Old 06-09-2012, 11:28 PM   #1
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Default A question about 20H buckets
I'm pulling apart a 20H and when I took off one of the exhaust cams the buckets started sliding out. I've got them in place using a temporary measure but what I want to know is if I take the buckets out, do I have to put them in exactly where I took them out or will it not matter if I mismatch the buckets when I put them back in?
Save myself making a second thread does anyone know if the up pipe for the primary turbocharger on a 20H/R is the same as a 20G/K up pipe? More specifically the flange that the turbocharger bolts on to.
i_c_the_light is offline   Reply With Quote
Old 06-13-2012, 02:48 PM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Bump. Come on guys.
Old 06-13-2012, 04:05 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Yes they have to go back into the same place. If they are shim over or shimless buckets they are specifically so many thousandths for each positions requirements. If you mix them up you can be too tight or loose and bend valves break springs or not get valve seal and then you dont make compression.
Pull each one out individually as you go and clean it well with break clean, let it dry and write on the top with a sharpy where it came from.
If your puttign in new valves then you have to remeasure all the tolerances and size the buckets accordingly.
dangerousatom is offline   Reply With Quote
Old 06-13-2012, 04:41 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yes, they need to stay in the same place.
No, the uppipe flange is different.
Old 06-14-2012, 02:09 AM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
get some feeler gauges.
elislider is offline   Reply With Quote
Old 06-14-2012, 04:47 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Unless the EJ20H had HLA buckets then it doesn't matter.
Marnix is offline   Reply With Quote
Old 06-15-2012, 08:35 PM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Does have HLA. So it does matter. I've got them on a piece of cardboard on the garage floor laid out in the same pattern if the heads were off the block and placed on a flat surface. But I'm going to clean and label each one in case anything happens while they're on that piece of cardboard.
Old 06-16-2012, 12:57 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
If the engine has HLA buckets it doesn't matter where you put them, they are all the same.
If the engine has shim over buckets, each shim as a specific thickness matched to the position in the cylinder head. If you mess that up you will have a hard time re-adjusting valve clearances.
Question about a swap? WRX2EVOX Subaru Conversions 6 07-06-2012 09:31 AM
Question about bucket seats and sldiers dorifto88 Interior & Exterior Modification 1 02-24-2012 04:02 PM
Few questions about the Perrin Turbo Inlet and about the Samco MAF arm???? BLUETURBOWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-21-2003 03:53 PM
question about what i should do about these 2 girls skylineR34 Off-Topic 28 07-23-2003 07:44 AM
About to buy STi, question about Subaru's fit & finish... JT-KGY STi Forum Archive 19 01-27-2003 02:39 PM
