Old 06-08-2012, 05:06 PM   #1
miltonguerrero
Member#: 318502
Default 2.5rs wrx sti conversion
I have a 03 2.5rs and im thinking of doing a sti conversion on it. Can anyone tell me or give me pointers into if its a good idea and how much it would be to do it.
miltonguerrero is offline   Reply With Quote
Old 06-09-2012, 12:37 AM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
I would use a WRX body harness and do a JDM swap, but that is me. The 32 bit US system requires you to swap every little thing.
lukeskywrx is offline   Reply With Quote
Old 06-09-2012, 12:40 AM   #3
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
it's a good idea, you need lots of $$ good luck
murrdogg24 is offline   Reply With Quote
Old 06-09-2012, 03:32 AM   #4
vipers
Member#: 298020
2002 RS-TI
Whitey
im at the tail end of my conversion...02 2.5rs into a full 100% STI.. 05 drivetrain and 06' everything else.. heres the thread
http://forums.nasioc.com/forums/show....php?t=2326927
you will get all the info you need in there!
to answer your questions.. good or bad idea is up to you.. are you willing to put in a TON of time swapping out every wire in the entire car? every nut and bolt? every module, relay, sensor? gas tank? there is a multitude of things different on an STI... just about every component in the car. there are ways to do partial swaps that are cheaper, and easier. but come with sacrifices.
as for cost.. it can range anywhere from about $8k - $12k for all the OEM parts youll need.. then the extras youd wanna add in there as well.
vipers is offline   Reply With Quote
FS: 2004 - 2005 2.5rs/wrx/sti headlights Harnicka Exterior/Styling 0 05-06-2009 04:18 AM
FS: *NEW* Black I Badge Impreza 2.5rs WRX STI sanovichleo Exterior/Styling 6 09-02-2007 12:50 AM
02+ 2.5RS/WRX/STI OEM dash clock Uncle Ben Private 'Wanted' Classifieds 0 02-12-2005 12:26 AM
FS: 2002+ Impreza 2.5RS WRX STI Front Strut Bar Uncle Ben Private 'For Sale' Classifieds 4 04-30-2004 05:56 AM
