Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 09-19-2011, 09:46 AM   #1
Visconti
Vendor Sales Rating: (24)
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Default The Shop CT - **Short/Long Block Upgrade / Repair Services**
These prices are for those who want to drop off their engine and have it upgraded / repaired.
Turn around time is normally 1-3 business days for drop offs.
If you would like to drop off your entire car and have us perform these services your looking at a additional $1500.
If you have any questions feel free to PM !
Rebuilt 2.0/2.5L Cylinder Heads
The Shop CT has been in business for over a decade now and one thing that we have noticed over the years in business is that; Not everyone has $20,000 to replace a Blown/Knocking or already unhealthy motor. In today’s economy its safe to say that almost everyone is on a budget, (believe it or not, even we are!) that being said, we offer a Cylinder Head “Rebuild” Package. This package was designed for customers/enthusiast that have owned their Subaru’s for many, many years and are now presented with the option of rebuilding their existing motor. This Rebuild package keeps the budget within reason and get’s your factory Cylinder Heads back to their Showroom condition.
(We also have some customers/enthusiast who like to assemble their own motors, just for the sake of the “Project”. This Rebuild Package offers the customer a clean sleight to start fresh with. The only remaining work would be to install the “Cam’s of your choice” and bolt the Valve Covers up and your ready for Head Stud’s and Assembly.)
-Decked, pressure tested, rebuilt, Valve Seals, Adjust Valve Lash
$800.00
Short Block Drop-in Pistons
-Ball Hone Cylinders
-Wiseco Forged Pistons
$1050.00
**(CP Pistons Available for $100.00 Extra)**
Short Block *Repair* Drop-in Pistons
-Disassemble / Inspect
-Hot Tank
-ACL Bearings
-OEM Oil Cooler
-OEM Oil Pump
$2010.00
**($1,000 Core Charge for extremely damaged blocks)
Long Block Drop-in Pistons
-OEM Head Gaskets
-ARP Head Studs
$1840.00
**(Cylinder Head Service Suggested on high mileage motors - Available for $800.00 Extra)**
**(“Get er Done” Belt, Pump, Tensioner, Pulley Package, Gapped One Step Colder Plugs - Available for $1000)**
**(Cosworth Head Gaskets Available for $150.00 Extra)**
Long Block *Repair* Drop-in Pistons
-Cylinder Head Service
-Hot Tank
-ACL Bearings
-ARP Head Studs
-OEM Head Gaskets
-OEM Oil Cooler
-OEM Oil Pump
$3950
Street Series Basic Cylinder Heads
The SS Basic Heads are designed for Street Car’s and or Auto X Car’s that are looking to hold their power a little further to red line. Typically we see a lot of these heads find their way onto a Pro Short Block to make for a nice 350-400HP Circuit car. In one car we had installed our SS Pro Short block with the SS Basic Head Combination. This car had a HTA Green that made power cleanly from 3,700rpm clean to 7,250rpm, while holding the torque clean across the graph.
-2.5L Factory Bare Cylinder Heads (Deck’d & CNC Finished)
-2.5L EJ257 Machining to Accept Aftermarket Cam’s
-Factory EJ257 Valves & Springs
-Factory EJ257 Retainers & Buckets
-GSC S1 Cam Shafts
**(Head Porting Available for $1200.00)**
**($500 core charge is applied to heads that arrive without buckets)**
**($1000 core charge is applied to heads that come in with damage)**
**($1500 core charge is applied if you need us to send out heads before yours arrive)**
$1,785
Street Series Pro Cylinder Heads
The SS Pro Cylinder Heads were created for the enthusiast that is looking to complete his ultimate Street Car. With the addition of the Supertech Titanium Valve Train system and the GSC S2 Cam’s we have seen steady gains all the way up to 8,000rpm. These heads are commonly placed on the SS Pro Short Block to support the Rotated 35R Kits seen in most Street Cars producing 500+awhp. The GSC S2 Cam’s have been known to give the power-band a gain of 50-80 ft/lbs of Torque from 5,000-8,000rpm. With that said, we have had great success with these heads on the street. They don’t affect the “stock” feeling drive ability while at the same time adding an addition 30-60hp to the over-all setup. These heads are generally found on Street Car’s making anywhere from 450-550HP. Add mild porting to this head and you’ll almost be unstop-able!
-Supertech Valves Springs & Retainers
-GSC S2 Cam Shafts
$2,300
Street Series Race Cylinder Heads
The Street Series Race Cylinder Head Package has been in development for over 4 years now. The Shop CT has been Researching and Experimenting with the different types of Valve Train Systems and Cam’s to arrive at the most impressive head package we have ever seen. Now we have to be honest with you, this isn’t the most budget friendly package we offer. It does happen to be the only setup where we have seen INSTANTANEOUS gains of 100whp.
-1+mm Over Bore Stainless Intake & Exhaust Valves
-Ferrea Valve Springs / Retainers / Keepers / Guides
-Supertech Adjustable Buckets
-GSC S3 Cam Shafts
-Extreme Intake and Exhaust Porting
$5,600
__________________
| 203-856-9946 |
Visconti is offline   Reply With Quote
Old 09-19-2011, 09:47 AM   #2
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Default The Shop CT's Street Series Short Blocks
The Shop CT has been breaking down and building motors for over a decade now. As many enthusiasts know the horizontal Subaru motors are no easy task to perfect. Fortunately, the Shop’s highly experienced and extremely meticulous motor assembling team has seen it all. With that said here are the following motors and services we offer for the Subaru community.
Street Series Basic Short Block
With a budget capped under $3,000 the SS Basic is perfect for those WRX’s or STi’s running an 18G-20G / HTA68 / HTA Green looking to make up to 400WHP. This is the ideal motor for the enthusiast that isn’t looking for 500WHP, but more concerned with keeping their 400WHP build safe and reliable.
-2.5L STi Semi-Closed Deck Short Block
-EJ257 Nitrated OEM Crank
-EJ257 OEM Connecting Rods
$2,900.00
Street Series ProShort Block
The SS Pro is one of The Shop’s most diverse motors ever designed. After almost a decade of constant motor production we have finally designed a motor that is what we like to call the “Ultimate Street Block”. With the option to upgrade or downgrade the internals of this motor, we have seen customers run anywhere from 400-500WHP. With that said, the SS Pro is probably the most popular motor we tend to offer customers.
-Manly H-Beam Connecting Rods
-ACL Race Series Main/Rod Bearings
$3,250.00
**(CP Pistons Available for $100.00)**
**(ARP Case Studs Available for $250)**
**(Manly Turbo Tuff I-Beam Connecting Rods Available for $200.00)**
Street Serires RaceShort Block
The SS Race motor is what we like to put in our Race Applications. We have spent many years working with many different types of parts to discover the ultimate combination. After several years of track use on these Iron Sleeved Race Motors we are now 100% confident in our setup. These motors are an absolute must when pushing the limits of HTA86 or HTA3794s on race gas. Our Shop Race Car is sporting this Race Block with an extravagant Cylinder Head Combination that makes for one fast 9 Second Pass with a Full Interior!
-Darton Ductile Iron Sleeve Liners
-Manly Turbo Tuff (I-Beam) Connecting Rods
-ARP Case Studs
$5,800.00
__________________
| 203-856-9946 |
Old 09-19-2011, 09:47 AM   #3
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Default The Shop CT's Street Series Long Blocks
Street Series Basic Long Block
The SS Basic Long Block is a combination of both the SS Basic Short Block and the SS Basic Head Package. This motor is most commonly seen in customer car’s that come in as basic STG II and STG III Daily Driven Subaru’s. **This also happens to be our “Go To Motor” when it comes to swaps.** Be sure to ask about swapping your Bugeye Wagen or your 2.5rs GC. While maintaining an affordable price tag and the additional options to straighten the motor up. This SS Basic Long Block is the “Turn Key” Solution to most Swaps/Rally Car’s or just plain and simple Daily Driven Subaru’s.
-Street Series Basic Short Block
-Street Series Basic Cylinder Heads
-OEM Head Gaskets
-ARP Head Studs
-OEM Oil Pump
-OEM Oil Cooler
-“Get er Done” Belt, Pump, Tensioner, Pulley Package, Gapped Plugs
$6700.00
**(Stock Cam Option Available for $785.00 Discount)**
**(Cosworth Head Gaskets Available for $150.00)**
Street Series Pro Long Block
The SS Pro Long Block is the said to be the “End-All” Ultimate Street Motor. This “Turn-Key” and Hassle-Free Long Block is made up of the SS Pro Short Block and the SS Pro Cylinder Head Series. As we stated before, this motor is most commonly found in 500-550+HP Street Car’s. The SS Pro Long Block is also one of the most diverse motors we have available to the public. This motor is most commonly installed with cars running Rotated 30-35R Turbos, as well as supporting fuel systems well over 1,000-1,300cc Injectors. This motor can support anywhere from 400HP to what we have actually seen the motor handle 550HP on E85.
-Street Series Pro Short Block
-Street Series Pro Cylinder Heads
-OEM Head Gaskets
-ARP Head Studs
-OEM Oil Pump
-OEM Oil Cooler
$7450.00
**(ARP Case Studs Avaliable for $250)**
**(L19 Head Studs Avaliable for $400**
Street Series Race Long Block
After 10 years of Research and Development The Shop CT has finally designed and created their “Godzilla” Motor. This SS Race Long Block was built and designed to handle non-stop 500-700+HP at WOT with no problem’s what so ever. The SS Race Long Block is not just any motor, it has been through years and years of testing/tuning and non-stop abuse. This motor is typically found in Race Car’s or what we like to call “Monster Street” Car’s. The Monster Street car is a car that comes out probably one weekend a month and it is supported with a cage/dogbox/parachute, So I assume you would get the picture. If your up for the challenge, well so are we. We will gladly accept your request because we at The Shop CT know what it takes to build the bullet-proof Long Block.
-Street Series Race Short Block
-Street Series Race Cylinder Heads
-Cosworth Head Gaskets
-L19 Head Studs
-OEM Oil Pump
-OEM Oil Cooler
$14,200
__________________
| 203-856-9946 |
Old 09-20-2011, 09:02 AM   #4
Shane-TheShopCT
Member Sales Rating: (1)
Member#: 292869
2006 Liberal WRB STi
GT30 .63 A/R 443HP E85
BUMP For all those out there looking to start their winter build!!! The time is here, let's get started and make some Powa!
-Shane-
Shane-TheShopCT is offline   Reply With Quote
Old 09-20-2011, 05:57 PM   #5
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
We build the best motors !
PMs SENT!
__________________
| 203-856-9946 |
Old 09-25-2011, 11:02 AM   #6
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Pm's sent!
__________________
| 203-856-9946 |
Old 09-26-2011, 09:00 AM   #7
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Happy Monday !
Friday we had 3 pro shortblocks on the shelf, this morning we only have one left!
Thanks Nasioc!
__________________
| 203-856-9946 |
Old 10-04-2011, 01:29 AM   #8
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
PMs sent - good night!
__________________
| 203-856-9946 |
Old 10-04-2011, 05:20 PM   #9
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Thanks for keeping these motors off the shelf!
PMs sent!
__________________
| 203-856-9946 |
Old 10-20-2011, 09:10 AM   #10
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Pm's sent
__________________
| 203-856-9946 |
Old 10-21-2011, 08:05 AM   #11
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Pm's sent !
Thank you all for your business, hope your enjoying your motors!
__________________
| 203-856-9946 |
Old 07-20-2012, 06:49 PM   #12
ppericfe
Member Sales Rating: (3)
Member#: 117973
2004 GT52 sti
FJ cruiser vodoo blue
Hi I would like bring my car here on the weekend so we can discuss
ppericfe is offline   Reply With Quote
Old 07-20-2012, 06:59 PM   #13
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Theyre not a vendor on here anymore, but they still sell these motors.
They're open Saturday until 1ish.
Call ahead. 203-847-5791
Good luck !
__________________
| 203-856-9946 |
Short/Long Block Upgrade & Repair Services + Short/Long Blocks Package Deals Visconti Engine/Power/Exhaust 3 09-09-2011 08:09 AM
The Shop CT -Short/Long Block Upgrade / Repair Services Visconti Engine/Power/Exhaust 7 09-04-2011 10:46 AM
