Old 06-10-2012, 09:31 PM   #1
my928s4
Member#: 158412
Default JDM EJ205 Into a Porsche 914
So the JDM motor is a 2006 from a Forester, I will post some progress but wanted to ask a couple of questions.
I bought a US WRX bulkhead harness and have pretty much stripped out what I do not need, however, this connector I cannot find any info on in the wiring diagrams. Any ideas?
YB-> 16pin Diag
BW -> 16pin Diag
RW -> Line End connect
YG - B134 Pin 20 (in the wiring diagram the YG goes straight from the Diag connector to the ECU)
Also I do not see where the wastegate solenoid should connect to, I believe there should be a 'T' in this tube shown but I do not see one. Am I missing something?
Thanks for your help!
Chris
my928s4 is offline   Reply With Quote
Old 06-11-2012, 12:10 PM   #2
thebionicman
Member#: 247561
2011 TR-42S
That white connector looks like your flash block. The colors are correct.
thebionicman is offline   Reply With Quote
Old 06-11-2012, 01:45 PM   #3
my928s4
Member#: 158412
You mean B250 in the diagram below? That is a 3 pole connector.
Old 06-11-2012, 04:44 PM   #4
thebionicman
Member#: 247561
2011 TR-42S
That page is from the 02-03 manual. This is from a 04-05 manual.
When I was prepping my harness for the kit car I ran into the same thing that I didn't have the right manual for this connector.
Old 06-11-2012, 04:47 PM   #5
thebionicman
Member#: 247561
2011 TR-42S
If you look up Flash Block for the 04-05 it jumps the wires in the B300 to allow the ECU to be flashed.
Old 06-11-2012, 05:37 PM   #6
my928s4
Member#: 158412
Found it, I guess my harness is a later MY than was advertised, thanks!
JDM EJ205 into BK MyogiNightKid Subaru Conversions 5 02-27-2010 10:32 AM
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 05:52 PM
subi 3.0 engine and A/T into a porsche 914 69_Lex Subaru Conversions 9 06-29-2008 07:28 PM
EJ20T into a Porsche 914, a few ?'s Crazyhippy Subaru Conversions 5 01-13-2006 04:17 PM
EJ25 into Porsche 914!!! :) Clegg Mid West Subaru Owners Club Forum -- MWSOC 4 02-10-2002 01:39 PM
