Old 06-08-2012, 08:12 PM   #1
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
Default 2012 Impreza-USB Flash Memory Compatibility
Have you used a USB flash drive to play music? Post your experience here. Please post the drive info (brand, model, size) and the results. Any size drive is fine to post about, but I'm ESPECIALLY INTERESTED IN LARGER DRIVES (32GB, 64GB). Edit: if using a larger drive, please indicate how full it is, approximately.
tomwi53092 is offline   Reply With Quote
Old 06-08-2012, 08:32 PM   #2
TObject
Member#: 320185
2012 Impreza 2.0i
TObject is offline   Reply With Quote
Old 06-08-2012, 09:59 PM   #3
ammo_umb
Member#: 316152
2012 Sport Limited
Camellia
I just used an old 1gb and it works good if you make sure to burn music as WMA files.
Note that on the Limited (and Sport Limited) HD radio you can't change sound settings while you're moving but oddly enough it let's you scroll through albums on your thumb drive...
ammo_umb is offline   Reply With Quote
Old 06-09-2012, 04:55 AM   #4
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
32 GB Cruzer, working fine here. Anything adhering to the USB storage standard should work.
Commander Keen is offline   Reply With Quote
Old 06-09-2012, 08:14 AM   #5
tomwi53092
Member#: 316315
DCP
How full is the drive?
Old 06-09-2012, 10:47 AM   #6
Commander Keen
Member#: 319157
About 24 GB, and yes finding music can be a pain. I just use the D>RDM mode to skip around the collection until I get close.
Old 06-10-2012, 01:59 AM   #7
somebody else
Member#: 21618
I listen to my USB "thumb" drives for probably 90% of my driving. I just copied files off CDs, iTunes folders, etc.
I have noticed some file formats won't play but I can't figure out what they are. The head unit just skips ahead to the next readable format.
somebody else is offline   Reply With Quote
Old 06-11-2012, 10:58 AM   #8
tomwi53092
Member#: 316315
DCP
I'll add to the mix here:
Problems using the Patriot 32GB Flex drive (by me) and Patriot 32GB Axle drive (by another forum user).
Symptom: will freeze playing during a song occasionally, maybe every fifth usage or so. For me, seems to happen only during the first or second song, so if you make it to the third song, you're probably good for the rest of your trip. I've tried a bunch of things I won't mention here, can assume that there is some incompatibility between the memory controller in the drive and the head unit.
So now you know why I started this thread. Thanks for the feedback on the 32GB drive, Commander Keen.
Old 06-11-2012, 11:09 AM   #9
Commander Keen
Member#: 319157
Are you using the FAT32 file system?
Old 06-11-2012, 11:57 AM   #10
tomwi53092
Member#: 316315
DCP
Yes, it's FAT32.
Old 06-11-2012, 01:22 PM   #11
Commander Keen
Member#: 319157
Will your thumb drive play through a laptop-style unpowered hub?
Old 06-11-2012, 01:32 PM   #12
tomwi53092
Member#: 316315
DCP
Good question. I don't have one to test with at the moment.
Drive works fine on my PC and Mac, and *usually* works in my car.
If I can just buy another brand that works, I'm fine with that.
Would you mind telling me which model of 32GB Sandisk drive you have? There are several.
Thanks for your troubleshooting efforts. I appreciate it.
Old 06-11-2012, 01:58 PM   #13
Commander Keen
Member#: 319157
Is the FAT32 partition the only one? I've found that the head unit can be confused by extra partitions.
Does it trip up on the same files? If so, are the problem files of the same type?
The drive is a SDCZ36-032G
Old 06-11-2012, 03:01 PM   #14
tomwi53092
Member#: 316315
DCP
Thanks for the drive info.
FYI on my Patriot drive situation:
- Default single FAT32 partition as it was shipped
- Folder depth: 4 (root/artist name/album name/song name)
- Maximum number of files I tried filled to capacity: about 1775 (I also tried it filled to 23.9GB and 15.9 GB)
- Most songs are 320 AAC encoded (simple encoding, no vbr, etc), some are mp3 at varying bitrates. If it hangs on a song, I can reset the stereo, go back to the song, and play it fine.
- Also tried truncating file names to 18 characters, as my Type B stereo only displays the first 12 characters anyway.
- I usually play in disk random mode. The location of the song files when it hangs is anywhere on the drive: one of the first, or middle, or last.
I also have a Patriot XT 16GB (PEF16GUSB) drive, and the same song files play fine.
Old 06-11-2012, 04:25 PM   #15
12ImprezaSL
Member#: 322198
2012 Impreza SL
I have my 1st gen iPod touch hooked up to it. Works great.
12ImprezaSL is offline   Reply With Quote
Old 06-13-2012, 07:05 AM   #16
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
Just tried an older 4th gen ipod and it won't work I can't seem to find a use for that thing...
darkbug is offline   Reply With Quote
Old 06-13-2012, 10:11 AM   #17
tomwi53092
Member#: 316315
DCP
You should be able to use it through the aux port. It won't be controllable with the buttons on your stereo or steering wheel, I don't think, but it will play. You'd have the benefit of being able to play Apple Lossless files (higher quality than mp3/aac).
Old 06-13-2012, 03:33 PM   #18
billnparts
Member#: 312928
I've used several sizes (largest 16GB) and makes (whatever was on sale)that all work in my laptop.
No issues...everything works great.
billnparts is offline   Reply With Quote
Old 06-13-2012, 07:48 PM   #19
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
I rather use an old thumb drive so I can control it via the radio. I mainly use Pandora via Bluetooth but my travels take me into no cell service areas.
Old 06-14-2012, 07:55 PM   #20
John451
Member#: 321966
2012 Impreza + XV 14
Black Pearl + White XV
Not sure if it applies with the Subarus USD memory but have found my bikes Zumo GPS doesn't like the memory card to be fragmented, ie it works fine formatted and everything copied over in one go or at least only add new songs to it without deleting old ones but if you delete old songs then copy in new ones it only partially plays songs then skips to the next track.
John451 is offline   Reply With Quote
Old 06-18-2012, 09:09 PM   #21
tomwi53092
Member#: 316315
DCP
I got this drive as you suggested and it's worked great for the last three days, with plenty of car starts to test it. I'll post an update if it starts to act up, but so far has been flawless. I have it filled to capacity.
This drive is fairly slow to save to, but that's OK. I don't plan on updating it much. Slow old technology = maximum compatibility.
Thanks for the tip.
Old 06-19-2012, 12:38 AM   #22
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I have the Patriot 32GB Axle drive and it freezes while playing music every so often, I listen to my music on random. I thought this was because all my songs are in the root directory, I got lazy and didn't use a folder system.
It's hard for me to replicate the variables for it to freeze, it does seem to freeze less if I don't turn on shuffle. So there is no solution for the Patriot 32GB Axle drive? I just bought it too, solely for the purpose of storing mp3s in my car with it.
While we're on the topic of mp3 tracks and the head unit, is there a way to make the mp3 titles scroll (like it does for radio stations) so that way it can display more than 18 characters.
pkL is offline   Reply With Quote
Old 06-19-2012, 10:28 PM   #23
Commander Keen
Member#: 319157
Glad to hear it works, Tom. Like you said, the relatively slow write isn't a big deal.
Old 09-28-2012, 04:52 PM   #24
CriticalityEvent
Member#: 281670
2012 WRX
I purchased a 32GB Emtec C600 and I am having this problem in my ’12 WRX with the standard stereo. I only have a few hundred songs on it, totaling 3-4GB. My 2GB thumb drive had no issues at all, but I can’t remember the manufacturer (might’ve been off-brand).
I’ve noticed that when I first turn on the car, it happens very frequently. As I drive, it becomes less problematic. Cycling through USB and radio modes doesn’t do anything for me; I either need to wait about a minute for it to reboot itself, or pull the drive out and put it back in. If it reboots itself, it starts from the first song on the drive. If I pull it out and re-insert it, it actually resumes from the point it became stuck.
CriticalityEvent is offline   Reply With Quote
Old 09-28-2012, 05:34 PM   #25
tomwi53092
Member#: 316315
DCP
Sounds similar to my original post regarding my Patriot drive. I did lots of things to try to fix the problem before posting here. I bought the 32GB Sandisk drive suggested by Commander Keen and it's worked flawlessly since I posted in June. It was less than $20, so a great fix to the problem. I have this drive filled to capacity.
Will this = cheaper flash memory and good times for all (consumers)? snvin Off-Topic 4 03-20-2006 10:57 AM
Flash Memory prices cut in half soon? Idjiit Off-Topic 13 05-25-2004 01:54 PM
Flash memory card question.... BrandonC Off-Topic 2 05-16-2004 06:50 PM
attn: nerds/dorks - USB flash memory Watch soundwave Off-Topic 5 03-01-2004 09:27 AM
Iriver 256MB IFP-390T MP3/FM player/recorder and flash memory drive wrk king Private 'For Sale' Classifieds 8 02-04-2004 02:06 AM
