my car looked like it was a California car.
In the OP's case, get under your car and scrub, scrub, wire brush, sand and scrub some more. Shoot every bolt with oil, refinish whatever rusty bit you can. You may have to repeat these steps.
Be careful with undercoating crap. It does protect but is a pain if you spray it on stuff you need to work on. The stuff can be sloppy.
Personally I will not stand for rust on or under my car so I get very anal about it. You can go as far or not as you like.
Yes I do detail under my car. Not saying you have to though.
Good luck
Can't wait to see your pics.
Bikelok is offline   Reply With Quote
Old 06-16-2012, 02:30 PM   #7
Dpalmer
Member#: 322860
2002 Impreza WRX
Default underbody
Just the tread I need to subscribe to. I just bought a 2002 WRX and the under body in the rear has some oxidation and surface rust. I'm looking forward to the pics!
Dpalmer is offline   Reply With Quote
Old 06-16-2012, 02:37 PM   #8
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
I use the 3m undercoating expensive but look's nice actually dries. My car's are worth spending the 9 dollars a can on. And like said before wire brush and pressure washer. maybe some sand paper.
spoolinsti05 is offline   Reply With Quote
Old 06-17-2012, 03:16 AM   #9
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Blake, maybe you can try coating your undercarriage with Por-50 (or whatever the number is)?
My car's undercarriage has seen a lot of abuse because I live on gravel roads. Definitely can't enjoy the stainless steel exhausts, or clean undercarriage.
Smoke is offline   Reply With Quote
Old 06-17-2012, 08:22 PM   #10
XsoberX
Member#: 289656
2011 Impreza WRX
POR-15 (Paint over rust 15), also, if you use POR15, you should also check out the acids/etches they sell as well, http://www.canada-por15.com/merchant...ory_Code=POR15 (I know, canadian website, but that's useful for me), as well as the product itself http://www.canada-por15.com/merchant...ory_Code=POR15
The body shop I work at uses this stuff on older cars we have come in that aren't actually getting rust fixed, but have rusty panels that we are working on (customer doesn't want to pay for the rust work, but it's still getting painted). Great product, and if you use it as a preventative instead of a remedy, way better.
XsoberX is offline   Reply With Quote
Old 07-31-2012, 12:22 AM   #11
wearywanderer
Member#: 327706
2010 WRX
Dark grey
I read somewhere today that washing the undercarriage can wash away protectants like grease and lead to quicker rusting... is that true?
I live in Ottawa and they use a lot of salt and sand during the winter months. I run my car through Shell's touchless car wash that is supposed to include an undercarriage cleaning as well.
wearywanderer is offline   Reply With Quote
Old 08-01-2012, 07:13 PM   #12
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
Another option which I've been considering for my Forester is Chassis Saver paint. It's basically POR-15 but cheaper from what I've read.
FCmaniac is offline   Reply With Quote
Old 08-01-2012, 07:25 PM   #13
bpang1
Member#: 67225
2015 Audi S4
Red
^^^Yeah I might try something like that.
I just did the brakes on my wife's Altima which spent just as long in the midwest and everything was rusted...had to replace both front caliper brackets because the pin thingies were stuck in the holes.
Old 08-01-2012, 07:30 PM   #14
FCmaniac
Member#: 142029
2013 Forester
^^ yup, rust sucks... the underside of my Forester was/is a rusty mess. I hit it with a wire brush, some naval jelly and then some rustoleum paint about a year ago but I need to do it again and be more thorough this time. I'm thinking about using the chassis saver this time around since I've read great reviews on it.
Old 08-01-2012, 07:36 PM   #15
FCmaniac
Member#: 142029
2013 Forester
After driving through salted roads when the roads are mostly back to normal, I include the undercarriage pressure wash in the drive through touchless wash. The thought of leaving that road salt and mag chloride or whatever solution pasted all under the car for longer than a week doesn't sit well with me. I doubt the risk is greater than the benefit of washing the undercarriage.
Old 08-04-2012, 10:19 AM   #16
Groundassault
Member#: 309165
you could always use this stuff----> http://www.roversnorth.com/m-19-waxoyl.aspx
Groundassault is offline   Reply With Quote
Old 08-05-2012, 02:23 AM   #17
JerseyDubbin
Member#: 260054
2004 AW WRX Wagon
VF43, Opensource Tune
I know POR-15 is pretty big in the Jeep world and I've seen a lot of people using it. Another option is to wire brush, then prime/paint with rustoleum, and then do a bed liner. I used UPOL-raptor in my Jeep and loved it.
JerseyDubbin is offline   Reply With Quote
Old 08-06-2012, 09:39 PM   #18
PsychoFunk
Member#: 322627
I just got a new WRX and I live in the North, so is rustproofing worth $450? I've been checking out Ziebarts because they seem to be the best at it. Just looking to learn from other experiences.
PsychoFunk is offline   Reply With Quote
Old 08-07-2012, 03:23 PM   #19
Astronautalis
Member#: 323990
If your in Canada this is the top rust control.
http://krown.ca/process.php
Astronautalis is offline   Reply With Quote
Old 08-07-2012, 08:09 PM   #20
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Boeshield T-9
www.boeshield.com
Old 08-10-2012, 05:45 AM   #21
swagen
Member#: 293427
2003 WRX Wagon
what is the stuff the dealers are using to rust proof the control arms?
swagen is offline   Reply With Quote
Pics of undercar braces giggio26 Member's Car Gallery 49 04-15-2006 05:21 PM
Local Vendor Review - D&P Undercar Fitz New England Impreza Club Forum -- NESIC 8 12-13-2005 09:18 AM
How much undercar rust is acceptable on an used 02? affinity1 General Community 9 10-14-2005 10:29 AM
PA: NRG crossmember undercar brace/Rallispec Silencer Delete mmorningstar Private 'For Sale' Classifieds 10 08-28-2005 04:27 PM
Washing undercar.... BajaT05 Baja Forum 7 06-22-2005 11:16 AM
